Question about Kodak EasyShare DX7630 Digital Camera
HIGH CAMERA TEMPERATURE warning
Camera turns off immediately and won't run. I did not go thru an xray machine like others have here. There is no reason behind this happening to my camera.
    Genius:
  • 2,985 Answers
As stated X Ray machines should not affect camera or images. Best to check this out with Kodak I am not aware of any other camera to have this sort of warning.
Posted on Sep 12, 2007
  • finesilver Jan 01, 2011
    this worked for me: just hit the bottom hard with your palm and the top and sides, not the front or back. After 3 hits, the date screen came back on and it was fixed. This was after the other two solutions I found on this site failed, namely pushing the shutter down before the message comes on or blowing into the camera slot with the memory card removed.
SOURCE:
Battery Temperature High message and camera shuts down
I would call Nikon and explain the problem. Get a name and Email address and send a nice Email confirming what they told you on the phone. Most companies are very willing to repair battery problems for free because of liability issues.
Nov 17, 2013 | Nikon Coolpix P510 16.1-Megapixel Digital...
Batteries in camera get hot
have you tried other batterys
Aug 20, 2012 | Cameras
When I try to upload pictures onto my Apple, my camera flashes with red and green lights and says BATTERY TEMPERATURE HIGH and won't upload.
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
Aug 12, 2012 | Nikon Coolpix S4000 Silver Digital Camera...
Battery temperature high...what do I do?
Apparently, the manual says the battery may get hot during use. If the "battery temperature high" warning comes on, you're supposed to turn it off for 5 minutes.
Nov 10, 2011 | Nikon COOLPIX S570 Digital Camera
I dropped my canon powershot SD 4500 IS and now it won't turn on! It's survived countless other falls just fine, and would turn on immediately then. All times, including this time, have been when...
Really!....you've dropped your camera "countless" other times and now you're concerned because this time, it won't turn on!!! You're not sure what else to do?!!! How about not dropping your camera. How about using the wrist strap. Your dropping luck has run out...your camera does not have nine lives.
Aug 23, 2011 | Canon PowerShot SD4500 IS/IXUS 1000 HS...
When i turn on my camera it says battery temperature high, and wont let me use my camera. What do I do?
To clear your warning message
  • Battery Temperature High
  • 1 Press the "Power" button on the camera to turn it off. If the flash is blinking, the camera will turn off automatically after 30 seconds.
  • 2 Set the camera aside and wait for at least half an hour for the battery to cool. If you have a spare battery, take the old battery out and insert the new one.
  • 3 Press the "Power" button to turn the camera back on.
Jun 01, 2011 | Nikon Coolpix S3000 Digital Camera
Fuji instax mini 25 film can go through x ray?
X-rays can fog many types of film. If you are flying you can declare that you have film, and have them manually inspect it rather than sending it through the x-ray machine.
Mar 02, 2011 | FUJIFILM Instax 200 Instant Film Camera +...
Z710..after a short time..warning says ''high camara temperature'' and shuts down
That means that your camera will shut down immediately so it doesn't burn out. Are you in an environment where outside temps are super hot, or leaving the camera in the sun or vehicle too long?
It can also happen if the camera is subjected to different dramatic temperature changes, like taking pics in central air conditioning and then go outside in the extreme heat.
Oct 24, 2009 | Kodak EasyShare Z710 Digital Camera
Kodak easyshare DX7630
X Ray machine would not harm the device. What Hi temp means I do not know- discuss it with the Kodak Support site.
Jun 21, 2007 | Kodak EasyShare DX7630 Digital Camera
"High camera temperature"
If there is a memory card inside the cad slot, take it out first. Open the camera. When the "high temperature camera" error appears, after it goes off, "BLOW AIR INTO THE CARD SLOT BESIDE THE CAMERA SEVERAL TIMES. I have blown air manually by my mouth. Then you can put back the memory card back or you can just simply Turn-ON sa camera. See if it work. It works fine for my CX7530 (i got this idea thru trial & error). Stupid kodak service center won't help, they just want to service my camera for almost half the price that i bought mine, & even suggested that i  should buy a new one.
I hope this works for you. ----kodak camera user from the Philippines.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Kodak EasyShare DX7630 Digital Camera Logo
157 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
