Question about Yamaha RX-V995 Receiver
RXV 995 SUB output is DEAD
I bough a 995 on craigslist. The sub output is dead. Yes, I have it turned on in the menu and have set to "both" mains & sub.
I have tried different subs to make sure. I have a rxv 2095 so I know the product. What would cause just the sub output to die? Ths other outputs work fine. Just the sub port is dead. Lose solder joint or worse?
Would the sub out be seperate from the main out signal? I am using the main out as sub signal port. It works fine. Have at it...
  • translunar May 03, 2009
    Update. I have found during testing that the sub output does in fact have signal. Its the rca connection that is bad. If you pull down on the cable you get sub output. When you take the pressure off, its gone. I tried different cables with minimal difference. Can I fix this by modifying the rca cable? Making the center pin "fatter" so it will make a better connection. Or should I pay a service center to solder in a new terminal?
  • translunar May 11, 2009
    Update....
    I removed the top of the unit. I then took my multi meter and checked for signal. There was no signal at the solder joint for the RCA jack. I was confused, as I was able to get signal by pulling down on the RCA cable. I put the cable back in and plugged the unit in to AC power with the top off. I played an FM station and tested again for signal, There was signal when torque was applied to the cable! I could physically see the solder joint move when I pulled on the cable. Simple fix...just re-solder it....NOT! I de-soldered and cleaned the area. Then I re-soldered it. Well...the solder was not connecting to anything. It looked good, but no signal. De-solder and clean....check for signal......nothing!!! Ok, I get it now. The etched path on the circuit board was missing right around the solder joint. The board looks like it was removed before I got it. Someone tried to fix it. Well I finally fixed it by drawing my own signal path with a strand of wire from a speaker cable. It aint pretty. But it works, and the sub hits hard and clean. One more thing...I found the speaker ohm selector completely void of solder. It was sparking when touched. So, I reached in and pulled the swithch right off the board. I unplugged the AC power and removed the board. I soldered it back together and its fine now. I got a great Yamaha for $65.00! It kicks *** and was worth all the insanity. I would do it again! That is what makes it so special. The thrill of the fix is addicting!
    Brigadier General:
  • 8,546 Answers
If there is a real failure in the Sub Output it would indeed be unusual. I'd still sift carefully through all of the settings. The Sub Out is very likely to be its own unique channel so I would try something that bypasses multichannel decoding entirely, like plug in something low-bass-rich to the Subwoofer (IN) at the External Decoder area on the left rear of the unit. Press Ext. Decoder and see what comes out of the Sub output. This bypasses all DSP and could prove if the Sub Out really does work.
Does it not work in speaker level setup either? That at least would eliminate any source issues.
Posted on Apr 14, 2009
  • David Dunn
    David Dunn May 03, 2009
    It does sound like a simple break in a conductor. If it's inside it may not be easily accessible to to for examination or repair.
    One thing you don't want to do is rig it so there is torque or mechanical stress on the RCA connector. Eventually soomething would have to give and the price of repair never goes down as the damage goes up.
    Is the outer ground (shield) connection tight enough on the RCA cable? Either the + (pin) or - (outer) connector making bad contact will give the same result. Some RCA cable have visible multi-tabbed outer conductors that can be tweaked a little to be tighter on the jack. You might luck out an orientation that gives good contact.
  • David Dunn
    David Dunn May 11, 2009
    Great fix. Thanks for the update.
Hi i want to restore factory settings my rxv 995
(input mode key)+ ((AM/FM key) lastly Press (power key)
When diag menu appears select 8
when sub menu appears select RESERVED
use tuning up/down at MAIN MENU and
program up/down to move for SUBMENU
Sep 13, 2013 | Yamaha RX-V995 Receiver
Denon avr2805 no sub output
I think you need to set the front speakers as "small" in speaker setup menu.
Nov 27, 2011 | Denon Audio Players & Recorders
I have the Subwoofer plugged into the output and have it turned ON but it's still not working!
It only drives a self-powerd sub.
The manual...
http://www.retrevo.com/support/JVC-RX-8010VBKC-Receivers-manual/id/315dj079/t/2/
Page 17:
Setting the Subwoofer Information
Register whether you have connected a subwoofer or not.
Before you start, remember....
• There is a time limit in doing the following steps. If the setting is canceled before you finish, start from step 1 again.
On the front panel ONLY:
1. Press SETTING repeatedly until "SUBWOOFER" appears on the display.
The display changes to show the current setting.
2. Press CONTROL UP / DOWN to select "YES" or "NO."
• Each time you press the button, the display alternates between "YES" and "NO."
YES: Select this when a subwoofer is connected.
NO: Select this when no subwoofer is used.
Note:
You cannot use SUBWOOFER OUT ON/OFF on the front panel (see page 14) and adjust the subwoofer output level (see below) when "SUBWOOFER" is set to "NO."
Then continue with setting its relative level and other things.
Feb 06, 2011 | JVC RX-8010V Receiver
I'm setting up a new 42KE5300 and when I turn it on it goes to an LG logo with time input field. I can't enter the time and I can't get past this screen!? The screen flashes and the logo turns upside down...
LG has a general manual that is supposed to cover most of their recent European region models. On page 170, it says if you are receiving a digital TV signal while in AUTO mode, the time is set to GMT plus a time zone/country offset that you can program in manually.
Have you verified that your remote control is working? If you can't turn the set on or off with the remote control, it may have a dead or improperly installed battery (I know it's "new" but I have seen dead batteries in new devices before).
According to the manual (page 76), you should be able to bring up the primary menu by pressing the Menu button, then you can press one of the four-way navigation buttons to step to a sub-menu. Next, you press OK to select the sub-menu. Use the up and down buttons to select the menu sub-items (these are not the up and down buttons on the four-way selector). If none of this works, and you have a known good battery in the remote control, then you probably have a defective product or it is locked into some sort of store demo mode.
Jan 16, 2011 | LG Televison & Video
Subwoofer has no sound but power light is on. also rca cable is good
run through the settings and see if by mistake you turn the output to the sub off
Nov 07, 2009 | Sony STR-DE485 Receiver
I have a yamaha htr-5240 receiver. Also have a 6 speaker polk-audio surround set.Center,2 rear,2 front,& the subwoofer. The sub is a psw-250 with no sub out or LFE.I can't figure out what i've done...
First, look at the sub, their should be a switch for "auto" "off" "on" switch it to "on" Then use the Left input on the sub not the right. Left is for mono. Now, if you still dont have any sub, disconnect the RCA at the receiver and touch the end of the RCA, if the sub is on, you will hear a loud humm. Now, go back into the receivers Menu and go into manual setup, find "Audio" and select "Auto". That should do it. If not, put the receiver on "Tuner" and set the sound to 7 channel stereo (I'm not sure if the HTR series has this) or "Adventure" I'm a Yamaha RXV series Dealer so the names may differ. (check in manual for audio surround settings) Anyway, this should let you know if you've got all your spkrs working. Then make sure your TV's external audio is set to "Fixed" (it may be called audio out) depends on TV type. Scroll thru TV's audio menu. If you still have problems post a comment and I will help some more. Hope this helps
Jun 21, 2009 | Audio Players & Recorders
Want to connect my RCA sub to my yamaha htr-5940 reciever
Subwoofer needs to be enabled through menu on Yamaha. LINE OUT might be turned off or Subwoofer volume set to low or off... (-db level) kinda thing...speaker wires are usually always live etc...
Feb 03, 2009 | Yamaha HTR-5940 Receiver
Sub Problem with Dennonavr- 1907
Go into setup and make sure sub is turned on and set sub for LFE + main otherwise sub will only work with Dolby Digital LFE signals. LFE plus main setting will allow sub to output low freq's that would normally go to Front Speakers. Refer to Owners manual setup Info.
Feb 11, 2008 | Denon AVR-1907 Receiver
Yamaha RX-V995 Receiver Logo
436 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
