Dell xp wont connect to the internet thru this router.
Hi,Using inspiron 9300 with XP, trying to connect to the internet using att gateway router. letting windows manage connection, correct network key, using wpa2. All worked fine in my apt in nyc but when i came down south to my sisters house laptop wont connect to router...any suggestions...Thanks
    Sergeant:
  • 322 Answers
I think that the settings in your sister laptop is the problem. See if it is using static ip ad and if it is using it, try to use dynamic to get an ip to the router.
Posted on May 05, 2009
No internet connectivity after upgrade firmware
1,there is a reset button
2,press this using any pin with power
3,automatically restart
4,connect your router with pc
5,type 192.168.1.1 on the browser
username:admin
password:admin12 or admin
configure router
enable dhcp
Oct 29, 2009 | D-Link DSL-G604T Wireless Router
Dell Inspiron 1525 not connecting wirelessly to Sky broadband
If your wireless router is configured with SSID, encryption, MAC address filtering (if enabled) etc. then the Dell wireless card needs to be configured with these settings to allow it to communicate with the wireless router.
Check the settings on your PC's wireless settings, and configure the Dell the same way.
Sep 08, 2009 | Dell Inspiron 1501 Notebook
I use a home network set up using a Linksys Wireless-G WRT54G router. I just had to reinstall Windows XP home edition on a Dell Inspiron 9300 computer. In hardware manager, the computer lists the Dell and...
Make sure you have fresh ip address...
go to command screen: ipconfig /renew
If this doenst work you can static the IP of the Wireless NIC. Make sure the IP you use is on the subnet of the router.
http://ask-leo.com/how_do_i_configure_my_static_ip_address.html
Jun 22, 2009 | Linksys Wireless-G WRT54G Router
Windows XP Network Connection HELP!
You need to call ComCast and have them walk you through the Internet Connection Wizard. It is rather easy, but it requires some specific information that they'll have.
Jun 16, 2009 | Dell Inspiron 1521 Laptop
SPEEDTEST.NET RESULTS VERY POOR AND VARIABLE THRU ROUTER
First what type use router and you using internet firewall ya VPN
plz tell me
Mar 14, 2009 | Dynex 4-Port Ethernet Broadband Router
Windows xp wont connect to internet
Please check you LAN settings on your router (DNS) - usually it is 0.0.0.0 (assigned by provider)
Make sure your PC is using DHCP (TCP/IP properties -> Obtain IP Address Automatically & Obtain DNS server address automatically). Try "ipconfig /all" at others computers and compare with your PC (look at gateway & DNS). See if you can ping gateway and then outside address.
p.s. To access your router open Internet Explorer and enter http://192.168.0.1/
If it is not working, check the default gateway address on working computer and use it instead.
Feb 10, 2009 | D-Link AirPlus DI-524 Wireless Router
Dell Truemobile 2300 - cannot connect to internet
This is usually a router configuration issue. The router has to be configured to match your new broadband settings.
For example, your old DSL may have required some kind of login which was entered into the router. For most broadband cable connections, you set the router to get an IP address automatically.
Re-run the router Setup Wizard. You can download it here:
http://ftp.us.dell.com/network/R74885.EXE
Jan 26, 2009 | Dell TrueMobile 2300 Router (000001)
Can not connect to internet using wireless
Did you input the WEP key? I will assume you are using Windows XP. So go to control panel, network connections and then go to the wireless connection and then select view wireless connections double click on the one with the highest strength, which should be your 2wire. When it asks for the network security key type in the numbers that are located on the sticker on the bottom of your router between the [########] brackets.
Jan 16, 2009 | Dell Inspiron 1200 Notebook
Cannot connect to the internet
open internet explorer, go to tools, internet options, then the connections tab and make sure ' never dial a connection' is ticked, assuming you had a dial up connection before using the router on this pc or if you briefly used it.
Aug 18, 2008 | Dell Wireless 2350 Router
Internet sharing
Hi, Could be done. On the Dell XP - 1. Activate your Internet Connection Sharing. Go to Control Panel, Click on Network Connections, right click on your Local Area Connection, Properties, Advanced tab, check Allow other network users to connect through this computer's internet connection. In Home networking connection, choose "Local Area Connection", OK; 2. Back to General settings, click on Internet Protocol (TCP/IP), click on Properties, tick Use the following IP address: IP address 192.168.0.1, Subnet mask 255.255.255.0, Default gateway 192.168.0.1, if you know ITT DNS use them otherwise tick "Obtain DNS server address automatically." You have to connect the DellXP with the DellVista using a crossover networking cable. On the Dell Vista- 1. In your Network Connections, right click on your Local Area Connection, Properties, click on Internet Protocol (TCP/IP), click on Properties, tick Use the following IP address: IP address 192.168.0.2, Subnet mask 255.255.255.0, Default gateway 192.168.0.1, if you know ITT DNS use them otherwise tick "Obtain DNS server address automatically." The above method will also work with peer to peer wireless networking. It might also facilitate connection if you enable auto-detect proxy settings in your browser. There are other methods. This is also better explained at Microsoft support Hope this be of help/idea. Post back how things turns up or should you need additional information. Good luck and kind regards.
Sep 30, 2007 | Computers & Internet
Computers & Internet Logo
201 people viewed this question
David Payne
David Payne
