Question about Cameras
Can view pics, shutsdown in camera mode, shutter wont close
Camera will allow you to view pictures, but shutsdown in camera mode. also shutter wont shut. is olympus stylus 725sw
  • 126 Answers
Lens assembly is bad must be replaced to make it work again .
Posted on Apr 14, 2009
CAnnon Powershot A630 LCD screen will not light up when trying to take a pic. I can, however view old pics that I've already taken.
First press the DISP or DISPLAY button to see if that corrects the problem. If not, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Nov 09, 2011 | Canon PowerShot A630 Digital Camera
--cannot view anything to take a picture of--the view screen is black but I can see al menu items and can display settings. Flash works. I can see cannon signal clearly when camera is turned on. I am...
The A6XX series is prone to stuck shutter problems, particularly if the camera isn't used very often. Lens lubricating grease can coagulate on the shutter, immobilizing it. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 29, 2011 | Canon PowerShot A630 Digital Camera
When turned on just shows black screen. Used to be able to pwer off and back on and would work. Lens issue? Can view pics on memory card just can't take pics anymore.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 14, 2011 | Canon PowerShot S2 IS Digital Camera
When I turn on my Canon PC 1130 to take a picture, the lcd screen and view finder just show a black screen. Camera is working fine in the play mode. Please help.
Set the camera in TV mode, (delayed shutter mode) set the shutter at 15 sec, click to take a picture and during that 15 secs (like, after 7 seconds) open the battery compartment which cuts contact with the battery circuit. Close the battery cover. At this point the camera works fine ... but only temporarily.... Here is the key to the permanent fix. While the camera is working via the temporary fix, take many, many pictures. Hundreds! I probably snapped 400-600 pics. The idea is to wear down the little patches of hardened oil on the shutter blades. For the next three days I took hundreds of pics each day. Basically, I just aimed the camera at the wall or whatever and snapped off several hundred pics.
Jan 05, 2011 | Canon Cameras
When the camera is in take a picture mode, the view finder is black. When viewing pictures pictures previously taken, they are show on the view finder. Why is it black in this mode?
Dec 06, 2010 | Canon PowerShot S2 IS Digital Camera
Canon elph 880 can display pic's but can't take a pic,,,,screen remains black and new pics are black
Aug 01, 2010 | Canon PowerShot SD880 IS / Digital IXUS...
New pictures I am taking with my camera are showing up completely black. I can view previously saved pics on the SD card on the screen, but any new pics only come up black. Any ideas what this could be?
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Feb 21, 2010 | Canon PowerShot S2 IS Digital Camera
In S mode camera wont take a pic, r09 comes on screen
The r09 is just the display that tells you how many pictures you have in the memory buffer for shooting in continuous mode. There are a few reasons why it might not take a pic in S, but normally it's when it's not in focus. Maybe you have it pointed at something too close for the lens to focus. It also could be that your shutter speed setting is way too fast for the available light.
In S mode, the camera will use your shutter speed setting and adjust the aperature to match the light. If it can't get enough light at the shutter speed set, then it won't expose. Keep in mind this isn't just for exposures that are close to being right, only when the shutter speed is so fast or slow that the exposure isn't in the ballpark.
Try moving your shutter speed up or down.
Jan 03, 2010 | Nikon D80 Digital Camera with 18-55mm Lens
Black screen. Can view previous pics even see icons via viewfinder or LCD but will not take a picture.
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 09, 2009 | Canon PowerShot S3 IS Digital Camera
Canon sd450 - spilled a little lemonade on the camera
maybe the lemonade was sticky and the shutter can't open? otherwise the circuitry could have been fried if you turned it on before it dried inside.
Nov 09, 2007 | Canon Powershot SD450 / IXUS 55 Digital...
Cameras Logo
133 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
