Question about Poulan Pro Chain Saw 46cc 20"
Can,t hardley pull starter cord. I've removed muffler and carb. It will pull fine if the spark plug is removed (w/or with carb and or muffler . this is a poulan pro 18"
  • skipdra Apr 17, 2009
    I have one that wants to kick back when pulling the cord. (A Poulan 20") It reminds me of some that have had the switch turned off and wheh pulling would kick back. This one does it either way. I can get it started with a lot of trouble . I know the carb needs adjustment. I thought it could have been out of time but the flywheel and key (one piece) seem ok. Help?
  • 226 Answers
What i have to occasionally do for a chain saw after it sits all winter is to put something like WD40 in the spark plug hole and crank it over several times. What happens to me is that the piston gets gunked up from the gas that ran down into it during the winter and it won't crank over hardly at all. This is probably your problem. I have also found that if i store my saws with the tank down, the gas cant get into the carb and do this. (Although it's better to drain tank).
If this has been a running saw instead of a stored one, you probably need a rebuild kit if the piston is scored.
Posted on Apr 15, 2009
Husqvarna Chainsaw 266xp
The 266XP never had a deco valve, once the ring bedded in they did have a really good compression, the is no milage in removeing the carb, you can remove the cylinder and fit an additional base gasket, you can also increase the air gap between the flywheel and ignition unit, this will cut down some of the drag from the magnets, once you have done this there is little else to do, it is what it is.
Apr 29, 2013 | Garden
I can not get my craftsman leaf blower to start. I put a new spark plug and fresh gas. Won't start.
Not to sure without seeing or hearing it being pulled over. Compression? Very likely needs some carb work/kit.
Apr 04, 2013 | Garden
Toro Electric Start Problem
Remove spark plug and observe condition. Fouled with oil, bad motor. With plug removed pull rope several times to blow out cylinder. Spray WD40 in spark plug hole, pull rope several times see if oil blows out. Spray a lot of starter fluid in spark plug hole, replace plug. Spray starter fluid in air cleaner area of carb, try to start. Replace spark plug, try to start. Ensure oil is full, all mowers have a low oil sensor now. 30w oil. Always use Stabile in gas.
Jul 04, 2012 | Toro Garden
Can't pull the starter cord, it's very hard to do. Removed spark plug and then the pull cord worked fine. Put the spark plug bvack in and once again the starter pull cord was hard to pull. Seems...
Hi and welcome to FixYa, I am Kelly
Remove the muffler and clean out the exhaust port and screen. You will have to disassemble the muffler and clean off or replace the screen item 8 of this link:
http://www.partstree.com/parts/?lc=echo&mn=CS-330T++S%2FN%3A+C08611001001+-+C08611999999&dn=7946
Before taking the muffler apart... unhook the spark plug and just pull it though with the muffler removed. If it pulls normally you know you have found the problem.
If it still pulls hard...check the exhaust port of the cylinder head for 2 tiny holes (not screw holes) Some have them some don't depending upon the year of the saw. If you do find 2 small holes that appear clogged with carbon... do your best to clean them out.
Thanks for choosing FixYa,
Kelly
May 15, 2011 | Echo CS400 18" Chain Saw
When i pull the cord to start it gas is spraying out the exhaust. What is the problem
The problem is the needle valve inside the carb is stuck open causing fuel to fill the cylinder. This why gas is coming out of the muffler. You have to rebuild the carb but you have to determine if you have a walboro or zama style carb in order to get the right rebuild kit. make sure you get the full rebuild kit that comes with a new needle valve and adjust the needle valve so that its flush with the slot that it fits in. Also remove the spark plug and pull the starter until all the fuel is out of the cylinder.
Dec 07, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
Craftsman gas leaf blower will not start. Spark and gas lines ok. Not getting gas to plug even after prime and several pulls. How do I find gas supply problem. Diaphram in carb looks ok .It actually...
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Nov 25, 2009 | Craftsman Garden
Troy-bilt gas edger trencher won't start. Spark
Remove spark plug and pour 5mls or one teaspoon of premixed gas in the engine. Depress trottle to full with choke on "run", pull starter about 10 to 12 times If it starts and run for a while and then shuts off your carb needs servicing. If not remove muffler and look for a spark arrestor screen. This could be plugged up with soot. If it is, replace and this would have been your problem. While the muffler is off slowly pull starter rope and examine the piston if gas and oil oozes backwards as the piston moves to the top then the piston and rings need replacing.
Oct 25, 2009 | Garden
I tried to start my older Poulan Chain saw a day after I had been using it. I find it almost impossible to pull the starter cord...there is too much resistance. If I take out the plug and pull the cord...
Did you remember to mix oil with the fuel before you put in the tank?
Remove the spark plug wire and the spark plug. Remove the muffler. Shine a light through the spark plug hole and inspect the cylinder through the hole where the muffler was. Is it smooth and shiny? Use the starter to move the piston up and down slowly. Is it smooth or does it appear scratched and gouged?
I suspect parts of your piston are adhered to the cylinder wall. If that is true it will probably cost more to repair it than to replace it.
You needn't take it to a poulan repair center. Most Stihl outlets employ good mechanics and can repair any saw. HTH
Lou
Shh... my Husqvarna gets serviced by a Stihl dealer... The Husqvarna dealer is actually closer to me. I feel better about the Stihl mechs.
Sep 30, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Husqvarna 51 from 1991 too much resistance to starting attempts
It sounds like it's sorta gummed up from old gas residue. You could spray carb cleaner in the spark plug hole and into the carb while holding the throttle open and pull the cord several times and then follow that with penetrating oil to re-lubricate the engine. You're probably going to have problems with the carb also. I would have it rebuilt or, better yet, purchase a new one
Jul 01, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Chainsaw won't start. Can't pull starting cord out
Try replacing the muffler. The baffle or something inside the muffler may be loose and when compression is put on the cylinder from pulling starter rope to crank over engine it will cause baffle to move over and seal off muffler leaving nowhere for compression to go. When the sparkplug is removed this allows an outlet for compression when starter rope is pulled. Hope this helps
Feb 24, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Poulan Pro Chain Saw 46cc 20" Logo
480 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
