Question about HP PSC 1350 All-In-One Thermal Printer
My Hp PSC 1350v
Has A error Message Of check the cartidge but i've checked and cleaned and reseated them and its still up there can anyone help
  • eemacks Aug 13, 2008
    All leds blinking and does not work at all. No movement of the cartridges carrier at all.
    Problem Solver:
  • 9 Answers
Check the date on your ink cartridge.  I bet it has expired. If you put in a "new"cartridge but it is even an HP one with an older date, it may not work.
I had my printer stop in the middle of a print job.  It was printing fine and suddenly would not print.  So I refilled the cartridge with an ink kit I had on hand and reinserted it--no go!  Then I opened a remanufactured cartridge I had bought some time ago and inserted it.  No go, despite the fact I could see ink coming from the jets.  I finally gave up and bought a new HP ink cartridge, and it worked just fine.  But it bugged me why the new one would work and the other two that seemed just fine would not.
Later I learned that HP has a chip that reads the expiration date on the cartridges and that is what keeps those old ones from printing.  I found one trick of setting my date on my computer back to a year earlier than the exp date on the cartridge.  I saw the date on the remanufactured one I had tried earlier was 2005, so I set my computer date to today
Posted on Oct 29, 2007
  • WiseWoman Oct 29, 2007
    Be advised, though, if you try the date setback, that HP printer will buck and try every way to not let you use that old cartridge.  You must say no to reflashing if HP tries to pull that on you.  And you will take out and put back that same cartridge multiple times and keep printing alignment sheets 3 or 4 times before you are successful.  But, if you persist, you can get it to work.
    date but year 2004.  After forcing me to do print alignments several times and take the remanufactured cartridge out and put it back, I got it to print just fine.  And that 2005 cartridge that would not work earlier is what I am printing with right now.
    Sorry--it cut me off at an apostrophe after today!!
    Scholar:
  • 21 Answers
Hi, I really appericate all your efforts to fix the issue the issue usually occures if any one of the cartridge is defective or low in ink or both the cartridge are defective. We can isolate the issue only by removing the both the cartridges out of the printer and check for the expiry dates printed on the cartridges as if the cartridges are expired also leads to this message. If the cartridge are not expired and have minumial ink in it you can try the below procedure to isolate the defective cartridge Once the both the cartridges are out of the printer insert only the black cartridge in the printer and check for the message if the message is install color cartridge the black cartridge and printer is detecting fine. If the message is check right cartridge this shows that the black cartridge is defective. If the message is insert left cartridge or color cartridge remove the black cartridge out and insert only the color cartridge and check with the message if the message is insert the black cartridge the color cartridge is working fine. And when the color cartridge is in the printer and if the message prompts to check left or color cartridge the color cartridge seems to be defective so replace the defective one will fix the issue So in isolation we can find the defective cartridge and fix the issue by replacing the defective one.. Hope this will help you to fix the issue.. Wish you success. Regards, Barret.
Posted on Sep 27, 2007
SOURCE:
Error message "remove and check black cartridge"
Buy a new HP cartridge, 3rd party cartidges for HP machines have substantially lower reliability
Aug 06, 2009 | HP PSC 950 All-In-One InkJet Printer
Continual error message on printer after replacement of new cartr
Try running deep print head cleaning on the printer and see if that helps
Apr 10, 2009 | HP PSC 1350v All-In-One InkJet Printer
Error message...
Check the board or ribbon behind the cartridge and see if there is a hole. If yes then there is nothing you can do unless under warranty. If it is under warranty you can get an exchange. If you do not it will not be worth getting a refurb unit from HP just purchase a new one. Sorry for the bad news, i know you were probably hoping for a fix.
Dec 12, 2008 | HP PSC 2355 All-In-One InkJet Printer
Error
Did you use HP cartidge? HP printers work best and can only eliminate errors if you use genuine HP cartridges. If you didn't, get a HP cartridge. If you did, double check to make sure it's seated correctly and if you need to you can clean the contacts where you insert the cartridge. You can wipe them very gently with a piece of cheese cloth or a coffee filter.
Mar 15, 2008 | HP PSC 1315 All-In-One InkJet Printer
Ink cartridge stalled
hmmm..did you clean and recalibrate your print heads after replacement?
also, you might want a fresh set of print drivers. get em here
Mar 10, 2008 | HP PSC 1350v All-In-One InkJet Printer
HP PSC 1350 All-In-One Thermal Printer Logo
230 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
