Question about Car Audio & Video
Powering off and on by itself.
Hi, i have a cda-9833 for about 3 to 4 years never had a problem before but suddenly now a days it seems to turn off and on by itself, sometimes i can not turn it on at all wait few mins or sometimes before i can turn it on any help please. thanks.
  • chuckiechulo Apr 15, 2009
    thanks evlangl ill try to check the wiring it was just odd this happen recently. never had a problem before. i thought it could be the unit itself is faulty. don't know the life of the unit.
    Problem Solver:
  • 6 Answers
There might be a loose wire,it could be dirty or you might just need a new one
Posted on Apr 14, 2009
Aux wont work
check the devices volume level. I had the same problem with my phone. Every time i plugged it in the phone volume level would go down to about half way. hope this helps
Apr 20, 2014 | Alpine CDA-9833 CD Player
CANT SEEM TO SAVE MY RADIO STATIONS EVRY TIME I TURN OFF MY CAR THE STATIONS ERASE.
there is a memory power lead (usually yellow) that must be hooked up to constant power. find a circuit in the car that doesn't cut off with the switch and hook the memory power lead to that. if the memory lead is properly attached, and has power even with the switch off, then the problem is internal to the radio and will have to be repaired. be aware, there is usually a fuse in the power lead to the memory, check the fuse also.
Aug 20, 2009 | Alpine CDA-9833 CD Player
Display malfunctions/no working functions
Remote turn on lead shorted to audio intterupt lead? I would just hook up power and ground to the 9833 and see if problem goes away. If not is must be internal to the 9833. If problem goes away i would double check wiring. Good luck that is a sweet cd player.
May 07, 2009 | Alpine CDA-9833 CD Player
Alpine CDA-9833, how do you tune frequencies manually,
1 Press SOURCE/POWER until a radio frequencyappears in the display.
2 Press BAND/TEL. repeatedly until the desiredradio band is displayed.
FM1 FM2 AM FM1
3 Press TUNE/A.ME to select the tuning mode. (the play/pause
button above source/power)
Distance mode:
Both strong and weak stations will be automatically
tuned in
(Automatic Seek Tuning).
Local mode:Only strong stations will be automatically tuned in
(Automatic
Seek Tuning).
Manual mode:The frequency is manually tuned in steps
(Manual tuning).
select manual mode to tune it one by one.
Nov 29, 2008 | Alpine CDA-9833 CD Player
Lost stereo front for cda 9833
You can try ebay.com if you lucky you can find it for very good price or go to pacparts.com,where you can buy it brand new
Nov 26, 2008 | Alpine CDA-9833 CD Player
No Sound
99 times out of 100 the audio is (a.k.a. "chip" ) is defective.
I would pull the radio apart, get the number off of the ic(it should be a big 10 or more pin part.. get the number off of it..
go to www.mouser.com, www.digikey.com, check ebay, or see if alpine will sell you one directly..
most common cause if the failure it a shorter speaker or shorted speaker wiring, so check all that over very well before you reinstall your deck!!!!
Jan 04, 2008 | Alpine CDA-9833 CD Player
Cd plays, but no sound
Disconnect the blue wire from the back of the radio and connect the blue/white wire in its place. This should fix your problem.
Apr 29, 2007 | Alpine CDA-9833 CD Player
Stays on even if HU (CDA-9833) is off
It is possible that the SIR unit stays powered as long as the red wire is powered, since it is normally connected to a switched source. To test this, disconnect the red wire or move it to a switched source (you could even add a switch on the wire and flip it manually). If the battery stays healthy after that, then the red wire being constantly powered is the problem. Otherwise, it is possible there is a problem with the Ai-NET cable connected to the SIR unit.
Sep 26, 2006 | Sirius Satellite Radio Sirius SIR-ALP1...
CDA - 9833 AI-Net issue
If the radio was still plugged in when you cut it (such a BAAAADDD idea....) it likely shorted the data pins to the power pins which fried the AI net processor. There is no fix for that. It's toast.
Aug 20, 2006 | Alpine CDA-9833 CD Player
Car Audio & Video Logo
20 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
