Question about Plumbing
Hole in copper water pipe
I drilled a hole in the wall to hang a towel rack and drilled a hole in a copper water pipe.(dead center) I cut out the dry wall around it and have access to it but how do i fix it? (water is turned off)
  • 3 Answers
Judging by how calm you sound it's likely a drainage or vent pipe and not a supply pipe which would be spraying all over the place the moment your drill pierced it. You'd have little choice but to cut the pipe and solder a coupling in there. If it's just a drainage or vent pipe you can buy an MJ (Mechanical Joint) coupling at Home Depot....these don't require fancy tools or torches to use.. The MJ coupling comes in two parts...a rubber part that joins two pipes and a stainless steel band with a couple of gear clamps....you just tighten the gear clamps and the compression does the rest.
Posted on Apr 15, 2009
Does anyone know the dip tube part number for a Rheem Fury Gas 42VR50-40F water heater? Heater runs out of hot water far too quickly. Thanks!
certain water heaters had a tube that dissolved, you take 1/2 in. copper flare one end of it, drill a1/8 in. hole in pipe 4 in. below flare ,remove cold water nipple on tank install new copper tube, cut tube to 3 inches off bottom of tank depth , reconnect cold water supply you should be good.
Mar 23, 2016 | Rheem Water Heaters
Hole in kitchen wall. How do I fix it?
First I would cut around the hole using a dry wall knife -I would make it a square. Then get a piece of wood ( 2" high and Then measure the length of the hole if it is 9" then you would need the wood piece to be 11" long.) Insert the wood piece inside the wall (hold on to it) and then drill using dry wall screws from the out side wall into the wood piece you installed. Then cut a piece of dry wall the size of the square you made and insert into the wall then screw into wood piece. Then take some joint compound and spread light over insert dry wall spreading on the old dry wall and let dry and then sand so it is flush with wall.
Apr 18, 2013 | Tools & Hardware - Others
I have a wooden shelf which I want to hang above my flat screen tv, what type of screws should I be using?
Depending on weight of shelf and contents.
And if you can hit a wood stud.
http://t0.gstatic.com/images?q=tbn:ANd9GcRgImEAL3MOBqQus1-EOz1kKhcNhWnCFnVcBrQtBZaGw0KC_bdPCw
I like the plastic zip-it anchor because it is pretty strong for towel rack or shelf with a few books etc, It simply drills flush into the wall and then you can use a regular pan-head or drywall screw to connect shelf to zip it. Later the zip it can unscrew and hole is filled easily.
Wall dog is nice for 1 step into drywall. Lightweight shelf, with 2 small books and vase..
Toggle bolt for heavy shelves, But requires good sized 1/2" hole drilled first, and takes a few skill techniques.
Mar 13, 2013 | Woods Hardware & Accessories
I replaced an Moen spout for my shower unit. Water flows thru the Spout and when level is pulled water flows thru the shower head. But there is water leak somewhere (reverse flow?). The ceiling below it...
if you have copper piping,you probably twisted the pipe when,you tightened the spout ,and broke pipe. If you are'nt able to get into the wall on the shower side, cut a hole on the other side of shower wall to repair it.
Aug 04, 2011 | Garden
There is loose wall mount tub filler. How can I tight it?
Most tub spout are pretty covers for the generic ugly pipes that deliver the water from the wall water plumbing into the tub area. Speaking for this water pipe it's either going to be copper or galvanized iron pipe. The pipe that you see sticking out of the wall is rather short. It ends just inside the wall usually at a 90 degree elbow which in turn is connected to a pipe and other things inside the wall cavity. If this short pipe stub is loose so you can move it in and out of the wall hole some, the reason is that the plumbing pipes inside the wall are not tied down to the wall studs properly.
If the backside of the wall can be opened by cutting out a section of sheetrock in the same location as where the spout pipe is located, you can expose the inside wall plumbing and tie in the wall pipes securely to the wall framing. Afterwards, you need to seal up the sheetrock hole you created.
In some cases this is not possible. When that is the case, your fix is spotty at best. You can use a caulking that becomes rock hard when cured around the pipe nipple as it comes through the wall hole. Hopefully the hard caulking will provide enough tightness tying the pipe to the wall material to help stop the movement. Install the caulking so it is underneath the pretty tub spout when you reinstall it over the generic pipe. Make sure you do not have this caulking involved with the pretty spout so if you need to remove it again, it won't be locked in by the hardening caulk.
Nimsgame
Feb 15, 2011 | Cifial Wall Mount Tub Filler Spout CIFIAL...
How to install an ace hardware saddle valve on 3/4" galvanized pipe?
You need to turn water off. Release pressure on system by opening a faucet or something. Drill a hole in galvanized pipe slightly larger than piercing needle on saddle valve. Open up piercing valve so it extends out, that way you can see it go in previously drilled hole. Finish valve like you would on copper pipe. Keep piercing valve closed until 1/4" pipe is done being hooked up. Turn on the previously shut off water valve
Jan 26, 2011 | Humidifiers
We have a shower surround that is 1/4" thick. However, there is a void of at least 1" from the stud. Where do you mount the valve on the stud? Should it be in the middle or offset? We are...
can you get behind the surround?
Install it in the dead center of your cut out. Use 1x1x3" to support the piping behind your wall of the surround. silicone one side of each 1x1 apply to the wall between pipe and wall then use 1/2" copper "two hole straps/clamps" (any hardware guy will know this when you ask for them.) Use 1/4 - 3/8" drywall screws to fasten the pipe straps to the 1x1's. You'll get your stability when you install your escushtion (beauty ring) on the inside of the shower. Will tighten up against your 1x1's.
You'll see,
Enjoy,
Mike.
Ps. Plz leave a remark.
Dec 31, 2010 | Moen & One Handle Tub & Shower Faucet
Trying to hang gatco channel towel bar. there are no studs what size hole should I drill? I lost my directions.
Go to Home Depot, hardware or Plumbing isle,, tell them you want to hang a towel bar and you want some self drilling wall studs rated larger than or equal to 10 pounds. bring one of the screws from your Towel bar kit.
Nov 28, 2010 | Gatco & Channel& Satin Nickel Towel Bar
How do I replace the water line in the door?
Find your route to the water line. Drill a hole in the floor behind the refrigerator and thread the copper tubing into the basement. Go to the basement and find the main water line and pull the copper tubing to it.
Step 2
Attach pipe to refrigerator. Go back up to the kitchen and attach the end of the copper tubing to the water pipe of the refrigerator. You can use a nut and ferrule to connect the tube to the fridge. Make sure to leave a little bit of copper tubing coiled behind the fridge so as to not disconnect the tubing when moving the fridge.
Step 3
Turn off the water. With the fridge all hooked up, go back to the basement and turn off the water. Find the cold water pipe and drill a 1/4-inch hole to accommodate the copper tubing.
Step 4
Attach valve to pipe. You need to attach the water valve to the main pipe. This allows you to control the flow of water to the refrigerator. Make sure you have a gasket to seal between the valve and main water pipe.
Step 5
Connect the copper tubing. With the valve connected to the main water pipe, connect the copper tubing using a clamp. This should be everything you need. Turn on the main water and you should be able to get a glass of water, but it will take an hour or two for the ice cubes to freeze.
Take care..
Aug 08, 2010 | Kenmore 53092 / 53094 Side by Side...
Have a hoover hed6612 dishwasher just over a year old, it pre rinses and part washes and then doesnt move to the next rinse cycle instead it stops and beeps continuously with the prerinse and wash buttons...
We have had the same problem but have found a fix.
1. If any of the wheels have come off the top sliding basket/rack you need to make sure they are all back on for each wash ( ours are very loose! )
2. Push the top rack in FIRMLY before you wash - make sure it engages at the back.
That's it - solved it for us after months of problems.
I think that as the wheels get worn the top rack does not fully engage at the back and this is when the problem starts manifesting itself. We have some new wheels on order but they are taking ages to arrive.
Dec 06, 2009 | Hoover Dishwashers
Plumbing Logo
160 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
