Question about Hitachi 43FDX01B TV
Remote will not change the volume
I moved the TV and the volume control on the remote does not work. The remote will turn the power on/off and change channels up (but not down), access the menu functions and the thumb button in the middle works fine. How can I get the volume button on the remote to work again? Thanks.
  • 153 Answers
Is the front funtion button works in the TV the it could be a bad remote controller(the button switch inside) :)
Posted on Apr 14, 2009
Sansui platinum plus tv
Are you using a remote control or the switches on the TV?
If using a remote;
First turn the TV off at the power point then wait for 10 seconds.
Then turn the TV back on
Then attempt top adjust the volume using the manual settings on the side or bottom of your TV, if that works then you may have a remote that either needs new batteries or does not work.?
Can you turn the TV on and Off with the remote control?
Can you change channels with the remote control?
If you can do both the above it would appear that the remote is working OK.
Does this fix the problem?
Jun 30, 2014 | Televison & Video
Sanyo DS31590 no remotes will work, will not turn on power or volume but changes channels
If you can control the TV by using its front panel controls, and only remote control is not working, the fault may be either to its remote control handset or to the remote sensor inside. The remote sensor is a small component, having only three solder terminals and will look like this. 7_12_2012_12_53_47_pm.jpg7_12_2012_12_54_01_pm.jpg
This is the component inside the TV which senses the infrared rays emitted by the remote control, and convert it to digital signals, and send to the microcomputer section circuit to process. This component can be located just behind the infrared remote window at the front panel of the TV. You have to open the TV to access it, and to replace it. Just check your remote for its infrared emission, before going further. Just get more details about how to check a remote control from this site named 'Electro-help'. Pull up older posts there. Just check this link, and locate the site named above.
Jul 12, 2012 | Sanyo DS25390 TV
Volume and mute buttons are not working
Do you have fresh batteries in the remote? You did not provide your TV brand so I can't provide you the codes for your specific TV. Below I have provided instructions on how to perform a power scan. If this doesn't work, you may need a new remote.
  • Remote: Basic Remote (Television Only)
    1. Turn the Television On.
    2. Press and hold the clear TV button for three seconds until the LED flashes.
    3. Press and release the redTV Power button.
    4. Press and release the Up or Down Arrow on the remote until the television turns off.
    5. After the television turns off, press and release the # button.
    6. Test functionality with the TV.
    7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Aug 17, 2011 | DISH Network IR Remote Control
Direct TV remote quits working - conflict with Samsung LCD?
Turned power saving feature on the TV to low and moved the receiver about four feet away from the TV and the remotes work fine now.
Sep 03, 2009 | Samsung TV Remote Control
Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
Feb 15, 2009 | Samsung LW20M21C 20 in. LCD Television
The volume control won't work on my sky remote
for a toshiba tv,
press tv
type in 0 1 5 6
press the power button on the remote
If the tv turns off press select and hey presto you're done, if the tv doesn't turn off, press tv then press the power button and keep doing this until the tv turns off. When the tv turns off press select.
Nov 17, 2008 | Universal Remote Control Remote Control
Lost the manual. Can't re-program remote control. Need step-by-step
http://www.rca.com/documents/15128800_201059_25.pdf Hope this helps :)
Apr 08, 2007 | Proscan PS35660 TV
Hitachi 43FDX01B TV Logo
195 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
