Question about Razor E100 Electric Scooter
Electric scooter e100--when we charge it the red lights shows for about 5 min then right away the greenlight (charged)shows,,an doesnt hold the charge at all---does this mean the battery is toast ?
  • Anonymous Apr 30, 2009
    I charged my scooter for 12 hors and it turns on with red light but when i went out to use it it didn't work.
  • Gotti445 May 08, 2009
    Previously, when plugged in both the red and green lights would illuminate. Now, only the green illuminates when plugged in and despite pushing the 'reset' button near the port receiver on the scooter itself it doesn't light up anymore. Additionally, the scooter no longer works as apparently it's not charging.
    It's clear the charger is cheaply made as the writing under the red/green lights on it are only in Japanese, so I had no idea what either light even indicated. Also, the wires have been pulling away from the metal plug that you insert into the scooter since it was pulled out of the box. The wires are completely connected so this isn't the problem, but this was said to illustrate just how cheaply this was made.
    At this point I'm not sure if I need a new battery, charger, connection port, or any combination of the aforementioned. Naturally, there is really no place to take it to be repair or inspected to diagnose issue, and good luck getting the people at Razor to respond.
    Anyone with similar experience that has a remedy feel free to hit me up at gotti445@comcast.net
    Thanks.
  • 3 Answers
I HAVE THE SOLUTION!! No, it's not what you're going to want to hear, but I have it nonetheless. The cheapest and easiest way you're going to fix this issue is by firmly grabbing the scooter, hoisting it directly upwards, clearing the rim and depositing it into your nearest refuse container. This is junk at its finest, brought to you from the worst in value and service, the Razor Company.
I did a little investigation into this problem as I too experienced what everyone that owns a Razor scooter does; it works for about two months, then suddenly the "battery stops holding a charge". You can Google Razor scooter issues and get page after page of this happening, along with more pages of frustrated people learning Razor won't do anything about it. But I digress.. back to the facts..
I need not repeat what I've already posted with regard to the issues surrounding my scooter, purchased Dec. '08 as a Christmas gift and not ridden (midwest snow) until the last month or two tops. So as I posted previously, it stops working and I'm assuming it's the batteries. I call my local Batteries Plus store and they say they can help. Here's where it gets interesting.
I bring in the entire scooter and charger. Let me say that I found the charger included in with my scooter.. "interesting?".. as directly underneath the red/green lights there are Chinese characters instead of English words, thus I never had any idea what these lights indicated. That notwithstanding, the test the charger on the spot and tell me it's working and is (pay attention here) 41 volts of charge. This means nothing to me at the time. I learn that testing the batteries in the scooter will take a couple days and they say they'll call with the results.
Before leaving, one of the CSR's engages me in a conversation about his identical experience with the Razor scooter he got for his kids one year prior. The circumstances mirrored everyone elses: it worked for 2 months, stopped working, he checks the batteries, replaces them, still doesn't work, he pitches it. Hearing this isn't making me feel any better.
So the weekend passes and here on Monday I get the call from Steve at Batteries Plus. Here's what he finds: There are 2 batteries in the scooter; one is at 60% of its life (this after a mere month of use) and the other is overcharged and 'swollen'. How can this be I wonder? I followed the charging instructions provided with my scooter TO THE LETTER, never leaving it charged for an extended period, etc. Well the answer is simple- the batteries for this scooter are 24 VOLT BATTERIES being charged by a charger that is outputting 41 VOLTS!! ALMOST DOUBLE THE VOLTAGE! It's overcharging the batteries and frying them out.
Steve said he removed and replaced the batteries with 2 brand new fully charged 24 volt batteries and it still didn't work. He surmised the switch that activates the motor, which is run through the charging system, was fried during its last overcharging.
Ergo, the charger included with these scooters is frying the scooters out in a very short period of time. To replace the charger, both batteries, and the switch would be more expensive than just pitching it and buying another brand new one.
This issie is Razor's fault and they should be willing to fix the issues (cue laugh track here). Go to their site and be ready to laugh at yourself for even bothering. Here's what I found. First I click the 'service/repair' tab, then am directed to the 'Razor Service Center Locater' to find the nearest service center to me to have it repaired. I entered my zip code and it said 'Sorry, no results found'. I then try my city/state, and again get 'Sorry, no results found'. Not looking good.
I then begin reading their return policy. It has a warranty that's good for 90 days from the DATE OF PURCHASE. Naturally, in my case I bought it in Dec. but since there was snow on the ground it was useless until spring; I was screwed before it even was given it's first charge. However, for the regular customer they'll find that even so, it's right at about the 2nd/3rd month when this thing takes it's final ride and as such, and through no fault of your own, your're totally screwed.
There are enough complaints on this scooter on the web that at minimum contacting the BBB is in order, and might I suggest a potential class-action lawsuit? This scooter retails still at $149, and like most of you I don't have $149 to throw in the trash every couple of months only to go and repurchase another "disposable" scooter.
So there it is. Not only are the batteries being overcharged and shot, but collateral damage to the electrical system is being done which is frying the switch that engages the motor and other things. Have your charger checked at your local Battery Plus (no charge) and you'll see they are putting out a defective product, and based on several hits on the internet they are clearly aware of it and do not care.
Posted on May 11, 2009
SOURCE:
Batterys showing full charge but when my daughter gets on in power kicks in then stops
razor hasnt been charged for a week as i needed a new charger i had 1 scooter charging over night yet still nothing , i bought a new charger its showing green on the light do i have to wait till it shows red and then wot if it doesnt still work
Dec 17, 2013 | Razor E100 Electric Scooter
How long does it take to charge Razor E100 Electric Scooter - Red
You threw away a perfect scooter you idi0t. Needed to desulfate battery with a smart charger. M0ron.
Sep 14, 2012 | Razor E100 Electric Scooter
My charger light shows always green and it does not charge the scooter.
Usually that means the battery is not able to hold a charge.
Jul 29, 2012 | Razor E100 Electric Scooter
The scooter wont start
Take it back and get an exchange one. Or, manualy check fuse, check wires conected to throtle and motor. If it all looks ok then its most certainly a wiring fault
Nov 25, 2011 | Razor E100 Electric Scooter
Have an e100 razor electric scooter. it has not been used for a couple of years. I got a new e100 charger and tried to charge but i noticed that the green light stays on and the red light charging does not...
The batteries are dead. The battery in these scooter need to be kept charged or if not in use for a long time charged every 3months. Otherwise, like what to you, they will go dead. The chemicals in the battery have deteriorated to the point where it won't hold a charge. Replacement batteies are available at:
razor.com
Jul 20, 2010 | Razor E100 Electric Scooter
When i try to drive my E100 scooter it doesnt go but when i press on the light turns on and i checked the wires its all there any help please???
have you tried to push the scooter like a normal non-electric scooter then while moving twisting the throttle? If not, then i dont know what to tell you except to get a new one.
May 01, 2010 | Razor E100 Electric Scooter by
On the charger it will go red green red green forever and i halve to charge it a week to go ten minuits
hi my son has not used the scooter for a while so i went to charge it and the green light comes on the charger straight away and the scooter is not working can you tell me what the problem is?
Mar 13, 2010 | Razor E100 Electric Scooter
Charges and light comes and sounds like it engages but does not move
in order for the scooter to go you must already be walking with the scooter. so hold down the throttle and start to push (kick) the scooter.
Jan 31, 2010 | Razor E100 Electric Scooters Red
Razor E100 Electric Scooter Logo
1,883 people viewed this question
Top Razor Toys Experts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
William Erickson
Are you a Razor Toy Expert? Answer questions, earn points and help others
