Question about Whirlpool DU806CWDB Dishwasher
Whirlpool Dishwasher Stuck in Cycle
My Whirlpool DU8750XB1 dishwasher gets stuck in a cycle when it runs. It looks like it happens at the same point in the cycle before it reaches ''rince'' and during that time, the ''delay-water heating'' light is on.
Could this be the thermostat? I believe it has 2 of them. A regular and a hi-limit stat. Are they easily replaced? I looked at the underneath of the unit but can't see them. Are they housed somewhere else?
Or am I way off?
Any help is appreciated.
  • Official Brand Answer
  • 408 Answers
Hello FishNYC22, we're sorry to hear about your Dishwasher. Unfortunately we are not able to provide technical assistance. If you would like for us to schedule service for you then please email us your name, phone number, address, the model and serial number and the website you were contacted on (Fixya.com) to Whirlpool_Digital@Whirlpool.com.
Posted on May 24, 2017
SOURCE: whirlpool dishwasher drainage problem..
This sounds like a bad timer. The timer is what tells the pump to drain at specified times. If it gets a bad contact, that timed cycle won't happen.
PS: Do you know for sure that the drain is occurring in mid-cycle? If not, you may just have an obstruction in the drain and/or anti-siphon valve (where the hose connects under the dishwasher.
Posted on Jan 03, 2008
SOURCE: Whirlpool dishwasher Fault codes
Fault code related to Flow meter. Cleaned the connections and reconnected.It worked fine for 2 weeks and failed again.Replaced the water chamber which contains the flow meter and the issue is resolved. The water chamber cost me 87euro including postage from Quinnspares in Co.Derry Ireland.
Posted on Jan 28, 2009
SOURCE: Stays in wash cycle Whirlpool Dishwasher Du1050SS
my repairman contacted whirlpool about my washing machine staying on
wash.. to his surprise.. and mine.. and his co=workers.. this is the answer,
it worked.. and we have never heard this before.
In your original istallation booklet it tells you to let the dishwasher run til its complete
the first time you use it as it may rinse twice... my original installation man told me this also.
however.. if you suffer a "blip" in your electricity.. it could put the little dishwasher "brain"
out of whack.. it can run as long as 3 to 4 hours on wash to reset itself.. if you stop it
(like others have mentioned.. and which I did also).. it doesn't complete the reset and it
will attempt to do it the next time..
answer?.. just let it go once as unnerving as this is.. it works.. They did mention that
if it went to 5 hours.. call your repairman because you need a new mechanism.
karen in Dothan
Posted on Apr 03, 2009
  • 74 Answers
SOURCE: water does not drain out completely on our model
there is a PROBLEM with the pump.it is most likely clogged,in which case,it must be removed and cleaned.the pump might also be faulty,and so must be replaced.
Posted on Oct 24, 2009
  • 120 Answers
SOURCE: Whirlpool dishwasher wont change cycles
wow, good move with the heating element. most folks don't know about how that relates. if that stuff is good, it must be the timer. or at least the small motor which turns the timer. good luck
Posted on Nov 08, 2009
Samsung get stuck at 40 minute cycle
I think the dishwasher gets stuck at the point where it is supposed to heat the water. If it can't heat the water (because the heating element isn't working, or because the heater relay inside the controller is bad), then it may stay there indefinately. In other dishwashers, the timer/controller will give up after 3 or 4 hours and finish the cycle. In others, the dishwasher will shut down and indicate an error condition.
Sep 20, 2014 | Samsung 24 in. DB5710DT Stainless Steel...
Mod DP1040XTXQ6 clean light does not come on
If your Dishwasher is stuck in a cycle check the following
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle.
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace timer/electronic control board
God bless you use the VOM..
Apr 05, 2013 | Whirlpool DP1040XTX Portable Dishwasher
Dishwasher stuck in wash cycle
see this causes and fix it. God bless you
.Float Switch
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer /electronic control 10_17_2012_1_06_02_pm.jpg
Oct 16, 2012 | Whirlpool Dishwashers
Need reset sequence for dishwasher
see this causes, use the common sense.God bless you
Dishwasher Stuck in a Cycle If your Dishwasher is stuck in a cycle check the following
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle. Check the tutorial and the video for checking this part.
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer / electronic control.
Sep 19, 2012 | Whirlpool DU1055XTS Built-in Dishwasher
HI our Indesit IDE 750 dishwasher gets stuck on the first cycle and the timer doesn't count down. Switching it off and restarting drains the water, but it gets stuck at the same point in the cycle
This sounds like a heating element issue, If the water doesn't get warm it just keeps trying to heat but won't advance past this point until it has reached a set temperature. You dishwasher may or may not be fitted with a thermal overload that may have tripped, Unplug the dishwasher, Remove the lower kick panel and look for a small circular metal sensor with 2 or 3 wires on it attached to the basepan of the dishwasher, Check to see if it has a red button in the middle and if it's there push it then re-assemble and try again, otherwise it's a visit from the serviceman unfortunately.
Mar 04, 2012 | Dishwashers
My Whirlpool dishwasher is stuck on the clean cycle?
If it continues to run without any alarms or flashing light, I would assume the heater is packed up. It is looking for the water to reach the correct wash temperature.
Try to run on the cold water cycles and see if there is any difference.
Mar 21, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishwasher will not run through its cycle
Hi
If the cycle doesn't complete, check these:
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Please revert for further assistance and Do rate the solution as "FixYa" if found useful.
Thanks
Rylee
Mar 26, 2009 | Dishwashers
Whirlpool d/w is stuck on wash cycle
Is it filling and emptying at the same time???? If not could be a heat problem. How long do you leave it running for?
Jan 03, 2008 | Whirlpool 24 in. DU1050SS Built-in...
Dishwashers Logo
222 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
