Question about Acer AL1916W 19" LCD Monitor
Pc automatic turn off
I just buy new computer but when i connet the network my computer suddenly turn off it self.one thing the cooling fan sound really fast.it that normal?when fan run fast my cpu turn off automatic.i use acer cpu 64athlonX2 1gb ram,and nvidia.please help me
    President:
  • Acer Master
  • 2,022 Answers
See the system temprature is cool it happen normally bcoz ho heat see your graphic card fan is working fine and it is not generating more heat. bye
Posted on Sep 25, 2007
  • mukhtar21 shaikh
    mukhtar21 shaikh Sep 26, 2007
    if your problem is still there change the cpu fan and change the graphic card and let me know.
    bye
SOURCE:
Can't get my system to boot up
The power mapping grid on the motherboard may be defective
Sep 15, 2012 | ASUS P8Z77 WS Z77 LGA 1155 ATX Intel...
My fan stopped working and i am facing overheating which making my laptop stop working and shut down suddenly
buy your self a laptop coolinng pad/table with built in usb fans your laptop will really appreciate it you can purchase these on Ebay ranging from $2.99 to $22
hope this helps
Jan 13, 2011 | HP (344872-001) Laptop Cooler, Cooling Fan
Overheats and freezes
Turn the computer off.
Disconnect the AC power.
Remove the battery.
Buy a can of compressed-air.
Give the computer a "blow-job", because dust inside the computer is working as a layer of insulation, i.e., not allowing your computer's fans to cool itself.
Apr 25, 2010 | HP Pavilion dv1000 Notebook
The labtop becoms heated and suddenly turn off
Hi
Sounds like the fan is either blocked or not functioning correctly. Advise you take to a good computer shop before further damage is done.
Taz
Nov 09, 2009 | Toshiba Satellite Pro L300 Notebook
The pc turns off without warning
Sometimes when you add a new device to your computer, you computer will have a driver conflict and just reboot or shut off. If nothing was introduced to your computer here lateley then it may want to run Windows updates.
Another thing that may cause thing like this to occur is if your CPU fan is not functioning properly. The computer will automatically shut off because of overheating. If you can, unplug everything from your computer, open it and with a can of air, blow it clean and look at all the cooling fans.
If you need further help, reach me via phone at https://www.6ya.com/expert/hugo_f827544e52871d36
Oct 09, 2009 | Computers & Internet
Turns off automatically
check your cooling fan sounds like its getting too hot
Oct 03, 2009 | Sony VAIO VGN-CS220J/W Notebook
My toshiba cooling fan is not functioning. the computer automatically shutdown because of overheating. what is the best thing to do?buy a cooling pad or maybe change the fan as well as the heat sink?
It is best to change the fan and heatsink. Make sure you clean the processor and apply a very thin coat of thermal compound (arctic silver) to the heat sink if it is not supplied. Newegg.com lists may cooling fans & heatsinks based on your socket configuration
Hank
Jul 30, 2009 | Computers & Internet
Display and Boot problem with HP Pavilion DV2125NR
It is normal for the bottom to get hot. The fan should keep it cool enough to run, but it sounds like perhaps your fan is not working very well anymore and should be replaced.
Does the computer act up at all when cool? If not, the first thing I would try is replacing the fan and examining the fan and heatsink assembly for proper installation, perhaps replace the heatsink compound with some Arctic Silver while you have it open.
Jul 10, 2009 | HP Pavilion dv2000t Notebook
My computer fan is running continuously, from the time it turns on. (even before booting in to windows xp) why does my hard drive fan kicks in all the time - its loud and annoying
The fans in most desktops do run whenever the unit is on. Only high end/ performance/ or self built systems usually have self adjustable fan speeds.
Mar 12, 2009 | Compaq Pesario S4120WM (DK216AR#ABA) PC...
My acer aspire cooling fan is not working properly so it turns off unexpectedly several times a day.
if the cooling works well the fan gonna shutdown automatic. nothing to worry about, but if it does when the computer is still hot then you need to replace the fan.
when it shutsdown, does it later start by it self?
Feb 24, 2009 | Acer Aspire L100 PC Desktop
Acer AL1916W 19" LCD Monitor Logo
73 people viewed this question
Ekse
Alun Cox
