Philips model# 27PT31, only turns on manually, no remote
Hi there. My TV doesn't respond to the remote control for turning it on and off. Volume controls work as do channel controls. I just purchased a new universal remote and cannot set it up because when it finds the right code, it's supposed to turn off, but it can't...does that make any sense? Please help. Thank you.
  • 1 more comment
  • laurenbro Sep 12, 2007
    Thanks.
    Yes, the TV definitey turns on and off manually. Could it be that there is dust on this command processor IC?
    It's weird that the channels can change and the volume can be controlled, but the darn thing just won't turn on or off...
    Ok...I am not going to take this in. Too heavy and too much time and probably more money than it's worth.
    I guess I'm gonna have to haul my cookies off the sofa to turn her on and off. Bummer.
    Thanks anyway
  • Bradshaw08 Feb 26, 2008
    Hi I have a sanyo that works fine turning it on/off manually but will not turn on with a remote. I have had it stored for a while in a closet and set it up the other day to use with Directv but the remote will not work with it. The code took on the remote but still will not work on the tv. Any suggestions?
    Genius:
  • 1,139 Answers
Hello laurenbro, Actually it does make sense if the command processor in the TV set is bad. a way to test this would be to see if the TV will manually turn off and on. If it can, than the problem may be in the command processor IC, also called the input data IC. You will have to take this set to a TV repair shop, and have the look at that section.
Posted on Sep 12, 2007
  • Henry McKelvey
    Henry McKelvey Sep 12, 2007
    Caused by dust, not likely. This type of problem has to be analyzed because the set can be turned off via the on off button. The TV shop would have to test the incoming signal into the IR photodetector then see if the signal is getting to the command processor via the signal bus (connecting wires on the circuit board). This means that you would not be able to work on this problem, because it is actually not a user serviceble problem.
SOURCE:
What is causing the volume to to change on its own?
This is a known issue for this model, and you need to ask for a service intervention via your dealer or Philips (http://www.support.philips.com/support/catalog_selector.jsp) to repair it.
Nov 22, 2015 | Philips Televison & Video
Tip
Programming Philips Universal Remote Control To Your Device
Program the Device by Entering Direct Codes
1.Turn all of your devices off, and then manually turn on the device you want to program.
2. Press the Setup button on your the universal remote and continue to hold it down until the indicator light stops flashing and remains solid.
3. Release the Setup button
4. Press the button to which you want to programme(TV/VCD/DVD).
5. Release it immediately and make sure the indicator light is illuminated.
6.Enter the first possible four-digit code on the universal remote, and then press another button on the remote to see if the device is now programmed, such as the volume control or power button.
7. If the device responds, you have successfully programmed your Philips universal remote.
8. If the remote is not programmed then, turn the device off and back on and follow the steps again using the next code on the list. Repeat until the device successfully responds.
How to Program a Remote Using Code Search
1. Turn all of your devices off, and then manually turn on the device you want to program.
6. Press either the Channel button or the Play button until the device responds. Each time you press the button, the Philips universal remote tries a new code.
7. When the code works, press the Mute button on the Philips universal remote and the code will be stored.
To Get The Programming Codes :
Please go to below website to get the codes to programme your remote.
http://www.urc.philips.com/
Please select the below informations.
1. Location
2. Select your remote model.
3. On your left side you will have an option called as REMOTE CONTROL CODE FINDER.
Attached a image for your reference:
4. Select the device you need to programme and the make of the device you will get the codes for your device.
Thank you
on Jul 27, 2010 | Televison & Video
URC20 D1F codes for philips tv
Not sure which Philips TV model you have. But you can use the remote to scan the code by itself.
Try these steps::
1. Manually turn on your TV. Hold down the "Code Search" button on your remote, then press and release the device button you want to set up until it flashes.
2. Push the power button repeatedly until the TV turns off, then hit "Enter."
3. Press any other button while the TV is on to see if it responds. If it does, you don't need to do any other programming. If it doesn't, repeat steps
Aug 17, 2014 | Televison & Video
Philips 19PS50S122 TV does not respond to remote control
Please check your batteries in the tv remote as they appear to be weak or dead. You will need to find the cable remote's paper guide in order to properly program the cable remote so it can change channels, volume, and power functions on the tv set.
Good Luck!
Rich Lilja
Jan 05, 2014 | Televison & Video
I am using a Philips SRU3003WM/17 Universal Remote with my Sylvania TV Model number 64119E. When programming the remote some strange numbers appeared on the screen and now I cannot get them off. The...
Well your Philips universal remote control comes with a list of codes for devices by brand name.
Find the first code for the brand name and type of device you wish to program. Turn all of your devices off, and then manually turn on the device you want to program.
Press the Setup button on your the universal remote and continue to hold it down until the indicator light stops flashing and remains solid. Release the Setup button. Press the Mode button for the type of device you want to program on your Philips universal remote, such as the TV.Release it immediately and make sure the indicator light is illuminated. Enter the first possible four-digit code on the universal remote, and then press another button on the remote to see if the device is now programmed, such as the volume control or power button. If the device responds, you have successfully programmed your Philips universal remote. If not, turn the device off and back on and follow the steps again using the next code on the list. Repeat until the device successfully responds.
If your TV code is not listed on the manual then you can use the Remote Using Code Search Option -
Your Philips universal remote has a built-in code search feature that will find the correct code for your device. This process may take longer than using direct code entry, but can be helpful if you do not have access to the code list or if the brand for your device is not listed.
Make sure all of your devices are turned off, and then manually turn on the first device. Press the Code Search button and hold it down until the red indicator light stays illuminated. Press the Mode button for the type of device you want to program on your Philips universal remote, such as the TV button.  Release it immediately and make sure the indicator light is illuminated. Press either the Channel button until the device responds. You may have to press the button up to 300 times. Each time you press the button, the Philips universal remote tries a new code. When the code works, press the Mute button on the Philips universal remote and the code will be stored.
I thing you wrongly do the second option that creates the problem. No issue, if your tv code not listed on the manuals then you can go with the second (code search) solution. Please post comments for further help or information.........
Good Luck!!
Thanks
Jul 31, 2010 | Televison & Video
Need to program my tv and dvd player to the remote
Please follow the steps below
Program the First Device by Entering Direct Codes
2.Press the Setup button on your the universal remote and continue to hold it down until the indicator light stops flashing and remains solid.
3.Release the Setup button
4.Press the TV button.
5.Release it immediately and make sure the indicator light is illuminated.
7.If the device responds, you have successfully programmed your Philips universal remote.
8.If not, turn the device off and back on and follow the steps again using the next code on the list. Repeat until the device successfully responds.
6.Press either the Channel button or the Play button until the device responds. Each time you press the button, the Philips universal remote tries a new code.
7.When the code works, press the Mute button on the Philips universal remote and the code will be stored.
To get the universal remote codes please visit below solution
http://www.fixya.com/support/t5395701-universal_remote_code_phillips
Thanx
Jul 27, 2010 | Philips Universal PH301S Remote Control
What is the code for philips tv using RCA universal remote control ??
just follow the steps below
1. Manually turn on the TV.
2.Press and hold the CODE SEARCH button until the
INDICATOR LIGHT lights, then release the CODE SEARCH button.
3.Press and release the TV button (The INDICATOR LIGHT will blink then remain lit).
4. Enter the code using the Number Buttons. After your code is entered, the INDICATOR LIGHT will turn off.
code list for philips :
003, 004, 008, 012, 019, 062,068, 069, 075, 076, 086, 087, 088
5. Aim the remote at your TV and press the ON•OFF button. Your TV should turn off.
6.With your TV on, press CH+. If the TV responds, no further programming is required.
if it works ignore the following thing (quite difficult and irritating one)
1. Press and hold CODE SEARCH until the INDICATOR LIGHT lights, then release CODE SEARCH.
2. Press and release the device button for the device’s code you are retrieving (TV). The INDICATOR
LIGHT will blink once then remain lit.
3. Press and release CODE SEARCH. The INDICATOR LIGHT will turn off.
4. Starting with 0 on the keypad,
press the number buttons in
order (0-9) until the
INDICATOR LIGHT blinks.
5. The number which causes the INDICATOR LIGHT to blink is the first digit of your code.
6. Repeat step 4 until you have
retrieved all three numbers in code
if you want code list for all devices
download this pdf
Jun 14, 2010 | Televison & Video
Tv doesnt respond to buttons or remote
this is looking like a common LG problem our tv started doing this tonight
May 15, 2010 | LG 42LC2D 42 in. LCD HDTV
Philips TV model 34PW9815/17 the LED on the front of the unit turns green when first plugged into electrical outlet, and then immediately starts to flash red. nothing on the unit works and it doesnt...
Philips TV model 34PW9815 the LED on the front of the unit turns green when first plugged into electrical outlet, and then immediately starts to flash red. nothing on the unit works and it doesnt respond to controls either on the set or the remote
May 12, 2010 | Philips 32PT81S 32" TV
Power button changes channels and volume does not work
bad solder connections. front control panel.
Nov 23, 2008 | Philips 27PT543S 27" TV
Televison & Video Logo
130 people viewed this question
Top Televison & Video Experts
Ekse
