Every once in a while my key pad first letter row Q thru P and second letter row keys a thru L will not operate. When the letter q is pushed qa will come up on the screen and when you push the a key qa comes up.Other times the key pad is fine. Is there a keypad test?
  • NitrusInc
    NitrusInc May 11, 2010
    Is this a Dell Desktop or Laptop?
    If it is a laptop the Dell Diagnostic CD in extended mode should detect any issues. Re-seating the keyboard cable is relatively easy and could be the issue.
    If it is a desktop keyboard, generally if the keyboard is well connected, its either a bad port or a bad keyboard.
    As far as a keypad test, I would search on Downloads.com or etc. , but have not heard of such a thing (sans the Dell Diag.)
    Good luck
  • 385 Answers
Keyboard errors are Locale setting errors.
check your regional languages in control panel,
are set to english at the top, and save it.
Should be good if hardware ok
Regards
Richard.
Posted on Apr 22, 2009
I can't correct my password and get into my computer--
keyboard layout is as follows.
TOP ROW: QWERTYUIOP
MIDDLE ROW: ASDFGHJKL
BOTTOM ROW:ZXCVBNM
If you're saying you just can't see the keyboard keys, that should help. If it doesn't, I suggest getting a hold of a USB keyboard other than the malfunctioning one you have now.
May 13, 2014 | Acer Computers & Internet
Where is the number lock on this keyboard?
As with most laptops there is no number lock key. you dont have the number pad like most desktop keyboards. you have a (fn) key this works for all the keys that have a square around them it may be blue/white/purple, and is located on the bottom left should be the second key on the bottom left row right next to the ctrl key. but once again there is no number lock key.
Feb 21, 2011 | Dell Inspiron 1545 Notebook
Some keys register different characters. For example the O registers the number 6 when it is typed.
This should be a simple fix, look at your keyboard, you should have a function key and if you look at the number pads above the top row of letters there should be either a numerical symbol or a key pad, your keyb board is simply using several keys as an extended numerical keypad. If you look closely at the letters there are small numbers on them. To fix hold down function key and pressing the keypad button. You can also try pressing the number lock.
Al
Aug 04, 2010 | Sony VAIO Notebook
Keyboard double letters showing
there is short in the data cable
may be some liquids spill inside it
you have to clean it and if this fail may the keyboard controller on the mother board is corrupted then you have to use external K.B or change the Mother Board
shadi
dont forget to rate my solution
Jan 24, 2010 | Dell 0Y3740 Keyboard
When entering degrees minutes and seconds (as per lat and long) into Turbocad .. what is the symbol you use for degrees?
Hey there, this is easy. HOLD the ALT key down and with the ALT key held down type 0176 on the number pad. DO NOT use the numbers on the top row of your keyboard, it must be on the numeric pad.
seth
Jun 25, 2009 | IMSI TurboCAD Pro 15 Full Version for PC
Keyboard letters press a and get qa press 2 get W2 and so on
Last time that happened to me there was something jammed between the Q and the A key or something stuck under the keys.
Jun 01, 2009 | Dell XPS M1530 Laptop
Fn key wont turn off
OK, I've found a soliution! :) I've been diging the internet and many people are having the same problem, so it is a common problem however the soliution is very simple (in my case). The thing is that laptops does not has a saparated Num Pad, and numbers can be found on keys under F1-F12 row or/and (active with Fn key) on alphabetic keys uiopjkl;m/ and so on. But if there is a NumLk key on your keyboard, you can lock the Num Pad on alphabetic keys. Then you have to hold Fn key pressed to write letters.  Find the NumLk key and try to turn off the Num Pad :)
On my laptop (Acer extensa 5120) NumLk key is on F11 and active when Fn is depressed.
Hope this wil help :)
Oct 01, 2008 | Acer Aspire 5100 Notebook
Changing display
After you hit the key, hit the 0 (operator) key to change between characters.
Hope this helps!
Dec 11, 2007 | Toshiba DKT-2020 Corded Phone
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
