I need a remote control for an Emerson AV1055A system. Can you help me?
  • 416 Answers
SOURCE: I have a oneforall universal
You can download the manual and codes from
this website. Just chose the model of your remote and get the code
Good Luck
http://www.oneforall-na.com/advanced_search.php?action=dosearch
Posted on Dec 14, 2008
SOURCE: i need a remote code for a emerson lcd lc195em82
1. Manually turn on the component you want the remote to
control (TV, VCR, DVD, satellite receiver or cable box).
Note: If you press an invalid key during the Auto Code
Search, the remote does not respond and the illuminated
ON•OFF key does not blink. If you do not press a valid
Auto Code Search key (TV, VCR•DVD, SAT•CBL, ON•OFF,
GO BACK, PLAY, REVERSE, STOP), the search times out
after two minutes. When the search times out, the illuminated
ON•OFF key blinks four times and turns off. The last
programmed code under that component key is retained.
2. If you are programming your TV or satellite receiver, go
directly to step 4.
3. To program the remote to control a VCR or DVD. The
VCR•DVD key can control only one component, either your
VCR or your DVD. To program your remote to control
either your DVD or your VCR, you must first put the
remote in the proper programming mode. Follow these
directions before proceeding to step 4.
a. Press and hold the VCR•DVD key.
The illuminated ON•OFF key
turns on.
b.While holding down the
VCR•DVD key, press and release
the number 2 key on the keypad to
control a VCR or the number 3 key
to control a DVD. The illuminated
ON•OFF key blinks, and then turns
back on.
c.Release the VCR•DVD key.
blinks four times and then turns
off. Your remote is now either in
VCR or DVD Programming Mode,
depending on which you chose.
Proceed to step 4.
4. Press and hold the component key
(TV, VCR•DVD, SAT•CBL) you wish
to program. The illuminated ON•OFF
key turns on and remains on.
5. While holding the component key
down, press and hold the ON•OFF
key. The illuminated ON•OFF key
turns off.
6. After holding down both keys for
three seconds, the illuminated
ON•OFF key turns back on.
7. Release both keys. The illuminated
ON•OFF key remains on.
VCR•DVD
VCR•DVD
VCR•DVD
ON•OFF
(BLINK)
ON•OFF
(BLINK)
ON•OFF
ON•OFF
(BLINK)
SAT•CBL
VCR•DVD
TV
TIP: Throughout the programming of each key, be sure to
keep the remote pointed at the IR sensor of the component you
are currently programming the remote to control.
8. Press and release the PLAY key,
then wait five seconds to see if
your component turns off. If your
component does not respond,
continue to press the PLAY key
every five seconds until your
component turns off. Each time you
press the PLAY key, the illuminated
ON•OFF key blinks and a block of
10 codes are sent to your component.
This process continues until all of
the codes in the Code Lists have
been searched. (If your component
has not turned off after all codes have
been searched, the illuminated
turns off. The Auto Code Search
Entry method is exited.)
PLAY
ON•OFF
(BLINK)
10
11. To confirm that the component key is programmed with the
correct code for maximum functionality, test the component.
Attempt to control a variety of the component’s functions
with the remote. If some of the features of your components
do not work, try programming the remote with a different
code in the list until you find the code that allows the remote
to control the majority of your component’s functions.
Different codes can provide different levels of functionality.
Posted on Mar 26, 2009
  • 120 Answers
SOURCE: Need remote control code for Emerson EWC19t3
Here are some options:
01,03,04,23,32,34,35,77,81,83,84
Posted on Oct 13, 2009
SOURCE: need remote codes for emerson lc320em9 so can program cable remot
If you only wish to power the TV off/on with the remote, there is an alternative. Plug the TV into the outlet on the back of the Comcast box. In the Setup Menu for the Comcast box there is an option to make the outlet switched or unswitched. Select SWITCHED then the TV will turn on/off with the Comcast box. The
LC320em9 will maintain the previously selected input.
Posted on May 13, 2010
gopakumarg43
  • 74459 Answers
SOURCE: Emerson Universal Remote Control: need emerson remote control codes for philips TV
Try these codes. 0062 0204 0184 0208 0205 0206 0207 0004 0189 0183 0199 0200 0288 0456 0003 0008 0068 0075 0086 0087 0141
Posted on Jun 21, 2012
No remote for Emerson # LE320EM3,how do you turn tv on.Has no power button
Look just inside the rear with a mirror. Sony hides them there as well.
EMERSON Replacement Remote Control for LE320EM3 ... - Amazon.ca
https://www.amazon.ca/Replacement-LE320EM3-LC501EM3.../dp/B00FKH6ME6
  1. Cached
EMERSON Replacement Remote Control for LE320EM3, LC501EM3, NH301UD, LE190EM3, LE220EM3: Amazon.ca: Electronics.
EMERSON Replacement Remote Control for LE320EM3, LC501EM3 ...
https://www.amazon.com/Replacement-LE320EM3-LC501EM3.../B00FKH6ME6
  1. Cached
Find helpful customer reviews and review ratings for EMERSON Replacement Remote Control for LE320EM3, LC501EM3, NH301UD, LE190EM3, LE220EM3 ...
Amazon.com: Original New Remote Control / NH305UD: Home Audio ...
https://www.amazon.com/Original-New-Remote-Control-NH305UD/.../B015IFY96W
  1. Cached
Original Factory Remote - No need for programming it just works! Supports these EMERSON Models: LC391EM3, LE190EM3, LE220EM3, LC501EM3, ...
Emerson LE320EM3 LE260EM3 Remote Control and Manual ' eBay
www.ebay.com > ... > TV, Video & Audio Accessories > Remote Controls
  1. Cached
EMERSON LE320EM3 LE260EM3 REMOTE CONTROL AND MANUAL in Consumer Electronics, TV, Video & Home Audio, TV, Video & Audio Accessories ...
Remote Control for Emerson TV ' eBay
www.ebay.com/bhp/remote-control-for-emerson-tv
  1. Cached
  2. Similar
Original New Remote Control / NH305UD by Emerson. Supports these EMERSON Models: LC391EM3, LE190EM3, LE220EM3, LC501EM3, LE320EM3, ...
Emerson TV Remote Controls ' eBay
www.ebay.com > ... > Emerson TV Remote Controls
  1. Cached
www.newegg.com > ... > Audio / Video Accessories > Remote Support Inc
  1. Cached
  2. Similar
Buy EMERSON Replacement Remote Control for LE320EM3, LC501EM3, NH301UD, LE190EM3, LE220EM3 with fast shipping and top-rated customer service.
Redi-Remote EMERSON Replacement Remote Control for ... - Sears
www.sears.com/redi-remote-emerson...remote-control...le320em3/p-SPM925361391...
  1. Cached
Aug 23, 2015 - EMERSON Replacement Remote Control for LE320EM3, LC501EM3, NH301UD, LE190EM3, LE220EM3. Emerson TV Remote Control. Emerson LE320EM3 Google Search
Nov 24, 2016 | Emerson Televison & Video
Tip
Emerson Jumbo Remote Manual Download
Download Emerson Jumbo Universal Remote Control Manual
Have you misplaced your Emerson Jumbo Universal Remote Control Owners Manual?
Would you like a digital, searchable, pdf version of the Emerson Jumbo Universal Remote Control Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
on Apr 30, 2010 | Televison & Video
Tip
Emerson Jumbo Touch Remote Manual
Emerson Jumbo Touch Remote Control Manual
Have you misplaced your Emerson Jumbo Touch Remote Control Owners Manual?
Would you like a digital, searchable, pdf version of the Emerson Jumbo Touch Remote Control Users Guide?
I hope that helps.
What code will work on an Xfinity XR2 remote to pair to a 39" Emerson TV model # LF391EM4F?
Sam, Emerson universal remote codes, check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
https://customer.xfinity.com/help-and-support/xfinityremotecontrols
Comcast Remote Codes Program Your Remote Control
http://codesforuniversalremotes.com/universal-remote-control-codes-emerson-tvs
Aug 11, 2016 | Emerson Televison & Video
Need code list for Emerson TV
Kathlene, Check the attached links,instruction and guides Emerson TV codes, Good luck
https://www.remotecodelist.com/remotes/emerson/emerson.html
What is the remote code for an Emerson TV
4 digit codes for TV sets including LCD Plasma and Panel TVs GE universal...
Jun 08, 2016 | Emerson Televison & Video
NH305UD. How can I program it?
Universal Remote Control Codes - Emerson Instructions
Codes and links for a number of universal remote controls, including Sony, RCA, Memorex, Radio Shack, One For ... Emerson multi-brand remote codes for tv's.
Remote Control Codes For Emerson TVs ' Codes For ...
codesforuniversalremotes.com/universal-remote-control-codes-emerson-t...
2 & 4 Digit Universal Remote Control Codes For Emerson TVs Emerson multi-brand remote ... How to Program a Universal Remote Control : Universal RemoteProgramming of TV ... Can you give me the code for Western digital TV box please.
Emerson brand TV remote codes - Comcast Help and Support Forums
forums.xfinity.com/t5/XfinityTV-and.../Emerson...TV-remote.../784589
May 22, 2010 - I have a Emerson TV model # BLC320EM9 A and I cannot find a ...http://www.bing.com/shopping/logitech-harmony-300-universal-remote-control/p/7E7752820C88A8C05005?q=. ..... I can not get 11864 to work with the silver xfinity remote that has the ..... Code 11864 was not listed in the program guide.
Dec 25, 2015 | Emerson Televison & Video
We have a RCA remote and need the codes for an Emerson TV. Can you help?
The codes to program an RCA RCU300WBL remote control for an Emerson TV are:
Code 004 for Emerson TV Code 006 for Emerson TV Code 012 for Emerson TV Code 023 for Emerson TV Code 025 for Emerson TV Code 026 for Emerson TV Code 029 for Emerson TV Code 030 for Emerson TV Code 033 for Emerson TV Code 035 for Emerson TV Code 036 for Emerson TV Code 037 for Emerson TV Code 038 for Emerson TV Code 041 for Emerson TV Code 042 for Emerson TV Code 043 for Emerson TV Code 046 for Emerson TV Code 047 for Emerson TV Code 048 for Emerson TV Code 049 for Emerson TV Code 073 for Emerson TV Code 123 for Emerson TV Code 162 for Emerson TV Code 171 for Emerson TV Code 177 for Emerson TV Code 179 for Emerson TV Code 191 for Emerson TV
If you have a different RCA, remote control you can post more details, or take a look at the RCA Code Finder Website at:
http://remotefinder.rca.com/default.aspx?site=rca
Aug 08, 2009 | RCA RCU300WBL Remote Control
Code for emerson remote
I found this list for Jumbo Remote Control codes. Post back if they don't work for you.
http://www.jumboremotecontrol.com/remote_control_code_list.html
Dec 21, 2008 | Televison & Video
Code for Emerson DVD using Philips 435S rEMOTE
There are many codes for emerson. Instead of confusion I am giving you code manual for the remote control you have. I hope this will help you.
http://www.geocities.com/aviorix/pm435.pdf
Good Luck
Dec 29, 2007 | Philips 483521837121 Remote Control
123 people viewed this question
 Grubhead
Grubhead
