Question about Linksys EtherFast Cable/DSL Router
Connectin a linksys Befsr41 wired router to a Motorola 2210 modem
I need help connecting a linksys Befsr41 wired router to a Motorola 2210 modem. I connected it to a speedstream 4100 modem but i upgraded at&t service and got a motorola 2210. i reset the router and entered the info but it won't get online. many people online say that i should bridge it but others say it messes with the dsl connection. I will bridge it as my last resort if it doesn't work.
  • 3 more comments
  • ricarcr5 Apr 16, 2009
    For rtrahan everything is connected as shown but now the modem is blinking red and green and is out of sync. the modem, ethernet cable and data cable are new . can my phone box be the problem ? if so can i have a step by step help on how to fix the box and how to properly connect the modem to the router. i don't want to bridge the modem because it might have some unexpected results. please i hardly know what i am doing wrong.
  • ricarcr5 Apr 19, 2009
    i have gone into the set up and put my screen name and password int the pppoe section( should it be in the dhcp section?) and it saves the information but after i try to access the internet ,the modem turns red( the router is working fine: the modem's sync to the dsl is the problem) so is the problem in my internet service provider's (at&t)hands or in my phone line? if you have been wondering i am using my friends computer :(
  • Anonymous Apr 27, 2009
    Linksys Befsr41 doesn't see the Motorola DSL Modem Model 2210 to get on line. What do I need to do
  • Randall  Trahan
    Randall Trahan May 11, 2010
    No you can't change anything in the wall...that's get you electricuted...have you gone into your router's software and made any setup yet?
  • Randall  Trahan
    Sounds like a hardware issue..how do you have it set up>one modem phone line to wall>ethernet from modem to Router>ethernet from Router to Computer?
  • 611 Answers
Do one thing change the ip address of the LAN in the 192.168.2.1 in the router then you get it after that configuration you done right ok
Posted on Apr 14, 2009
  • 741 Answers
You need to set it to DHCP not PPPoe...DHCP stands for Dynamic Host Configuration Protocol, which means it will assign your IP addresses automatically to each of the computers connected to the router each time you turn your compute on..so yes you need to change that for sure, you won't get anywhere with PPOE...
Posted on Apr 19, 2009
I recently had to have my Speedstream 5100 modem (surge damage?) that was connected to my Linksys BEFSR41. The new modem is a Westell ADSL2+ router. Ever since the change in modems, my Linksys BEFSR41...
Without a model number, it's difficult to tell you exactly how to resolve this issue. What you need to do is make sure that your modem is set to bridge mode. You'll need to plug directly into the modem, access the web interface that it uses (usually 192.168.0.1 or something similar) and set it to function as a bridge instead of a router. You should disable DHCP as well, but before you do that make sure you know how to do a full reset of the modem so that it will return to factory settings because disabling DHCP makes it tricky to access the web interface which means if you need to access it again later, you'll need to do a full reset.
Jul 02, 2011 | Computers & Internet
My new WRT160N Linksys won't connect ATT Motorola 2210 DSL Modem
For AT&T default IP address for the Motorola modem is 192.168.1.254.
Default for the Linksys IP address is 192.168.1.1.
Have you changed either one? For them to work correctly they need to be in different subnets. An IP Address of 192.168.y.xx, where y is the subnet and a different number for each device, usually 0, 1, or 2.
If they are in the same subnet, change the modem'smag-glass_10x10.gif IP to 192.168.0.254 or 192.168.2.254. Once you do this you will need to use the new address to access the modem.
You should make sure the router'smag-glass_10x10.gif gateway is outside the DHCP rage of the modem.
Dec 06, 2010 | Linksys WRT160N Wireless Router
How do I connect it to a motorola 2210 modem
This FAQ is for configuring a BellSouth supplied Motorola/Netopia 2210-02-1006 with a generic third-party router that isn't specifically covered in the existing FAQs. If you have a router that is covered in the FAQs, I suggest you use that FAQ. This initial setup is all that is needed to configure and connect your generic router based network for FastAccess DSL. Any additional setup for features like DHCP IP ranges, port triggering, etc is out of the scope of this FAQ.
This FAQ has 4 Major sections:
Section 1 - Overview
Section 2 - Motorola/Netopia 2210 modem configuration
Section 3 - Third party router configuration information
Section 4 - Connections and power up
•The best configuration for networking a router with the Motorola 2210 is to set the 2210 to "Bridged Ethernet" mode and allow the third-party router to do the routing and DHCP functions. The 2210 is also a router with full DHCP functions and may not function correctly when connected directly to another router. Not changing the modem to Bridged Ethernet will result in double NAT'ing, increased latency, possible IP conflicts, or possibly a network that doesn't work at all.
Before proceeding both the 2210 modem and third-party router must be reset to default. Despite what the help desk tech tells you, resetting the modem does not put it into Bridged Mode.
• The BellSouth Installation CD and Connection Manager are not required to use this configuration.
• The third-party Installation Wizard CD should not be used in this configuration.
• Since BellSouth assigns static IPs via your username the configurations shown are applicable to both dynamic and single static IP customers.
• You must connect the 2210 directly to the computer's NIC to make the necessary changes before you connect the router, because you will probably be unable to access the modem interface after you connect the router. The reason is that the modem interface is 192.168.1.254 which is a local IP. By default, most routers do not have the capability to route a local IP out of their WAN port (where the 2210 is connected). Additionally, they may be on completely different subnets. After you have made the changes to the 2210 you can then connect the router and configure it for use with FastAccess. There are several alternatives around this problem. One method involves extra equipment (second NIC and a hub) and major configuration changes. The second method requires you to utilize the router as a simple switch and use the 2210's PPPoE and DHCP functions. Click here for more information.
•If you encounter any problems simply reset the 2210, connect it directly to your NIC, restart your computer, log into the interface, and start over again.
Section 2 ? Motorola 2210 Configuration
bred.gifStep 1
Verify that NIC cards (wireless or wired) are set to "Obtain IP Address Automatically". Completely power down the 2210 and the computer(s). Power up the modem and press the reset button on the back of the modem. After the modem has fully initialized connect the 2210 to the NIC and then power up the computer.
bred.gifStep 2
Open a browser session and enter "192.168.1.254" in the address field to access the 2210 GUI interface.
bred.gifStep 3
Enter your BellSouth Username followed by "@bellsouth.net" in the User ID field. Enter your BellSouth Password in the Password field. Re-enter your BellSouth Password in the Confirm Password field. Click on Next. Update the Auto Calender Update Configuration as desired and click Next. The modem will try to initiate a session and then return to the main menu.
bred.gifStep 4
Click on Broadband DSL Line from the top menu. Click on Configure Connection from the right menu. Select "Bridged Ethernet" from the Protocol pull down. Click on Save and restart the connection at the bottom. This will automatically restart the modem and the interface will return after the changes are saved. Note: functions like NAT, DHCP, IP Passthrough, and username and password will be disabled or irrelevant and can not be selected. After the modem has restarted, power down both the computer and the modem then physically disconnect the 2210.
Section 3 - Third-Party Router Information
bred.gifStep 5
After the PC is powered down connect one of the router LAN ports to the computer NIC and power up the third-party router and then the computer.
bred.gifStep 6
Open a browser session to access the router interface as per the router's user guide. Even though the interface will vary from router to router you must use the following configurations as a basic rule:
- Select Obtain an IP address automatically. Important Note: Use Obtain an IP address automatically even if you ordered a static IP.
- Select PPPoE connectivity. Do not select any other choice, even if you have a static IP.
- Enter your BellSouth Username followed by "@bellsouth.net"
- Enter your BellSouth Password
- Select "Keep Alive" or "Always On" (if available)
- Set "Maximum Idle Time" to "0" which is similar to "keep alive" and "always on" (if available)
- Select a redial or reconnect period of "180 Seconds" (if available)
- Enter "1492" in the MTU Field (if available)
- Save your settings (which will probably restart your router)
Section 4 - Connections and Power Up
bred.gifStep 7
Power everything down and physically connect the 2210, wired or wireless router, and any computer(s).
Pictures by Andy Houtz
bred.gifStep 8
Power up the network equipment in this order:
1) Motorola 2210 Modem (wait for DSL synch)
2) Third-party Router
3) Computer(s)
Open a browser session and go surfing!
bred.gifImportant Additional Information
•The 2210 has an "Internet" light that is green whenever there is an active PPPoE session initiated by the Motorola. Since you are using the Netgear to establish the PPPoE session the light will stay off. This is normal.
•You should check your tweak settings to optimize your new network. Reminder: If you are required to change your MTU, make sure that it is identical on all equipment (PCs and routers) in the network.
bred.gifCool Stuff
An online, html-based menu simulator program is available here. The simulator recreates the Motorola 2210 user interface and provides the ability to navigate menus; just like the real modem interface. It is for simulation purposes only and will not make any changes to your actual modem.
Jun 09, 2010 | NetGear WGR614 Wireless Router
Linksys router will not connect with motorola 2210 modem
Your problem may be timing.
Make sure you have all your cables connected correctly.
Do not have power to either the modem or router.
Plug in you modem and watch the lights go to work. Wait for them to settle down. Now plug in your router, again watching the lights. It should work now.
You can download Linksys' LELA program to monitor the network. Shows green lines to your computers, etc. when working and red lines when not. It will also give your status and make suggestions if you loose your connection.
Good Luck
Feb 24, 2010 | Linksys Wireless-G WRT54G Router
BRIDGING MODEM AND ROUTER
Your firmware may not support bridge mode, try installing dd-wrt from http://dd-wrt.com/dd-wrtv3/index.php
Aug 19, 2009 | Linksys Wireless-G WRT54G Router
Setup router with vonage device and dsl modem
For the best call quality, I suggest you connect the Vonage router to the DSL modem, and if necessary, connect the Linksys router behind that. Why are you using a second router, though - you probably just need a switch or hub, if you're trying to connect more machines. Small networks rarely require more than one router. MaverickSolutions.biz may be able to provide additional support if you can give us more details about your installation.
Jul 20, 2009 | Computers & Internet
I have linksies router and 2 wire modem will they work together?
If the Modem has an ethernet port (looks like a large phone plug like the ones on the router) connect an ethernet cable from it to the "internet/wan" port on the router. If it doesn't there isn't much you can do.
Dec 30, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
2210 modem to befsr41 router connectivity
HI
JUST GO TO THE SETTING OF ONE OF THEM AND CHANGE THE DEFULT GATE TO CHANGE THE THIRD NUMBER BY ADDING ONE OR SUB. ONE
Dec 12, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Wireless network broken, access to WRT54G & Motorola 2210-02 via http.. denied
I have att yahoo dsl which I installed about a year ago. The process required bridging the ADSL Modem (in my case a speedstream 4100) and accepting dynamic IP addresses and configuring PPPoE on the WAN side of my Linksys router. The ATT support person walked me through the entire process over the phone even though I was comfortable with making the Linksys configuration changes as I had to do the same in China without technical support. The modem configuration was no more difficult than the router configuration as it was performed from a web browser too. The biggest warning was that to reverse the modem change (if desired) required use of a reset button because the web interface was disabled as a result of the configuration change. My advice to you especially if you are willing to attach the Linksys router to the telco modem is to contact the ATT highspeed DSL support line and see if they will walk you through it like they walked me through it. Reviewing your Linksys User's Guide and understanding the configuration of that device would probably be appreciated by the ATT Support person as well as assuring you can access the Linksys router to configure it during the call.
Dec 08, 2007 | Linksys Wireless-G WRT54G Router
Linksys EtherFast Cable/DSL Router Logo
876 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
