Changing used toner cartridge
I need to change the used toner cartridge, and I have never done that, nor do I know how to get to it.
  • 1 more comment
  • Gools Jan 14, 2008
    My SCX 4720F Printer stopped printing and gave the red indicator signal for a new toner. It also said 'Empty Toner'. I have refilled my toner cartridge and I still gets this messages and it still won't print. Is there someting I need to do like resetting the printer to recognize the toner and print again. Please let me know how to get this printer to print with this refilled toner. Thank you.
  • Anonymous Jun 11, 2008
    same problem for a work cart. and it still maintains the empty black cart. red light
  • clip52 Jul 29, 2008
    Kids left for college...I can't find owners info
    I need to change the ink cartridge for a Lexmark z42 and can not remove the old one... help
It depends on what kind of printer you're talking about and even then, there might be some differences between different makes and models.
The easiest way is to take a look in the manual, it is described there. If you don't have a manual, you should be able to download one from the manufacturer's website.
For inktjet cartridges, most of the time you have to tilt the old one towards yourself (after opening up the cover when the printer's on - the cartridges are transported to the middle) and then pull it out. The reverse should be done for the new cartridge.
Posted on Jan 04, 2008
  • 233 Answers
What is the printer make and model
  • 82 Answers
Dear you did't specify the printer otherwise if you want to change the cartridge the best solultion is that read the printer manual the you can easly change hope you can do bye
Posted on Sep 21, 2007
I want to know the solution to a sharp ar-5316 i refilled the toner after the toner was empty and the red triangle is still blinking, what should i do?
Does the toner cartridge have a electronic chip on it? if so you could refill it all day long it would not change once the chip say the i am done the cartridge is done. Sorry.
Try this site as a start and get a new OEM cartridge
Jan 28, 2016 | Sharp Ar 5316
I changed the toner cartridge and when started back up, it goes though initiating and then says "toner life done" "replace cartridge. using brother brand. never had this problem b4.
Do you have another toner? Seems like the chip was not reset when they recycled the cartridge. Call your supplier about a replacement if another toner fixes the issue.
Jul 24, 2015 | Brother HL-6050DN Laser Printer
When any color cartridge finish , you must change the whole unit Why?????
No, you must change only the toner cartridge that has finished. It would be quite a waste to replace a toner cartridge that's not empty. Here are the codes for each cartridge, to know which one you need:
-CB540A Black Toner
-CB541A Cyan Toner
-CB542A Yellow Toner
-CB543A Magenta Toner
Remember to always use genuine cartridges.
Dec 12, 2010 | HP LaserJet CM1312 All-In-One Printer
Sharp ar 5127 erorr u 2-40
Pl do something as follows (1) Change Toner IC Chip (90%), (2) Check the toner Cartridge. If it wont be done, pl let me know.
Dec 07, 2010 | Sharp AR-5316 Advanced Digital Imager...
I changed the black ink cartridge in my printer and then when i closed teh lid it said "PRINT CARTRIDGE: Refer to printer documentaion" have put in cartridge that i know that work and done everything that...
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled or third party cartridges that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Feb 19, 2010 | HP Photosmart C5280 InkJet Printer
How to change toner
hi friend,
How to Change a Toner Cartridge You may need to change a toner cartridge when:
  • Your printer tells you toner is out (low toner usually means you can print a few hundred more pages without a problem)
  • The pages coming out of the printer look faded or washed out
  • The pages have a repeating defect of some kind
Users are able to and expected to be able to change toner in black and white printers. (Color printers are more difficult so if you are unsure of how to change color toner call the helpdesk and we will assist you.)
  1. First thing you will need to know is what model of printer you have.
    This will be written on the printer somewhere, there are 2 names that you will likely find on the printer, one is our name for the printer (i.e. ucrit01) the other is the model name (i.e. HP LaserJet 5m). You will need the model name.
  2. Take the model name to the central stores.
    They will be able to tell you which replacement toner cartridge to use. (If there is a problem identifying which replacement to use call the helpdesk.)
  3. Give them your cost center number and they will let you have the replacement toner cartridge that you need.
  4. Take the new cartridge back to the printer and remove the new toner cartridge from the box.
  5. Power the printer off.
  6. Open the top cover on the printer.
  7. Remove the old toner by pulling up and away from the printer. (It should come out with only a small amount of force)
  8. Remove the new toner from its bag, remove the rip strip from the cartridge. This is a small tab on the side of the cartridge that is attached to a plastic film strip. If you do not remove this strip the printer will only print blank sheets. Take care to avoid getting the toner on you when you rip off the strip. Spilled toner is best cleaned up with a dry cloth. If you spill any toner on yourself you can wash it off with COLD water (no hot water as it can cause the toner to set).
  9. Place the new cartridge into the printer the same way the old unit came out (there may be arrows or other cues to help you align the cartridge correctly.)
    It should slide in with minimal force. If it does not slide in easily, make sure you have the cartridge aligned correctly and that you are using the correct cartridge (i.e. 4000 series cartridge is not compatible with the 4100 series printer, you must use 4100 series cartridge).
  10. Once you have the cartridge seated all they way in place, close the top cover.
  11. Power the printer back on.
  12. Print a few test pages
    • If the printouts look good:
      You are just about done, package the old toner cartridge in the box the new toner came in and give it to the mailroom. We get a credit for the old cartridges. Now you are finished.
    • If there is a problem with the test pages:
      Our cartridges are refurbished and sometimes the cartridges can be defective. If you see streaks, repeated defects, faded out pages or other defects that did not exist before you changed, toner it may be because of a problem with the toner cartridge.
      Try getting another new cartridge, installing that cartridge, and printing some test pages. If the printouts are clean, then the first cartridge is a defect, return it to the mailroom for credit.
      If both new toner cartridges seem to have problems call the computer helpdesk. There is likely something wrong with the printer.
Please Note: Toner cartridges are light sensitive if you are going to leave them out of the box or printer for more than a few minutes please cover them to prevent damage
hope this helps u
please rate me........................
thank u for using fixya
Nov 24, 2009 | Samsung ML 1610 Laser Printer
IBM Infoprint1120 and Lexmark T520 toner cartridges.
You cannot use Lexmark toner cartridges in IBM models and vice-versa because the toner carts have a smartchip that identifies the toner to the printer. IBM printers expect to see IBM toners and Lexmark machines expect to see Lexmark toners. If you put the wrong cartridge in you will get '32' Unsupported print cartridge error.
Some refillers may swap the smartchip when they refill cartridges and this would be the only reason why you may have seen it done before.. IS your current toner a refilled one? It's technically possible to make an IBM printer into a Lexmark printer to accept Lexmark toners by replacing the System Board... but why would you bother doing that...just use the right toner.
May 19, 2009 | IBM Infoprint 1120 Laser Printer
Question about mc 2350 cartridge
I just got done replacing my toner.  You'll need to change toner and most likely all of them. There is no other solution.  I refill mine by buying the bottle toners.  It can be messy and you'll need to take some parts off the cartridge to get to the opening plug and reset the lever so that the printer knows the cartridge is full.  It is cheaper than buying a toner. The cartridge has a life of about three refills.  Anyway hope this answers your problem.
Aug 07, 2008 | Minolta magicolor 2350 Laser Printer
50 people viewed this question
