Question about KitchenAid K5SS Heavy Duty Commercial Stand Mixer
KichenAid K5SS Speed lever does not stay in ''off'' position. When the lever is placed in the off position it moves to speed 1 immediately.
  • Anonymous Mar 15, 2014
    The speed control lever will not move
  • 135 Answers
Hi Burt. Go to mendingshed.com, look up kitchenaid mixer parts. Near the top of the page, locate the free kitchenaid service manual. Download this valuable manual, it will help you to diagnose and repair your mixer. Mending Shed also sells KA parts. If you order parts directly from kitchenaid be prepared to wait for at least a month for the parts to arrive.
If this solution has assisted you, please rate it. Good luck! ricardok45
Posted on May 02, 2009
My mixer wont stay turned off it springs back to number 1 speed so i have to turn off via plug socket
Shelly, usually this can be repaired without needing ANY parts! Its pretty simple but you do have to tear apart the mixer. Here is a link to the service manual: http://ep.yimg.com/ty/cdn/mendingshed/kitchenaidservicemanual.pdf
99% of the time you are dealing with a loose screw. So take the mixer apart, once you have done that you will find the speed control lever with knob has a screw that holds it in place and in contact with the spring. That screw can work loose and if not all the way tightened will allow your mixer to pop back into speed one. Simply tighten the screw and see if the mixer will operate correctly.
If the speed lever is working through all 10 speeds correctly re-assemble the mixer. If it does not correct the problem you will want to buy the speed control lever kit.
This will include a new speed control lever with knob, the spring, link and a gearbox gasket.
KitchenAid Mixer Speed Control Lever Kit 4176230
The part number you will be looking for is 4176230, it is only about $7 plus shipping of $3.25.
-Colleen @ Mending Shed
May 14, 2015 | KitchenAid K5SS Heavy Duty Commercial...
How do I fix a speed control switch that doesn't stay in the off position?
My daughter had this problem with her mixer. The problem is that the screw that holds the speed lever has come loose. To get at the screw you have to dismantle the head. It took me about 1/2 hour to take it apart and put it back together. It is not that hard, except that you have to drive a pin out of the beater shaft. Works great now.
Jun 01, 2014 | KitchenAid Food Mixers
Funky speed
Could also be a broken wire to the control plate. It's not very often the plate itself. Just looking in there while operating the lever may reveal something. The shaft at the bottom that moves the plate closes a set of points to start the mixer, maybe the points are loose and not closing when they should. Just be careful operating it with the cover off and alive.
Dec 28, 2013 | KitchenAid K5SS Mixer Speed Control Plate...
Mixer works fine with speeds up to 6, but changing to 8-10, speed stays the same.
Sometimes can be caused by running too fast on the lower speeds. Should be 13 to 15 revolutions in 15 seconds on speed 1 then a slight increase only on speed 2.
Aug 01, 2013 | KitchenAid K5SS Heavy Duty Commercial...
The speed lever won't hold a speed
The spring attached to the speed control switch has come off or broken. Does the switch stay in one place when you move it or does the switch move about freely. I need a little more info to be more help.
Feb 23, 2013 | KitchenAid Classic Stand Mixer
SPEED CONTROL ALWAYS ON HIGH
Speed control plate at the back is stuck in the high position or you need a new phase board. That's the small PCB under the back cover at the top.
Nov 24, 2012 | KitchenAid K5SS Heavy Duty Commercial...
Model K5SS -- The speed control lever will not stay in the slowest position - STIR - but will pop over to the next position - 2. Can I adjust anything to fix this problem?
Open up the Motor Housing and inspect the Switch Lever with Stud.
The Lower Gearcase has many depressions which allow the stud to
snap into it when the Speed Selection lever is moved. If the Stud
is worn out then there isn't much you can do but replacing it.
3184193 is the Switch Lever And Stud part number for your model.
Jul 03, 2011 | KitchenAid K5SS Heavy Duty Commercial...
I could not regulate the speed as usual. Hubby removed the phase control board and a new one was purchased #9706595. It arrived and was installed and now the mixer won't even turn on. HELP please.
The K5SS is very similar to the 5-QT Artisan KSM150.
You need to adjust the mixer speeds. Obtain a copy of the K5SS Repair Part List from Kitchenaid.com. Remove the screw holding the End Cover and locate the three screws from the Control Plate. All three (2 top left and right, and 1 bottom) must all be adjusted. 1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
anymore. Leave the bottom screw alone for now.
2. Use a dab of white paint or paper whiteout to mark the positions of the Phillips screws.
3. Plug in your mixer and Set the speed selector to "Stir".
4. Turn each top screw One full turn couterclockwise (alternating between Left and Right)
Keep making one full turn at the time (for both left and right) until the motor starts running.
5. Put your hand near the Agitator shaft and allow it to brush your finger slightly. Use your
watch or clock and start counting the number of times the shaft touches your finger in
60 seconds. The correct count should be 60 RPM (Rounds Per Minute). If it is less
or more than 60, give each screw 1/4 turn counterclockwise or clockwise and start counting
again. Now tighten both lock nuts.
6. Set the speed selector to "6" and turn the bottom screw either clockwise or counterclockwise
to achieve a speed of 180 RPM.
For your reference, the planetary RPM's for the 5-qt. tilt-head Artisan Stand Mixer are as follows:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jun 28, 2011 | KitchenAid K5SS Heavy Duty Commercial...
Kitchenaid stand mixer will not stay in the off position.
There is a spring, item #4, which hooks on to the bottom of the control plate, item # 25, and pulls it back when you move the lever to off. Remove the rear cover and see if that spring is still connected to the control plate and to the lever arm, Item # 3. Here is the diagram:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212369.pdf
Mar 31, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Kichenaid Mixer K5SS Electrical Problem - All gears have been removed. Motor shaft turns easily. With speed lever in off position, 0 volts go to motor via red and white wires. With lever in any other speed...
I had this problem also: power to the motor, motor not running.
Solution was simple: remove the 2 stators things from the sides of the main housing, clean all the black dust off them, re-insert and everything works fine.
The dust problem is similar to model train sets that I had as a kid at Christmas, the black dust acts as an insulator, preventing power from travelling between two metal parts that you'd think otherwise would conduct.
Aug 26, 2009 | KitchenAid Food Mixers
KitchenAid K5SS Heavy Duty Commercial Stand Mixer Logo
397 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
