Have observed H2O leaking from front of machine out of door.????and door lid is closed , it will not go if open. There is a tiny chuk out of the rubber and unsure if the rubber part that is around the inside should be replaced and if so how much and whom do I get that knows what to do? thanks front loader Hitachi wash machine HWF 800X necia
    Problem Solver:
Have had the same problem with my HWF 800X. New bellows $150 plus fitting so I use a Bike repair it and used the glue to glue a piece of bicycle tube to the inside of the seal to cover the chip by 1 cm either side and trimmed to the same height as the seal lip.
I then placed a little bathroom sanitized silicon sealant over the repair within the chip, wet down with soapy water on the door glass in the chip area and shut the door. Carefully wipe of any excess with wet finger and repeat. Open the door and let it all cure.
My repair has lasted about 2 weeks so far and seems ok.
I had another problem a couple of weeks ago where the motor functions would not work but would fill and drain - turned out to be $240 worth of motor brushes.
Hope this helps.
Gary01-Perth WA
Posted on Apr 26, 2009
    Sergeant:
  • 187 Answers
  • Hi,
  • Try these
  1. Inspect the water supply connections
  2. Inspect the drain hose
  3. Inspect the water pump
  4. Inspect outer tub for cracks or corrosion
  5. Inspect the tub seal
  6. Inspect the tub bearing
Please rate my suggestion...
Posted on Apr 14, 2009
My dishwasher is leaking from the bottom of the front door. I can't seem to get to the drain filter. Can that be removed? I think there may be a clog in it.
If the leak is from the bottom of the front door than it is most likely the door seal. If the leak is from beneath the unit and appearing to leak out from the front there are many sources for the water.
Check the seal around the door. It may have some residue that has collected prohibiting the seal. The water in the machine actually sits in a tub. The seal on the door prohibits the water leaking as the spray arm rotates.
To test the door seal start the cycle and stop the unit as soon as the machine begins the spray cycle. Open the door and observe that the tub is full but still below the edge. Dry the seal around the door. Place colored paper towels or cloth beneath the door as close to the door seal as possible, Continue with the cycle and observe for water leaks. Stop allow the unit to sit a few seconds open door and observe the seal. You are looking for the location that it is leaking.
If you can confirm that the seal is leaking you can purchase replacement seals, On some models they can be easily replaced.
In my experience I have not seen a filter in the return line. If there is a blocked return hose the unit would not leak. The tub would remain filled after the cycle. There is an overflow switch that prohibits the tub from overfilling if the tub has not emptied between cycles.
Nov 21, 2015 | Dishwashers
Error message dE
hello there and thank you for choosing fixya
dE - Lid door open error Lid /door isnt fully closing or is open during wash cycle. Close lid.
· Check wiring harness
· Check lid switch
· Check unbalance switch
· Check circuit board
Jul 28, 2011 | GE Energy Star WCVH6260F Front Load Washer
F1 flashing on both doors on my Fisher&Paykel dishwasher. Just turned on by themselves.. was not running either top or bottom at the time.
F1 - on dish drawers means there is a H2O leak on the machine which has activated the flood sensors.. Causes
Lid not closing.
??¢ Overfilling.
??¢ Foaming.
??¢ Not draining.
??¢ Lid seal damaged.
??¢ Dispenser or water softener or their seals leaking.
??¢ Damaged water inlet or drain hoses.
??¢ Leaking heater plate or motor seals, or drain o-ring seals.
??¢ Yoke jammed or broken.
??¢ Inlet hose to inlet valve connection loose.
??¢ Inlet valve body leak.
??¢ Heater plate damage (chipped enamel).
??¢ Dry F1 - PCB mains filter, harness or connectors, electronic controller
May 09, 2011 | Fisher and Paykel 24 in. DD-602 Built-in...
My Kenmore 22712 Top load will agitate, but when it switches to the spin cycle I get nothing. The motor wont run and the tub doesn't spin.
open the lid a lttle and close it down a few times,if you don't hear a clicking sound when it closes you have a bad lid switch,or open the lid and stick a screw driver in the hole where the piece on the lid goes down into when the lid is closed, if it doesn't click and the machine doesn't run then the lid switch is bad.,they don't want the machine to run with the lid open when it goes into the spin cycle,if you send the full model number located beneath the lid when it's open on the back panel under the lid.let me know how you make out
Jan 13, 2011 | Kenmore Washing Machines
What is sensor magnet in LG 6.5 kg washing machine? Recently I got a dE error and when technicians attended, they said, there was problem to closing door lid. To resolve this, technician replaced sensor...
The machine has a small magnet on the front of the lid. There is a sensor (Hall Effect probably) in the electronics block that senses if the magnet is there (lid closed) or not there (lid open). They aren't that well attached and seem to fall off and wind up in the wash, which means they get lost when the washing is being hung out.
The machine will not start without the lid closed you get a dE error code which means the lid is not shut. You can trick it temporarily by putting a small round magnet inside the front housing if you don't have a proper replacement, as the real one needs to be quite strong. Not sure what they cost, my husband just did the 'trick' to our daughters machine, but a small button magnet wasn't strong enough to trip the sensor from the lid position, he had to stick it right next to the sensor.
Shouldn't be that dear, you can buy blocks of very powerful neodymium magnets in varying sizes for under ten dollars.
Sep 09, 2010 | LG WFT1071TP Top Load Washer
Replace LG washing machine seal
Hi
When you open the machine door, you will see a manufacturer's badge. Record the model number and call around to order the door seal from your local parts vendors. Have the replacement seal ready when you are changing the seal. If you remove the seal and then go to source it, then you might not remember how it was put on initially.
To replace door seal, First turn off machine and unplug from its power source.
Next remove top lid. Two screws in the back of the top lid and you can slide the lid back and up to remove. See if you have a clear view of the door seal from above the machine and see how it is joined to the drum mouth. There would be a metal ring holding it in place. Locate the screw which tightens it and unscrew it to loosen the ring.
Next the wire ring which you have already seen on the front of the seal needs to be removed. These are normally spring loaded. Feel around the ring until you get to the spring tensioner. With a flat screw driver, stretch the spring to pull the ring out from around the seal.
Now observe how the door seal is clipped around the front panel of the machine. The seal has a groove which fits snug agains the rim of the front panel. You can now remove the seal by pulling around the edge.
Now go back to the top of the machine and do a similar thing to remove the seal from around the drum. Make sure you observe how it had fitted on originally, and also observe if there are any differences between the top and bottom of the seal where it sits on the door. There normally is a difference.
When replacing the seal in the reverse manner, make sure you fit the seal correctly around the lips of the drum and the front panel. make sure you also correctly tighten and refit the rings to hold the seal in place.
Once you have finished run a couple of quick cycles without cloths, to make sure there are no leaks and that the seal is fitted properly.
Good luck.
Ash
Nov 09, 2009 | LG Washing Machines
Du f flashes as code on whirlpooll whasher??
The F30 error code (dU) will flash when the dispenser motor cannot be driven to its proper position.
Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked.
It will try to unlock the door 6 times before displaying the error.
Door Lock Mechanism broken.
Check Door Lock/Switch Assembly for foreign objects
Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Door Lock/Switch Assembly Failure
If it is a cabrio:
dU flashes if the following conditions occur:
Excessive force on door lid is preventing lock bolt from retracting.
Wash media buildup is preventing lock bolt from retracting.
Machine/motor control cannot determine if door lid is in an unlocked state.
TEST #8 Door Lid Lock
Perform the following checks if washer fails to lock (or unlock).
1. Perform Manual: Door Switch and Manual: Door Lid Lock tests.
2. Remove the console to access the machine/ motor control assembly. See Accessing & Removing the Electronic Assemblies.
3. Visually check that the P12 connector is inserted all the way into the machine/motor control. If visual check passes, go to step 4. If visual check fails, reconnect P4 and repeat step 1.
4. Check the lid lock motor winding and switches by removing P12 from the machine/ motor control and checking the
resistance values....
Component/Resistance Unlocked/Resistance Locked/Contacts Measured/Contacts Measured:
Motor Winding/35 ±5 O/35 ±5 O/P12-2/P12-3/
Lock Switch - Home/0 O/Open Circuit/P12-1/P12-4
Lock Switch - Lock/Open Circuit/0 O/P12-1/P12-7
Lock Switch - Lid/Lid Closed = 0 OLid Open = Open Circuit/Lid Closed = 0 O Lid Open = Open Circuit/P12-1/P12-5
If resistance values are good, go to step 5. If switch measurements do not match the values shown in the table for unlocked (or locked) conditions, a problem
exists in the door lid lock. Replace the door lid lock.
5. If the Manual: Door Switch or Manual: Door Lid Lock in step 1 failed, then the machine/motor control has failed: Unplug washer or disconnect power.
Replace machine/motor control assembly. Perform the Manual: Door Switch and Manual: Door Lid Lock in step 1 to verify repair.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
LG Top load fuzzy logic washing machine DE problem.
I have the same problem. please let me know if yours got fixed
Sep 11, 2009 | LG Washing Machines
Washer flashing dl on the screen
"dL" indicates Door Lock Failure: dL flashes if the following conditions occur:
Door lid is not closed completely due to interference.
Wash media buildup is preventing the lock bolt from extending.
Machine/motor control detects open door lid switch when attempting to lock.
Machine/motor control cannot determine if door lock is in a locked state.
Check for lock interference with lid or lock bezel
Dec 14, 2008 | Kenmore Elite 45986 Front Load Washer
Washing machine makes beeping noise
It sound like a lid switch problem .A defective lid switch will notice of an open door when actually door is physically closed, and will prevent washer's spining and function at all. The switch located inside the machine near the door frame. You should open the top panel (open 2 screws and then slide it out) and you will have an access to it . You can test it by multi-meter (it is an on/off switch). In case of a deffective switch, it should be replaced. Be aware that you should remove machine's power cable before starting your test !!!! Good luck !!!
May 30, 2006 | Tricity Bendix AW1000W Front Load Washer
Washing Machines Logo
191 people viewed this question
Top Washing Machines Experts
