Question about Kenmore 44072 Front Load Washer
Torn gasket anyone had any luck repairing slighty torn door gasket on KENMORE he3 front loaders?
    President:
  • 1,294 Answers
Catriver(fixya) has a solution:
Remove the top, by removing the 3 screws in the rear. The top will slide off toward the back. Next remove the control panel. Remove the 2 screws on each end on top. Remove the detergent drawer. Remove the torq screws behind the detergent drawer. The control panel will now snap off, pulling from the top and lifting up. Once freed, remove the control panel ribbon cable from the side of the main board. Now remove the screws holding the door switch mechanism in place. Remove the spring that holds the outer part of the boot from the front panel. Now remove the 4 quarter inch screws that hold the front panel and door on the front. Now you can install the new boot with ease. I know it sounds like a lot, but it is not that bad. Just reverse the process when the boot is on the tub. Make sure to have the mark on the boot ^ lined up with the mark on the tub on top.
Posted on Apr 14, 2009
Check drain light keeps coming on how do I fix it
I'm not sure about your specific model, but in a Kenmore HE3 front loader, the lower front panel is removed, and it reveals the screw-on drain cover, which can clog up with debris. Also, on the lower part of the seal for the front loader door, you can pull it back a little to reveal a drain hole. I've found socks covering it before. It is most likely the drain in the lower section hidden by the lower front panel, though.
Bruce
Jun 09, 2014 | Miele W310 Front Load Washer
How do i replace kenmore washing machine latch
I'm assuming you are referring to the door latch assembly. The following link explains step-by-step how to replace the door latch on a Kemore Elite front loader:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
If you have any questions about this repair, please post back and let me know. I hope this helps you.
Nov 30, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Tub seal relacement method
The following link explains the step-by-step procedures for replacing the door bellow on a Kenmore Elite HE3:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
If you have any questions about this repair, or require additional assistance, please let me know. I hope this helps you.
Jul 16, 2009 | Kenmore 44072 Front Load Washer
Check Pump on front loader kenmore HE3 elite
Remove the lower front panel 3 screws across the bottom. Pump will be behind this panel.
May 26, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore HE3 front loader shows an error message of F02. It doesn't complete the rinse cycle as a result.
There is a trap on washer pump I just found to be full of the same **** you find in sink trapp. That is probably why I had same problem. could also be kinked hose or pump issue. The experts at fixya just walked me through it. best ten bucks i ever spent.
Good luck Scott
Apr 05, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
My front loading Kenmore H2 has a torn gasket.
You will have to take the door apart to get the gasket mounted properly. Although not required, a second pair of hands really helps.
Mar 19, 2009 | Kenmore HE2 Plus Front Load Washer
Front load washer door won't open
There is an override switch directly below the latch under the machine on most front loaders.
Jan 24, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore HE3 will not HOLD water, drips out into the pedestal
check to see if there are any rips in the door seal,then take the bottom of the washer off you will see 3 screws holding it on. see if the water is coming out of the pump that is right behind the panel that you took off.
Dec 30, 2008 | Kenmore Elite 45986 Front Load Washer
Washing machine door gasket.
i am a recently retired appliance engineer of 20 years and seen every bodge job / trick and short cut in the book which people have done to save money its simple DON'T WASTE YOUR TIME its a dam sight easier to do it right the first time
Oct 04, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore 44072 Front Load Washer Logo
153 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
