Question about Mtd 46" Dozer Blade, Fits All & Yard - Man Lawn & Garden
46" mtd 25hp riding mower. Idoling ruff...
When i crank the mower it runs but rpm goes up and down. Constantly. When I engage the blades it gets really bad. I have drained the gas and changed the filter. What else can I do to fix this??????
  • 33 Answers
I had a similar problem on my 42" MTD riding mower, the vent in the gas cap was plugged up. Replaced the gas tank cap and it fixed it (Lowes sells them)
Posted on Dec 30, 2009
On this engine, another problem that can cause surging is a simple "O" ring that is located under the float in the carburetor bowl. This O ring is included in the carb rebuild kits but you can probably replace it at your local hardware store. The easiest way to access it is to remove the four bolts holding the plastic intake manifold onto the block, and then remove the entire unit. Turn the unit over and remove the two screws that hold the bowl on. Between the plastic fitting in the bottom of the bowl and the center column that fits into it, is where the O ring is located. It is about a half inch in diameter. If you are going to just replace the O ring, you should be able to determine the proper one by taking the plastic fitting with you to the store. The O ring being replaced will likely be very distorted and not useable for a size sample.
Posted on Oct 27, 2016
    Scholar:
  • 61 Answers
It sounds as if you have a carburetor problem. When you drained the fuel out of it did you happen to notice if there was any contamination within it? You might try draining the fuel out of the carburetor, alot of carbs. will have a drain plug on the base of the carburetor which can be usually found(providing it is so equipped) near the bottom closest to the mounting bolts. By loosening what is normally a short hex sized plug you'll allow any fuel in the carburetors bowl to drain out. This plug varies in size but normally is about 1/2" in size.Although this method is not always 100% effective you might want to attempt to catch what you drain out if you should see water in it and by draining it this method doesn't cure it , then your probably going to have to disassemble the carburetor one of the passages is partially plugged.
Posted on Dec 05, 2012
How to replace the cable that engages blade on an MTD 42" cut riding mower
Utube or ur library...has shop manuals. Do it slow n safe...dont endup the er
Sep 12, 2015 | Mtd Garden
I have a 46" Yard Man riding mower with 20 hp BS.
Hello, Ask your local Mower shop if they show a Thermal switch for the PTO. You may have to replace it or move it away from the heat.
Aug 14, 2011 | Mtd 46" Dozer Blade, Fits All & Yard -...
I need a belt diagram for a ranch king king plus also i need to know the size for the main drive belt
Ranch King is a brand name of the manufacturer MTD.
Product manuals with part blow-up diagrams are available from MTD's web site,
http://www.mtdproducts.com/
Models are identified from the model number printed on a label under the mower seat.
The PTO and deck drive belts are shown on one diagram and the transmission drive belt is shown on another. The Form number on my printed Operator's Manual is 770-10526A (22HP, 46in cut) for Hydrostatic 817/818 models.
Parts can be ordered directly from MTD or other distributors on the web.
It is my experience that original brand name MTD belts work best.
The 22HP, 46" mower deck Ranch King Pro has 3 belts:
The drive belt which runs from the engine pulley back to the hydro drive unit to provide over-the-ground propulsion is part #754-0349.
A mower has either an electric PTO or a manual PTO, not both.
The electric PTO belt the provides power to the blade deck (runs around the electric clutch on the engine shaft (activated by electric switch, not the mechanical hand lever that engages the mower deck) is p/n 754-0476 for the 46" deck.
The manual PTO belt the provides power to the blade deck (runs off the pulley on the engine shaft (activated the mechanical hand lever to the left of the steering wheel that engages the mower deck) is p/n 754-0228 for the 46" deck.
The deck belt that goes around the 3 blade spindle assemblies on the mower deck, to drive the grass cutting blades is p/n 754-0349
In my experience, the PTO belt lasts about half a season, the other belts break about every other season when mowing 4 acres weekly.
Sep 07, 2009 | Mtd Garden
Mtd yard bug model - 198707 riding lawn mower blade belt size?
I dont know the belt size but if you go to mtd belts in Jackssmallengines.com you should find it. Stephen.
Aug 23, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
John deere mower won't engage
on the engine there is a shaft with 2 pullys ,drive belt goes to the top closet to the engine lower pully is for the deck
there also is a saftey switch located on the deck which should shut down blade operation when raised. check the mandrels for broken bearings by grabbing the pully and wiggle them back and forth looking for movement could be possible that one madrel is shot giving you that bad sound which is crushed bearings
Jun 30, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Blades won't engage
I have a john deere 185 was mowing and my blades Quit turning with the switch still on,any quick fix?
May 16, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
My Yard Machines MTD blade won't engage. The belt that spins blade is loose when I try to engage deck.
My mtd 20 hp mower, blade will not engage, found a large spring and a small metal piece that came off and I have no Idea where it goes in order to get this blade going again, can some one give me some info Please..
Apr 19, 2009 | Garden
Mtd 46" Dozer Blade, Fits All  & Yard - Man Lawn & Garden Logo
431 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
