Question about Tomtom GO 300 GPS Receiver
Will not turn on
Tom tom was ok this afternoon charging in the car then it went off and i cant get it back on it just has the tom tom logo on the front i have tryed the reset button with no responce please help Paul
  • 1 more comment
  • nicola d Sep 24, 2007
    Hi thankyou it had nothing to do with the tomtom its self i have found it was thw sd card so it anybody gets a problem like this it just maybe the card thanks paul
  • rajpatelred Nov 07, 2007
    hi
    i have a tom tom 300
    the fault is the charger light comes but does not switch on
    what do i need to do?
    please reply on rajpatelred@yahoo.co.uk
    i would be most thankful
    thanks again
  • Anonymous Nov 18, 2007
    gbs wont charge
  • 3 Answers
Do you plug it into the cigarette lighter or is it installed (wired) behind the cigarette lighter. If so and you happen to plug something into the lighter you run the risk of shorting out our friend TomTom (I did it twice)
Posted on Sep 22, 2007
My tomtom go 510 will not charge in car but ok at home
The Car chargers are generally the defective unit.
I have also faced a similar issue as the spring loaded cigarette lighter was pushing the charger causing it to disconnect.
Jul 31, 2016 | Tomtom GPS
My tom tom started with the screen going dull and then volume went lower and it started to shut down then same thig happened a battery symbol of a rectangle shape with a little red section then sat n
can you connect it to your usb port on your computer? if so try to connect and use it. dont worry about charging it just use it to see if its working ok. i dont know why they put a battery that is not replaceable in those. you must send it back to them to replace, I keep mine on power all the time. check this out first and see if its a malfunction or works ok.
Jan 31, 2015 | Navitech TomTom / Tom Tom GPS / SatNav...
My DS Lite wont charge! Help!
Try another charger, yours may be faulty. Alternatively,the battery may need replacing as it is no longer holding charge, these can be obtained very inexpensively from Ebay and you will just need a small cross head screwdriver to remove the cover on the back of the DS lite, then tap the unit in your hand to dislodge and remove the battery.
Dec 22, 2013 | Nintendo DS Lite Console
Ok so my phone has been stuck on the apple logo since 12 this afternoon and now it is 6pm. I have been charging it for hours and have tried all of the tricks shown on this site but nothing has helped! It...
Easy problem to fix !!
turn off your phone.
take the battery out.
leave out for about 5 min.
put back together.
turn on phone.
your problem should be fixed.
don't for get to give me a
good rating if this helps you,
Thanks,
Debbie
Aug 05, 2011 | Apple iPhone Smartphone
Loss of signal
It is most lkely the battery, chane the battery and recharge it. batteries collapse after about 2 -3 years depending on use and abuse. If you have it plugged in when starting the engine the battery will deteriorate quicker and eventuslly fail. resting the battery can cause some charge to return, often sufficient to run it for short periods before it once again fails due to output being greater than the chrging rate.
Jun 30, 2009 | Tomtom ONE GPS Receiver
Just bought a tom tom 1. it was on at first. then went off. so i have charged it in the car. green light came on. so i know its charging but it wont switch back on. blank screen
those need a good charging! if you have a mains adapter for it, give it a overnight charge! same problem happened to a friend of mine!
Jan 02, 2009 | GPS
Tom Tom Go 710 - Won't turn on
not sure but try an other device on the car plug to see if it works??????????? could be the plug.
Dec 17, 2008 | Tomtom GO 700 GPS Receiver
Cant get tom tom to switch on
Is the unit charged fully? If so, try resetting the unit. There is a small opening on the back of the unit on top. Put a paperclip in there for a couple of seconds and the unit should reset.
Jan 20, 2008 | Tomtom GO 910 GPS Receiver
Tomtom GO 300 GPS Receiver Logo
112 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
