Question about Garden
My son and his friend have a tecumseh 5 hp ohv 17 go cart. ever since a neighbor change the oil, which he tipped the engine over to empty the oil out instead of using the drain, the motor only runs with it primed. once the prime burns out, it quits. a little bit of fresh oil came running out of the carb. what to do?
  • 155 Answers
Remove and clean out the carby bowl it will probably be full of oil , you cant tip a 4 stroke engine over for that reason.
Posted on Jul 25, 2009
What is the valve clearance on a 13.5 hp Tecumseh ohv 130 motor?
Set the intake and exhaust both at .004. This should get you running smooth. GOOD LUCK FRIEND.
Jun 06, 2015 | Tecumseh Garden
What causes a lot of gas in oil on 8.5hp B&S
This would be caused by a sticky needle valve on the float in the carburetor.You have three cures 1. remove and clean the carburetor internally. 2. replace the carburetor with a new one. 3. or most simply buy and install a fuel shut off valve and turn it off when not in use. make sure you change the oil 1 4 ID LINE GAS FUEL SHUT OFF VALVE TECUMSEH BRIGGS
Jun 03, 2014 | Briggs & Stratton Briggs Stratton Intek V...
Is 5.0 Hp Tecumseh Ohv Engine a 2 strcke engine ?
a 2 stroke has no oil in the crankcase (motor) a 4 stoke has oil in the crankcase
Jan 02, 2011 | Garden
Tecumseh 16 hp ohv adjustment
It is always best to have the exact model number of the engine you want to work on. Here is a helpful link:http://www.tecumsehpower.com/CustomerService/BSI.pdf
Jul 03, 2010 | Tecumseh Enduro Vertical Engine 16 HP 1in...
My propane generator engine has apark and gas
For a quick test.
Check engine oil.
Remove wire from low oil sensor and see if it starts every time.
If that works change oil and replace low oil sensor.
Hope this tip helps to solve your problem.
r/
David
Jan 19, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Canaballing parts
Hello tim38663:
Depending on the Engine Model and Spec this Tecumseh Usually has the Same External Parts as a 15 HP to the 18 HP Single Cylinder Tecumseh Engines.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 04, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
How to change the oil. Without turning the machine upside down how can you changew thew oil? There is no plug that I can see.
I don't know what brand/model you have, but mine has a Tecumseh engine, and you empty the oil by removing the oil filler tube and tipping the engine to the side (per owner's manual). There is no plug.
Mar 23, 2009 | Garden
Garden Logo
282 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
