Question about Hoover F7431-900 SteamVac Vacuum
Steamvac quit spraying
Hi.... I am cleaning my carpet and everything was fine the "first round". I emptied the dirty water and refilled the clean water reserve and when I tried to pick up where I started, the sprayer won't spray. I cleaned the black filter, checked the rubber washer, and can't find out what's wrong. HELP!! THANK YOU!!
    President:
  • 1,673 Answers
Check the seal that the clean water tank sits on, may have come loose. The filter inside the dirty water tank has been pushed up too far, needs to have a 1/4 in. gap from the top to the top of the filter.
Posted on Jan 10, 2008
SOURCE:
I have a 1 year old Hoover carpet cleaner . I went to use it today and it won't start. Everything seams to be in the right position. can't figure it out..
Dual Power™ Carpet Cleaner - Hoover
hoover.com/products/.../dual-power-carpet-cleane...
The Hoover Company
Rating: 3.5 - ‎84 reviews
Dual Power™ Carpet Cleaner. Easy to Empty Tank ... You currently don't haveany recently viewed items. ... 3.5 out of 5 stars. ... The Hoover Dual Power™ Carpet Washer deep cleans on the double. ... 1 Year Limited Warranty .... The rinsing stage is a must and it cleaned a 20 year old carpet that was badly stained.
Hoover SteamVac Troubleshooting: Carpet Washer Loss of ...
? 1:19
https://www.youtube.com/watch?v=6TkcWjuz1zw
Aug 16, 2013 - Uploaded by Hoover
Your SteamVac carpet cleaner should pick up as well today as the day you got it. If you're experiencing loss of suction or noticing that your SteamVac won't . ... Hoover 1 year ago ... thank you! worked and i did not have to wait for call center to open! thank ...This machine is running well almost four years in.
Repairing a Hoover Carpet Cleaner ' ThriftyFun
www.thriftyfun.com/Repairing-a-Hoover-Carpet-Cleaner.html
I have a Hoover f7412900 carpet cleaner and one day the brushes stopped working. ...It was a couple years ago, so I don't quite remember, but it was in the manual, ... Itwon't start back up. ... If it is only 5 months old, it is likely still on warranty. ... Do not try to fix this yourself, as you may void the warranty if you start taking ...
Jan 29, 2016 | Hoover Vacuums
Hoover SteamVac LS F5899-910
Did you try to clean first the unit..
Jun 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover brush and wash instruction manual
Hi there! To prepare for cleaning, put the solution and water in the top tank. While cleaning, all the dirty water gets sucked into the bottom tank. To clean squeeze trigger to release cleaning solution and slowly push carpet cleaner forward, this equals one wet stroke. Continue to squeeze trigger and slowly pull carpet cleaner back toward you (second wet stroke). Release trigger and slowly push carpet cleaner forward over area just sprayed with solution (dry stroke). Then slowly pull carpet cleaner back toward you without squeezing trigger (dry stroke). To avoid saturating the carpet don't do more than 4 wet strokes over one area. Always end with dry strokes. Here is a link to view the instruction manual if needed.
http://hoover.com/file/604/
Hope this was helpful!
Jun 19, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
It is not dispensing water and solution
Clean Water
Solution Tank
won't dispense.
1. Clean Water Solution Tank
not firmly in place.
1. Make sure tank is securely locked in
position.
2. Clean Water Solution Tank
empty.
2. Refill tank according to instructions for
surface being cleaned.
3. Dirty Water Tank lid not on
correctly.
3. Make sure lid is firmly in place.
4. Pump needs to be "primed"
(when using tool).
4. See "Before Using Tool" section.
Dec 17, 2012 | Hoover SteamVac F5914-900 SpinScrub...
Wont **** dirty water back out of carpet and it has nothing to do with the lid not being on properly, just no suction...
Please check and see if the round gasket is on the round vacuum pipe under the hood, that contacts the dirty water tank. It should be a soft seal that touches the round open cylinder on the base of the dirty water tank.
Oct 03, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Water does not dispense on wash cycle
this would be the soap/ water valve. it is stuck closed or isn't opened.( no cure for an non-opened valve, just replace.)
Jul 16, 2009 | Hoover F7220900 SteamVac V2 Upright Vacuum
Instructions on Using The Hoover Steamvac Ultra cleaner
CARPET CLEANER\r\n™
i went the xtra mile to look this up you give me a incorect modlel # put the user guide are the same ps: dont for get to vote for me when it ask if i helped you lol sawdust46
MaxExtract™ technology features the most advanced
combination of multi-action agitation, carpet washing, dirt
removal and direct heat drying - all in one machine. This
technology delivers a floor that is not only deeply cleaned,
but a room that can be lived in again within hours!
• High intensity LED
- illuminates problem areas
• Stream Setting
- ideal for smaller spots
and stains
• Spray Setting
- attacks heavy traffic areas
Dual scrubbing1, multi-directional
brushes have been specifically
engineered to surround carpet
fibers, removing dirt at every angle.
1Patent pending
High velocity suction removes both
dirty water and soap residue, leaving
carpet revitalized. Forced heat further
speeds the drying process. No sopping
wet carpets. No musty odors. Just
clean carpet.
STREAM
SPRAY
REMOVES MORE DIRT2
INTEGRATED SPOT CLEANING
2Test of leading brands of household extractors using FCTP-0024p
Our exclusive pre-programmed
cleaning modes take the
guesswork out of revitalizing your
carpets. Simply select your carpet
type and cleaning task, and let
the pre-programmed modes take
care of the rest. Fully equipped
with Process Feedback Lights
and Full Tank Indicator Lights,
this Intelligent Cleaning System
makes cleaning your carpets
easier than ever before.
HOOVER PLATINUM COLLECTION™ DETERGENTS
TO MAXIMIZE CLEANING PERFORMANCE
PROFESSIONAL STRENGTH
Carpet and Upholstery Detergent
PET PLUS
CARPET CLEANER
Instant Stain Remover
Carpet and Upholstery Spray
AN EFFORTLESS CLEAN
CONVENIENCE IN HAND
Powered Scrubbing Tool,
Upholstery Brush and
Crevice Tool included for
cleaning fabric covered
items such as:
• Stairs • Upholstery
• Mattresses • Pillows
• Area Rugs
To learn more about the Hoover Platinum Collection™
visit www.Hoover.com ™ ®
Six new vacuums, six new standards of clean, and six
new reasons for Clean Freaks to Rejoice. The Hoover
Platinum Collection™ saves you time and effort while
giving you the confidence of knowing your home is truly
clean. Whether corded or cordless each item is distinctive
in both appearance and performance, offering best in
class cleaning through a combination of innovative
technologies and carefully engineered ergonomic design.
With the Hoover Platinum Collection™ you get fast and
effective deep cleaning so you can move on with what
is next in your day, knowing you have efficiently
accomplished the deep clean you desire. With these six
superior cleaners from Hoover®, it is a wonderful time to be
a Clean Freak, and a terrible time to be a dirt molecule.
EXCLUSIVE HOOVER PLATINUM COLLECTION™ MEMBER SERVICES LINE:
1.877.MYPLTNM (1.877.697.5866)
Hoover®’s Best In Class,
Limited Six Year Warranty
Jul 11, 2009 | Hoover F5872-900 SteamVac Wet/Dry Vacuum
Hoover Upright Steam Vac, 12 amp
  • Check to make sure that the lower dirty water lid is installed and secure and not cracked.
  • Check to make sure the front duct panel is installed on the dirty water tank (this will transition the water from the front nozzle into the tank)
  • Check the filter in the dirty tank lid, clean if necessary
  • Remove the lower tank and look at the motor cover, locate a round hole, you should see a black ring (gasket).
  • with the lower tank removed, turn the machine on to check suction at the round hole, if OK then your problem will be with one of the above reasons
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Jan 12, 2009 | Hoover SteamVac F5914-900 SpinScrub...
We used our Hoover SteamVac F6207-900 for the first time today and it did not suction at all. Please help. It emptied all of the clean water/detergent as I cleaned the carpet, but no dirty water came up...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=639624
Generic problem for all Vacuums
Posted by medglen on Jun 01, 2008
We used our Hoover SteamVac F6207-900 for the first time today and it did not suction at all. Please help. It emptied all of the clean water/detergent as I cleaned the carpet, but no dirty water came up into the empty tank.
Thanks!
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sounds to me that you may have a clog or a vacuum leak in the vacuum line. The suction should be able to pickup the water into the holding tank for you. So please feel free to contact your local vacuum dealer or you can use a wire coat hanger to try to unclog the vacuum but if that fails contact the factory or your local vac dealer. . So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 01, 2008 | Vacuums
Vacuums Logo
166 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Kirk Thompson
Level 1 Expert
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
