Printer 2710 not talking to computer - Office Equipment & Supplies
  • 523 Answers
Well when the printer is not talking to computer the problem will be :
Either the cable is not good or the port of the computer is not good, or the drive corrupted.
But first is your printer connect to computer throught usb cable or Ethernet network cable?
if its connected through usb cable check this:
check the cable is good, try test another cable
check the port of the computer where the cable connected, change it to different port in the computer could be become bad.
But the most important is to reinstall the driver Coz may be you lost some files from drivers and this happens usually so try to reinstall the driver and test it.
Now if its connected through Ethernet network cable:
check the one above + check the ip address of the printer
LEt me know wat type of connection you have so i can help you better.
Posted on Apr 14, 2009
Are there any software for windows 7 for
No, there are no drivers for this printer with W7.
However, we can add the additional drivers and make it print.
Please click on Start on the computer----Devices and printers----Add a printer----Add a local printer
----Select Use an exhisting port-----Please select LPT 1 and from the drop down selet USB 001
(Please do not proceed further until we get USB 001)
----Next----On left Select HP----
On right select HP Photosmart 2710 or any related Photosmart printer series----
Next----Next----Select do not share this printer----Next----Print a test page----Finish
Jul 01, 2010 | HP Photosmart 2710 All-In-One InkJet...
How to connect additional computer on??
use cross cable to 2 computer &give the ip this printer .or share it installable pc printer
Apr 29, 2009 | HP Photosmart 2710 All-In-One InkJet...
Help connecting HP 2710 wireless to my PowerBook G4
No, there is no fee. I will help you figure it out. However looking thru the HP manuals is the HP 2710 your printer model number or your notebook? I found manuals on notebook.
Don't forget to rate this solution before you log out.
Jan 26, 2009 | HP Photosmart 2710 All-In-One InkJet...
2710 all in one printer
I have the same printer; when installing it asks if I have a PC or Mac? Of course I have PC so I click PC. Another area you can check is the printer driver itself. Make sure the PC driver for the printer was installed. Then re-boot p-rinter, computer and all. Hope this helps.
Jul 29, 2008 | HP Photosmart 2710 All-In-One InkJet...
HP 2710 printer
hello menzo
see if the 2710 faqs offers any help .
riz.
May 19, 2008 | HP Photosmart 2710 All-In-One InkJet...
The printer will not scann to the computer
Are you able to print? I suspect so. If not your probably looking at a bad cable or corrupt windows drivers.
The director software uses it's own system to talk to the printer via scan / fax though printing is controlled by windows itself. Since scan and fax are the same function to the printer, essentially i would start by re-installing the director software.
1. Remove it via add/remove programs, don't reinstall over. It may work but you'll likely just waste time, you want all it's files gone and replaced with new ones.
2. If that has no effect remove the printer from Control Panel > Printers. Also remove the scanner device from Control Panel > System > Hardware > Device Manager >
3. Reboot, windows doesn't really remove things till you shut it off.
4. Install the director software again, hook up the printer when asked.
Again:
If you can print at all communciation with the device is perfectly fine from a hardware perspective.
If you can fax without the computer then your scanner and such is fine from a hardwware perspective.
So your problem is simple software, either windows devices install or hp director. Both simple to remove and re-input.
It's very
Nov 09, 2007 | HP Photosmart 2710 All-In-One InkJet...
Dell 420 notepad and HP All In One 2710 printer
Are you trying the install while connected to the printer with USB cable ?
Jul 04, 2007 | HP Photosmart 2710 All-In-One InkJet...
k24674
jasbo
jasbo
