Question about Vacuums
My Bissell Dirtlifter Powerbrush carpet cleaner will not roll. The back wheels roll fine, but when you put the machine down flat, the front part (where the roller is) sticks and will not roll.
  • 4 Answers
I had the same problem. It would pull backwards but not go forward. A closer examination revealed the clear plastic part on the bottom in the very front of the machine had popped loose on one side.
If you look at the front of the machine, there is the clear plastic part on top where you see the dirty water being sucked up. The bottom half that creates the channel for the vacuum is where it came loose. It wouldn't create enough suction to draw the water up either. By taking out the two screws that hold the top part in place and removing it, I was able to snap the bottom back in. Works fine now. Hope this helps.
Posted on May 15, 2009
  • glendajk Sep 17, 2010
    Oh THANK YOU so much for sharing! I have been "troubled" with this for over an hour, checked the belts, cleaned it, was about to give up, then I read your solution!! THANK YOU., I didn't even see the second piece of plastic there, wearing my glasses 100% now, sweating or not! thank you again!!
Can i use this machine to do laminate floors
no not recomendid it will scratch all the laminate
Feb 06, 2013 | Unknown Bissell 2080-3 Bissell...
Looking for cleaning instructions for bissell little green machine
BISSELL User's Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User's Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Oct 07, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Do you have manuals for a Bissell carpet machine model 1640-6? This machine is about 25 years old. I forgot how to set up soap dispenser
Model 1631 is a faucet hook up unit similar to the 1640-6. 1631 User's Guide is on the BISSELL website and should be a similar set up to the 1640-6.
May 01, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
I need instructions on how to use my machine. Can you please help!
if its a bissell,go to bissel .com and request a manual sent to you.there should b a cartridge that you push a button to unlock so u can fill it with water or carpet shampoo.I fill mine half water half carpet shampoo. then u put it back on ,make sure it either clicks or snaps on.plug in and turn on,they usually have a button that turns that say wash or rinse.it depends on your machine.
Jan 19, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
How do you prepare the driftlifter powerbrush for operation? What kind of cleaner should I use? How do I put it in the machine?
Don't use the Bissell, Hoover or Dirt devil cleaner products in your machine. They are a petrolium based and will eventually gum up the machine. Use an alcohol based product put out by Riccar. It dries faster and won't leave a sticky residue in your carpet.
Nov 26, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
I need instructions for the Bissell Big Green powerbrush
I recently did a Google search an owners manual for my inlaw's Bissell. I just googled your 168-3 and found a manual, hope it is the right one,
Apr 09, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
My bissell powerbrush won't **** up the water
had same problem - carpet soaked with dirty water and very little, if any, cleaning fluid used. Easily remedied. Removed water resevoir and found that the rectangular shaped washer at the top of the front cover (the bit you had unscrewed to give a good clean) had become dislodged. It has small lugs on either size which lock on to the plastic opening when pushed down firmly. Resevoir then sits on top and makes full connection, also ensure that grey locking handle is fully pushed down.
Seemed to me that the water wasn't being sucked up as there was air getting in and this has down the trick. Sorry if this is difficult to follow but all will become clear when you look for the black washer! Good luck
Mar 18, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
How to change the belt on a bissell powerbrush deep carpet cleaner.model 1694
Turn the machine OFF (O) and unplug from
the outlet. To check if the brush belt or
pump belt has broken, you will need a flat
head screwdriver. Insert the blade end into
the lower slot of the belt access door to
release the lower snap. If necessary, insert
the blade end into the upper slot to release
the upper snap.
Hope this helps.
Richard
Mar 10, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
The dirtlifter powerbrush do not trun.the belt are ok and i unplug it and trun it back . still not working
I have a Bissell Dirtlifter Powerbrush that will not spray soap. I assume the soap lines are clogged, but how in the heck to you "unclog" them? I've searched high and low on the Internet looking for that answer.......
Apr 20, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Vacuums Logo
478 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
