Question about Seagate Barracuda 7200.10 500 GB SATA Hard Drive
External Hard Drive Beeps and Doesn't Connect
It's a Seagate Barracuda 7200.10, 500GB.
It fell down about 2ft and no longer connects to my laptop. It still gets power; the light comes on, but it just beeps out this strange chirpy noise.
I think the disk can't spin or something; is there a way to make it spin?
I've got a lot of data on the thing, enough for it to be valuable in the region of a several hundred pounds, but not the thousand eight hundred that seagate were asking for for them to retrieve my data.
Hell, even if there's a short term '3 hour' fix, that would be perfect for me to just copy everything off it onto another drive.
Thanks!
  • 1 more comment
  • seanbrown89 Apr 14, 2009
    jimscot531
    By no longer connecting, I mean the bios can't detect it; cmd, f: etc brings up nothing (that is the name of that particular port, but I tried all the others anyway)
    To check, I tried to connect it to another PC, but nothing then as well.
    fougzki
    I'm thinking of taking it apart and replacing some components to see if it will run, even for a few hours, do you think that will work?
  • seanbrown89 Apr 21, 2009
    Thanks for the help, but I've already chucked it now, having it there and not working with so many other examples of the same drive just not working was getting me quite ansty
  • Jim Scott May 11, 2010
    how do you mean it no longer connects to your laptop ??
  • 29 Answers
This is very common in the 7200.10 series,there is the bug of the firmware,so u must update ur fw and the your drive will be detected by the bios and pc.
there is many cases in this website:www.salvationdata.com/blog
Posted on Apr 21, 2009
  • 700 Answers
You may consider this options but if you have no more options. This treat your hard drive as to be trash already.
Some do it this way, they swap the board of the harddrive with a good board with the same make, model, capacity, and board design, also its revision.
Hoping they can run it, only if the harddrive board that gets defective. But still sometimes will get some issue for it.
Posted on Apr 14, 2009
Seagate barracuda 7200.9 connect to USB
You will need an external Hard drive adapter case.
This will probably come with driver disk.
If already and external drive it may have internal firmware which talks directly to the PC.
Just install drivers, if any, and plug unit in.
Follow screen prompts.
Sep 15, 2012 | Seagate BARRACUDA Computers & Internet
I have a Seagate Barracuda ATAIV model ST340016A 40 Gig HDD. I want to put it in an external enclosed drive so that I can format and wipe the drive. I suspect it has some viruses on it that are bogging it...
You do not need a driver, I suspect the Seagate hard drive may be faulty.
Try conncting your hard drive as a Slave drive in your computer, if the BIOS does not detect the hard drive then the hard drive is faulty.
Aug 11, 2011 | Seagate Barracuda ATA IV (ST340016A) 40 GB...
Hi guys, my seagate barracuda 7200.8 300 gb hard disk notworking. power is not coming to external harddisk, so i open the case connect it to lap by using some wires(dont know given by my friend), stil...
I have the same problem like yours right now. The on-board circuit of my Seagate Barracuda burned and I'm planning to buy new Seagate Barracuda with the same specifications, same model.. I will try to disassemble the circuit of the new one and connect it to the old hard drive to take a chance if it will work and retrieve my files. If it doesnt work, at least I try and I still have a new hard dist to store my new files.. If you want to do the same, you must be careful in handling the circuit board. It is very sensitive and can be damaged with just touching the components.. I recommend you to discharge static electricity of your hands by touching anything that is made of steel.. The steel will discharge static electricity, but still, to make sure you wont damage the circuit, just touch the circuit board on its sides.. Never touch any components, it will damage your circuit board.
Jun 22, 2011 | Seagate Barracuda 7200.10 250GB (7200rpm)...
Seagate Barracuda external hardrive - damage to usb connector on
Assuming the drive itself is still ok (it sounds like it would be), then yes, you can put the drive into another case or directly into the motherboard if you know how to do that.
May 27, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
External hard drive fell on floor. Now will not
I would send it back to seagate but don't tell them it hit the floor
Jan 09, 2010 | Seagate USB 2.0 External Enclosure + 400GB...
Seagate barracuda external 500 gb hard drive usb not seen any longer,cables and power okay , tried on three computers
Verify what Drives have been detected by your Operating System by using Windows: Control Panel -> Admistrative Tools -> Computer Management -> Disk Management -> Your Hard disk(s) will be displayed with all existing partitions and any assigned drive letters.
Your external (or internal) drive must be recognized as having formatted partitions that have a drive letter assigned to each required partition.
Hope it helps: let me know how you go!
Dec 30, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
I have an Eagle external hard drive enclosure. It has disappeared
check your connections also the enclosure may be bad
Jul 20, 2009 | Computers & Internet
Open Questions:
bricked hard drive? Would folling this lead to a full hard drive format or just unbricking a drive like people sat it does?? Also any other ways that might help would be great to know, heres what i'm talking about! "Fixing The Drive NOTE: Commands for you to type are in red boldface. Pay attention to upper & lower case - it is important. Turn on power to the RS232-to-TTL adapter and the hard drive. After a few seconds, Press CTRL+z. You should then see a prompt like this: F3 T> If not, swap TX & RX wires. Access Level 2 (type /2): F3 T>/2 (enter) F3 2> Then spin down the (disconnected) motor: F3 2>Z (enter) Spin Down Complete Elapsed Time 0.147 msecs F3 2> Very carefully, remove the cardstock that you placed between the PCB and the drive head contacts. Carefully replace and tighten the 3 loose screws. I suggest using a small piece of masking tape to help you hold the screws while you put them back in place. Then start the motor: F3 2>U (enter) Spin Up Complete Elapsed Time 7.093 secs F3 2> Next go to Level 1 (type /1): F3 2>/1 (enter) And do a S.M.A.R.T. erase (create S.M.A.R.T. sector): F3 1>N1 (enter) Cycle power to the drive, then do partition regeneration: F3 T>m0,2,2,0,0,0,0,22 (enter) After 15-30 seconds, you should see something like: Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 14, Max Certify Rewrite Retries = 00C8 User Partition Format 10% complete, Zone 00, Pass 00, LBA 00004339, ErrCode 00000080, Elapsed Time 0 mins 05 secs User Partition Format Successful - Elapsed Time 0 mins 05 secs Do not turn off drive until you see this message. Once seen, drive can be turned off. Power down everything, place drive back into your computer, and confirm that it's working." Thanks.
Apr 12, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Seagate Barracuda 7200.10 500 GB SATA Hard Drive Logo
900 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
