Question about Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM Combo Drive
Combo drive opens and closes automatically
Hi, i am using combo drive samsung make model no sh m522c/idbh. Recently it started opening and closing automatically. sometimes press button is not functioning. assisst me a solution for this
    Scholar:
  • 57 Answers
Arav you will have to open this unit up, sounds as thought the units slider has passed the spring sensor. with the unit open manually open the tray, there should be a spring lock release on the right with it upside down facing you. slide the tray all the way back in until you hear it click and lock. You may want to do this several times to make sure no plastic pieces have broken off. If you see or find a piece come out then achances are the spring lock mechanism has snapped, not uncommon on this drive. The screws are easily located on the bottom.
Posted on Sep 12, 2007
SOURCE:
My DVD/CDW combo SH-M522C can read CD but can't read DVD!!!
try to run the Microsoft Fix it option to delete the upper and lower filters and if this does not work, update the firmware and try to use a lens cleaner. if nothing works including system restore, it might be time to get a new drive. hope this helps
Apr 16, 2011 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Please help me to rectify the problem as under Windows cannot load the device driver for the CD DVD combo drive TSSTcorp CDW/DVD SH-M522C. The driver may be corrupted or missing. (Code 39)
Hi rrcholan,
  • Optical drives never require a driver when used in Windows other than the one packaged with the OS. So, I would take the following steps.
  • First, open the device manager, uninstall the sh-m522c, then
    • Download and install CCleaner (free) from Piriform- http://www.piriform.com/ccleaner
    • Run the cleaner to remove old un-needed temp files
    • Select the StartUp tab and look for any programs that you know you installed but no longer use or need, and disable them. Caution, do not disable any system files unless you absolutely know what they do and that you do not need them.
    • Run the Registry cleaner, when asked if you want to backup the registry, select YES, and save to a file you will remember just in case. I have used this program hundreds of time on many different system and it has never caused a problem, but you want to be safe, backup the Registry.
    • If asked about a particular file that it wants to clean, select "yes to all"
    • Reboot
      Windows should see the drive and reinstall the drivers.
      If this helps resolve your issue, would you please rate the solution. If this does not help, please leave a comment giving me more information on the problem and I will try to help you further.
Dec 29, 2010 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
My Samsung CD-RW/DVD-ROM Combo Drive could not support dvd ?
try these steps
) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
* HKEY_LOCAL_MACHINE
* SYSTEM
* CurrentControlSet
* Control
* Class
* {4D36E965-E325-11CE-
BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
Jul 05, 2010 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Is the SH-M522C/BEBN) CD-RW/DVD-ROM Combo Drive a DVD writer
It can read DVDs but cant write.. so its NOT a DVD writer..
Nov 15, 2009 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
How to install samsung sh m522c without
goto samsung website you should be able to find the driver you need and dwn load it. If you don't have internet access right there you can download it from another computer with web access onto a flash drive and put it on your computer.
Oct 30, 2009 | Samsung SH-M522C/BEBE 52X32X52X/16X IDE...
Eject Problem..
1. right click on the drive. 2. press 'Eject' option. this will intern send the software interrupt to the drive to open it, if your cd-drive 'button' is not working. thanks.
Jun 08, 2009 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
POWER CALIBRATION ERROR
Power Calibration error indicates that the drive hasn't been kept clean and is unable to guarantee a good write to disc...
I recommend a wet and dry CD/DVD Cleaner disk with Alcohol on the wet side (Like Tape Head cleaner liquid) and let it dry for a minute then run the disc again... if it still happens the drive is on its way out.
May 25, 2008 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Problem with my combo dvd
May not close all the way, somthing is jammed in the back of it possible or a disk is not in all the way (Press down more)
Nov 29, 2007 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM Combo Drive Logo
103 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
