Hope this helps:
Cavity/Fuse Diagram (1996 Grand Cherokee, passenger side kick plate to find, Owner's Manual pgs 205-206):
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
Row 1: 1-6 (left to right)
Row 2: 7-12
Row 3: 13-18
Row 4: 19-22
1996 Jeep Grand Cherokee Fuse Panel (Passenger Side kick panel) Reply
CAVITY FUSE DESCRIPTION
1 -10 amp (RED) Radio
2 -15 amp (Lt Blue) Cigarette Lighter
3 -10 amp (RED) Rear Washer Switch, Body Controller
4 -10 amp (RED) Airbag
5 -10 amp (RED) Lamp Out Module, Overdrive Switch, OBD II
6 -15 amp (Lt Blue) Vehicle Information Center/Graphic Display Module Park & Side Lamps, Overhead Console Lighted Visor, Automatic Dimming Mirror
7 -20 amp (Yellow) Body Amp, Cluster, Body Controller
8 -20 amp (Yellow) Rear Wiper Motor, Flipper Glass Solenoid, Cargo Lamp, Trailer Tow
9 -15 amp (Lt Blue) Brake Switch
10- 10 amp (RED) Rear Window Defroster
11 -10 amp (RED) ABS Module
12 -10 amp (RED) Heater-Ventilation-A/C Control & Recirculation Motor
13 -15 amp (Lt Blue) Hazard Switch, Turn Signal Switch
14 -15 amp (Lt Blue) Spare
15 -15 amp (Lt Blue) Spare
16 -10 amp (RED) Right & Left Courtesy Lamp, Glove Box Lamp, Halo Lamp Cargo Lamp, Underhood Lamp, Dome/Read Lamp Right & Left Visor, Automatic Dimming Mirror
17 -15 amp (Lt Blue) Radio Illumination, Tail Lamp, Graphic Display Module, Park & Side Lamps, Headlamp Switch, Body Controller
18 -20 amp (Yellow) Spare
19 -15 amp (Lt Blue) Passing Light
20 -15 amp (Lt Blue) Radio, Heater-Ventilation-A/C, Vehicle Information Center
21 -15 amp (Lt Blue) Power Outlet
22 -10 amp (Blue) Airbag Module
1996 Jeep Grand Cherokee Alarm, Remote Starter, Keyless Entry Wiring Information
Constant 12V+
Pink/Black
Ignition Switch Harness
Starter
Yellow
Ignition
Dark Blue/Gray
Ignition 2
Red/Black
Ignition Switch Harness (for AC)
Accessory
Black/Orange
Tach
Gray/White
Coil
Brake Switch
White/Tan
Brake Switch
Trunk Pin
n/a
Works with Dome Light
Parking Lights
Blue/Red (+)
Left of Steering Column or Light Switch
Head Lamp
Tan/Black
Light Switch
Factory Disarm
Purple/Yellow (-)
Driver's Kick Panel Black Connector at ECM
Door Trigger
Yellow (-)
Driver's Kick Panel see notes
Door Lock
5/Wire in Driver's
Inside Driver's Door Orange/Purple Lock Pink/Black Unlock
Door Unlock
and Passenger's Doors
Inside Passenger's Door Black/White L Pink/Black Unlock
Horn Wire
Gray/Orange (-)
Steering Column
Windows Up
LF=Light Blue, RF=Brown/White, LR=Blue/White, RR=Gray/Black Doors
Windows Down
LF=White, RF=Purple/White, LR=Red/Black, RR=Green/White
• Cruise Control Information • Stereo Information • View all Jeep Vehicles
how could it be the power supply? and what part? and no im no novice.
