Question about Plumbing
Hole in copper water supply pipe
I drilled a hole in my bathroom wall to hang a towel rack and drilled a hole in a copper water line.(dead center) I cut out the dry wall around it and have access to it. how do I fix it? water is off. Please don't ask how I did this.
    Problem Solver:
  • 19 Answers
Solution#2 is one way to do it however those clamps will leak after awhile. You can cut pipe on center of hole and (A) push pipe up and install a copper coupling which does involve soldiering. Or (B) you can get a brass coupling fitting called (Shark Bite Fittings) which simply slides over pipe and locks and seals on pipes. This is a fairly new product and godsend to plumbers and plumbing repair. Whenever fixing pipes in walls check for any form of leaks thoroughly before covering up wall.
Posted on Jul 07, 2009
  • 247 Answers
Well you can go to Home Depot or a harware store and the will have a clamp patch or else you will hace to cut out the hole and splice a new piece in which would consist of cutting and soldering. Hope this helps
Kurt
Posted on Apr 14, 2009
Put a hole in water line while drilling, we want to know how to locate remainder of pipe under the interior siding
Posted on Jun 16, 2009
2 Suggested Answers
  • 3 Answers
SOURCE: hole in copper water pipe
Judging by how calm you sound it's likely a drainage or vent pipe and not a supply pipe which would be spraying all over the place the moment your drill pierced it. You'd have little choice but to cut the pipe and solder a coupling in there. If it's just a drainage or vent pipe you can buy an MJ (Mechanical Joint) coupling at Home Depot....these don't require fancy tools or torches to use.. The MJ coupling comes in two parts...a rubber part that joins two pipes and a stainless steel band with a couple of gear clamps....you just tighten the gear clamps and the compression does the rest.
Posted on Apr 15, 2009
How to remove Moen towel rack from wall?
I think for removing moen towel rack from the wall, you should hire a professional because your wall may get damaged if you do this work by yourself.
Apr 02, 2013 | Home
I have a wooden shelf which I want to hang above my flat screen tv, what type of screws should I be using?
Depending on weight of shelf and contents.
And if you can hit a wood stud.
http://t0.gstatic.com/images?q=tbn:ANd9GcRgImEAL3MOBqQus1-EOz1kKhcNhWnCFnVcBrQtBZaGw0KC_bdPCw
I like the plastic zip-it anchor because it is pretty strong for towel rack or shelf with a few books etc, It simply drills flush into the wall and then you can use a regular pan-head or drywall screw to connect shelf to zip it. Later the zip it can unscrew and hole is filled easily.
Wall dog is nice for 1 step into drywall. Lightweight shelf, with 2 small books and vase..
Toggle bolt for heavy shelves, But requires good sized 1/2" hole drilled first, and takes a few skill techniques.
Mar 13, 2013 | Woods Hardware & Accessories
Trying to hang gatco channel towel bar. there are no studs what size hole should I drill? I lost my directions.
Go to Home Depot, hardware or Plumbing isle,, tell them you want to hang a towel bar and you want some self drilling wall studs rated larger than or equal to 10 pounds. bring one of the screws from your Towel bar kit.
Nov 28, 2010 | Gatco & Channel& Satin Nickel Towel Bar
How do I replace the water line in the door?
Find your route to the water line. Drill a hole in the floor behind the refrigerator and thread the copper tubing into the basement. Go to the basement and find the main water line and pull the copper tubing to it.
Step 2
Attach pipe to refrigerator. Go back up to the kitchen and attach the end of the copper tubing to the water pipe of the refrigerator. You can use a nut and ferrule to connect the tube to the fridge. Make sure to leave a little bit of copper tubing coiled behind the fridge so as to not disconnect the tubing when moving the fridge.
Step 3
Turn off the water. With the fridge all hooked up, go back to the basement and turn off the water. Find the cold water pipe and drill a 1/4-inch hole to accommodate the copper tubing.
Step 4
Attach valve to pipe. You need to attach the water valve to the main pipe. This allows you to control the flow of water to the refrigerator. Make sure you have a gasket to seal between the valve and main water pipe.
Step 5
Connect the copper tubing. With the valve connected to the main water pipe, connect the copper tubing using a clamp. This should be everything you need. Turn on the main water and you should be able to get a glass of water, but it will take an hour or two for the ice cubes to freeze.
Take care..
Aug 08, 2010 | Kenmore 53092 / 53094 Side by Side...
Leak from bathroom sink behind the wall
hello , usually there will be water supply lines coming in from behind the wall area and if it isnt leaking at the supply valve it self then you may need to open up the wall area behind the sink and find out what is leaking it depends on what type of pipe is used most likely you have cooper tubing and sometimes these tubes after a while may leak or form small holes or it may be a leak at a soldered joint remeber there are 2 lines one for hot one for cold and you can turn the off by shuting off your water at the main valve then repair the leaking area.
Oct 10, 2009 | Belle Foret Bathroom Sink Faucet -...
Hole in copper water pipe
Apr 14, 2009 | Plumbing
Rheem small 6 gallon water heater vibration/noise
If the water heater is working fine than I would not worry about the function of the water heater. What the problem may be is that some of your WATER LINES HAVE MOVED, AS THEY WERE NOT SECURED PROPERLY. The sound you may have heard was the Copper or PVC(Plastic) lines just getting back comfortable. I Suggest checking that your water lines are secured about every 3 or 4 feet with the proper ancjhor....Metal for metal pipe, copper for copper pipe, etc. Sometime as in my house, pipes are run through a hole drilled through a stud or a piece of wood, usually when hot water is run through this pipe. You can here an expansion of the water line interacting with the pipe expanding, if the hole in the wood was not drilled big enough......Experience of remodeling a very old house.......Joe
Dec 31, 2008 | Rheem 81VP6S/430126 Water Heater
How to Install Towel Bar?
Since towel bars are usually installed onto separate hardware that's mounted on the walls, use the actual hardware as a template to mark exactly where to drill your mounting holes. Hold a piece of mounting hardware against the masking tape and use your pencil to mark the actual spots to drill your holes. Use different-sized drill bits to drill for the two ends. The Molly bolt or wall anchor will require a much larger diameter hole than the screws going directly into the stud. (The size of the hole required for the wall fastener will be marked on the packaging.) Install the wall fastener into the wall, then mount the hardware onto the wall and place the ends of the towel bar over the hardware. Attach the towel bar to the mounting hardware using the screws included with the towel bar. These are commonly small-slotted screws located on the bottom of the end pieces of the towel bar.
Aug 27, 2008 | Grohe 40.344.000 Essentials Bathroom...
How to Install Towel Ring
Place the mounting bracket against the wall and trace around the inside of the two ovals on the bracket. Gently drill a hole into the center of the traced oval. If you hit a stud, you will not need the anchor. Carefully tap the drywall anchors into the holes. Screw the bracket onto the wall, using the screws provided, into the two anchor points. Make sure the set screw is backed out far enough to set the escutcheon over the mounting bracket. Place the escutcheon over the mounting bracket, top first. Tighten the set screw with the Allen Wrench provided.
Aug 27, 2008 | Kohler Bathroom Accessory Set with Classic...
Plumbing Logo
1,056 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
