Screen keeps flashing and cutting out. If I move it back and forth and find a position where it works ok it may continue to work for quite awhile and even days. It's an Acer Aspire 2680 about 2 years old.
  • 2 more comments
  • sailor2680 Apr 14, 2009
    Thank you. I will try to reseat the cable and report back.
    Ken
    I reseated the plugs but now it is not lighting up correctly. I can see the desk top but it is very, very, very faint. (Before I tried this operation it was lighting up OK.)
    I tried it both with and without the power adaptor.
    At least it is not flashing or cutting out that I can tell. I can see it but it is very!! faint. Mabye the light is burned out. Is there one and how could I tell?
    Sailor
  • sailor2680 Apr 15, 2009
    As suggested by Scrinivas on April 14 I took the laptop to the service center to be repaired.
  • 10,594 Answers
Ok,
Please let us know when it got repaired.
Thanks.
Posted on Apr 15, 2009
  • 1,170 Answers
What I think is most likely is
- you have reloaded Windows fron scratch since the last time the monitor worked properly, but you have not loaded the drivers for the main mboard chipset yet. That can easily cause problems because in that case Windows does not have the proper information about the mboard chipset - either the onboard display adapter is not recognized properly if you are using it, AND/OR - whether you use the onboard display adapter or a card in a slot, Windows doesn't have the proper info about the ACPI/APM hardware support on the mboard, which may cause strange problems such as going into Standby randomly, or possibly blinking video.
- AND/OR - you have an LCD monitor and your monitor is using Plug and Play Monitor in Display - Settings. The problem with that is the Plug and Play Monitor driver was written for CRT monitors, and LCD monitors often can't use some of the settings - either there is no display at all, or the display setting doesn't work properly. The cure is to either never use the settings provided by Plug and Play Monitor in combo with your video drivers that don't get along with your LCD monitor, or, the best solution, you load the proper drivers for your LCD monitor model - in that case Windows by default will not show you any settings available in combo with the video drivers that will not work properly with your LCD monitor.
So, install the display driver.
Hope I helped with the repair of your problem.
An Accept from you is how I get paid.
And a positive feed back tells me how I did with the repair.
Arjun
    Novelist:
  • 133 Answers
Hello Sailor,
This problem might be even due to the short in the power adapter. Try disconnecting the Laptop from the wall power supply and see if that fixes the issue and if it does then you might require a new adapter.
This might not be the issue but there is a possibility, please check and let me know.
Thanks and Regards,
Srinivas
Posted on Apr 14, 2009
  • Srinivas Dhulipala
    Srinivas Dhulipala Apr 14, 2009
    The only other thing that I can think off from the description of the problem is that it seems like its a problem because of the loose contact. You might want to contact service center to get this fixed as this would involve crack opening the laptop.
    Regards,
    Srinivas
  • 1,183 Answers
The screen can display this type of problem , if the LCD cable that attaches to the motherboard is faulty or the Inverter board is faulty.
It would look something line the figure in link below
acer
-aspire-5100-laptop/">http://www.insidemylaptop.com/remove-lcd-screen-replace-inverter-board-acer-aspire-5100-laptop/
Opening and re-seating the cables would require to have a sound mechanical hand. As laptop components are really small.
I would suggest to call acer technical support, and they can give you step by step instructions to remove and re-seat the cable.I tried finding the service manual for your laptop , but the same is not available from acer, as product has been discontinued.
If you need more help ,kindly post back
Thanks
proton
When driving frequently the vehicle will start swinging back and forth like you are moving the steering wheel back and forth you let off the gas and it quits for awhile been aligned and checked why?
was the suspenssion checked out before the alignment was done?? something is loose/worn out. i would be looking at the lower control arms/bushings on lower control arms.something tells me that who ever did the alignment didnt check out the suspenssion the right way or at all. you can not do alignment if stuff is loose.
Sep 17, 2012 | 1988 Nissan Pathfinder
When I turn on my laptop, the screen will turn black then I had to move the screen back and forth to get the screen working
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Mar 11, 2012 | ASUS Eee PC 1005HA-PU1X-BK Netbook
We haven't used this typewriter in quite awhile and the line space buttons keep flashing and periodically beep. Can't turn them off.
Give the silver shaft that the carrier slides on a shot or WD40, turn it off and move the carrier back and forth. Replace the batteries, clean the battery holder if they were cruddy.
If this dosen't work repost this with model # Which lights are flashing and how many beeps.
DickyO
Dec 13, 2010 | IBM Office Equipment & Supplies
The saw blade does not engage when trying to cut
Probably shot. You could buy parts, but now worth the time. Probably stripped the gears.
Jul 02, 2010 | Dewalt DC385B 18v. Cordless Bare...
I am trying to get my 18.5hp 42" cut craftsman DLT3000 to move. The rod in the back is in, and the wheels are still locked up on the transmission. What would cause the transmission to lock up?
At the end of the rod under the battery there is a lever that bolts to the transmission you will need to spray with wd40 and tap it with a hammer back and forth until it starts to move then continue to oil it and move it back & forth with your hand , its stuck in the gear position. if you are looking to get it in the neutral position follow the above procedure these catch alot of dirt and seize up.
May 19, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Computer screen is flashing
dell monitor will work fine and then go black with an internal blue light flashing from the bottom of the screen up. I have checked wires they are ok. I am able to get it working sometimes if I move the position of the screen back and forth or up and down the on button will stop flickering and it will come back on. HELP!
Jun 24, 2009 | HP f2105 21" LCD Monitor
Screen not Working
Ok,
The back and forth motion indicates that the problem is in the interface wiring. Below is a link to disassemble the computer display screen and expose the interface wiring cable:
1) disassemble the lcd screen: http://www.irisvista.com/tech/laptops/ToshibaM35X/Satellite-M35X-display-1.htm
Follow the instruction step up to step 5, do step 5. Now look into the right side of the trough
exposed by removing the keyboard securing strip. There will be a silvery looking cable with a white plug on the end of the wire to the left. The white connector must be pushed completely into the white socket on the motherboard. Use a pair of heavy non cutting tweezers or needlenosepliers to push the white connector into the socket. You can turn the machine on and see if it is improved. If it still is not correct proceed to step 7 and stop following the dis-assemembly.
The flat cable that runs across the LCD panel must be connected fully into it's terminator connector. If the cable will wiggle from side to side using a gentle motion then the cable must be reconnected. Examine the connector that the flat ribbon wire is inserted into. There will be one little ear protuding from each side. You must pull the ears in a rocking motion toward the cable. Use a blunt thin device, like a paper-clip with a rounded end. You may have to use two of them, one keeping one side from moving and the other to push it's ear down. When the two ears are down CAREFULLY pull on the ribbon cable. If it does not move STOP. Try moving the ears in the opposite direction, if they move continue until they are fully loose. If they do not move continue. Again try to CAREFULLY pull on the ribbon cable. Assuming that the ribbon cable is loose, re-insert the ribbon cable into the ribbon cable connector. Keep the ribbon cable square with the connector. do NOT push hard, the cable will stop at the bottom of the connector port. When the cable is in the connector you will use the blunt thin device to push the little ears of the locking bar back into lock position. Now reassemble the unit to step 5. You can turn the machine on and see if it is improved. If it still is not correct, please advise.
I hope that his helps.
Jun 23, 2009 | Toshiba Satellite M35X-S311 Notebook
Computers & Internet Logo
91 people viewed this question
David Payne
David Payne
