Question about Radio Shack Pro-97 Handheld Scanner
Distorted The voices on my scanner are so distorted that you can't even understand what is being said. I've tried other frequencies but they're all that way.
Are you using batteries or an AC/DC adapter? The only time I've seen the voices get distorted on my Pro 97 was when the batteries were about to die. If you're using an AC/DC adapter in some way to power yours, maybe there is something electronically wrong with your Pro 97. This is not intended to get you to throw it away.
Posted on Sep 30, 2007
6ya staff
SOURCE:
They speakers, when they hit hard they make this odd... smacking sound.. Also on just like.. eminem songs and some rock songs that I listen to whenever the subs hit the vocals get distorted, but when I...
Well it sounds like you need a mono block amplifier for the subwoofers. Subwoofers are ment for low frequency. If you try to run regular audio through the subwoofer the sound will become distorted at a high volume. If you have a crossover on the amplifier try putting it on LP. Also do not exceed the RMX rateing on the subwoofer because if you do they will also distort. If you try adding the mono block on to it and it is still doing it you may also be running to much power to the subwoofers.
Jun 13, 2011 | Alpine SWS-1043D Car Subwoofer
My SONY Home Theater Model HT-6600DP unit was working fine and then about tow years after...present, my sub woofer is sounding distorted. Why is this happening? Please help me as I often watch my home...
Is it so even at lower volumes?
Are you sure it's the sub distorting and not the front or center speakers?
If you designate them incorrectly as Large (which tells the receiver they CAN effectively produce bass frequencies) they will probably distort in the presence of low frequencies.
See Page 17, 19
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sony-HT-6600DP-Home-Theater-Systems-manual/id/390ag319/t/2/
Mar 13, 2011 | Sony HT-6600DP System
Recorded acoustic guitar is fuzzy and distorted
Try anouther Microphone sounds like the frequence sprecturm is to low.
Jul 09, 2009 | Samson C01U USB Condenser Microphone...
Distorted sound (voices sound like "Alvin and the Chipmunks"
Have you tried another set of speakers? If not I would do so cause your speakers might have just gone bad!
Mar 22, 2009 | HP Pavilion a1730n PC Desktop
Distorted / skipping sounds from Acer laptop
Go to the sound icon which is at the right hand bottom corner on your task bar, explore properties cheack wheather voice supression is any thing else than 0.As well as check for enviroment.
Mar 14, 2009 | Acer Aspire 5100 Notebook
Uniden BC80XLT Radio Scanner distorted
It may very well be an interference problem. While the scanner may not have moved, there are many items around it that may be the source of interference. Think back to the time when the interference started. Did you install something new around that time frame? Perhaps a new computer, a new monitor, some new CFL light bulbs? Any of these items can cause interference. The other possibility is that the interference is coming from outside your home or office. While these sources may not be able to be corrected, you can do a few things to help reduce the effects of the intererence:
1. Move the scanner to a new location. Radio waves are tricky little things. You may be able to find a location where the interference is weaker, but your intended signal is still adequate.
2. Try moving the antenna. If using the rubber antenna that came with the scanner, try laying the scanner flat instead of upright.
The other thing you may want to do is check the frequency with another scanner. There is always the remote possibility that the problem is with the transmitter, and not with your scanner at all.
I hope this helps. Good luck!
Dec 27, 2008 | Uniden BC80XLT Handheld Scanner
Distorted voices
if it sounds garbled it may be due to digital communication. most scanners cannot recieve the digital communication. that is why you hear a garbled inaudible sound from it.
Jun 18, 2008 | Uniden BCD396T Handheld Scanner
Voice not working properly on garmin nuvi 660 - very disdorted
i have been told that voice to street is not as clear as the voice just stating turns. If it really bothers you then try voice to turn. I cant remember the setting but it should work well for you.
Dec 03, 2007 | Garmin Nuvi 660 GPS Receiver
Noise Cancelling distorts voice
try lowering the volume on the headset while using phone in quiet areas to avoid feedback.
Nov 30, 2007 | Motorola Mobility H700 Wireless Headset
Radio Shack Pro-97 Handheld Scanner Logo
163 people viewed this question
Top Radio Shack Radio Communications Experts
Robert McClure
Jason
Perry Mellott
Perry Mellott
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
