Question about Acer Aspire 5315 Notebook
Wireless connection problem
I would like to know why the wireless connection has trouble detecting when I am travling.
  • Anonymous Apr 14, 2009
    Had to take my computor back to factory settings since then cannot get onto wireless netI can get onto wired one it starts to connect to wireless then cuts off again
Hello.i have a problem with my laptop (acer ASPIRE 5315).when i install XP sp2 i get a problem with my wireless connection where i cant connect via its wireless!!!it asks me to install broadcom 802.11g.it happens just with windows xp but doesn't happen with Vista system.I need your help please
Posted on Apr 17, 2009
Get connection to internet
Connections to the internet can be tricky. It depends on how you connect- modem, lan,or wireless. If wireless, is it at home, or at a hot spot. If you are connecting at home, try shutting off your wireless switch on your laptop.(if you can), then shut off (unplug) your router, plug it back in, and then plug in the lan (ethernet) cord, and reboot. It should find your connection. You might also go to control panel, then to internet options, then to connections. See if there are any listings in the box. You might have to change things if there is one that says "use this connection first" or something like that, if you are trying to connect otherwise. Then go to lan settings, and uncheck "automatically detect settings". For a modem you need to make sure the modem is installed in devices (in control panel) and then make sure the software, from your internet provider, which will tell your laptop which number and how to connect, is installed. If you are using a wireless connection, do as instructed above and uncheck "automatically detect settings." and make sure your wireless switch is on. Occasionally there are conflicting connections, or possibly unsecure wireless connections "remembered" in your system that may have changed. Right click on your wireless icon on bottom right, then network and sharing center, then manage connections. You may want to delete the ones you don't recognize, or the ones you don't use anymore, as you can always connect again if you want to. If you are having trouble connecting to a particular connection, remove it from that list and then try connecting again. I know a lot of this sounds difficult, but like I said, connecting to theInternet can be tricky.
Nov 23, 2010 | Sylvania Computers & Internet
My new Lenovo G550 laptop (bought 3 days ago) won't connect to a wireless network anywhere. At home I have a desktop and another laptop that are connected and I don't have any trouble with them until I...
The wireless card may be swithed offGo to control panel and select "wireless connection" windows will detect the wireless card and tell you if it's swithed off.
Sep 11, 2010 | Computers & Internet
My computers stopped detecting the wireless network. The wireless router used to work fine with all my computers, but today it stopped. I am unable to connect online via wireless, but if i plug cables...
Power cycle all devices. that should do the trick. You may also want to get to the User Interface of the router to check if the router radio has been turned off by accident or the wireless detection has been stopped by accident.
Jul 07, 2010 | D-Link Xtreme N DIR-655 Wireless Router
Acer 6930 wireless won't connect anymore.
Hi acording your describle, you need do
1) please check the bios first, to set wireless to enable
2) check windows right buttom bar is there a wireless icon show there and click to see any detect wireless signal, if nothing to detect
3) check or compare to other laptop wireless configuration, check any incorrect setting.
4) if all sense ok, you need check the wireless card and wireless antenna wire connection, open a samll cover at back of laptop, there is a MINI PCI slot with a wireless card, take out and clean the card pins then put back.
5) still trouble please change another wireless card (same model)
it should be fix.
hope help you to fix it, please take a rating le me know how much helped you, thanks. for any question in any time please !
May 17, 2009 | Acer Aspire 6930-6455 Notebook PC
I am having trouble finding the WAP key for my computer. I just bought a laptop and it can detect the LAN connection but needs the WAP key. I am looking on our desktop but having trouble finding it. How do...
I guess you meant the Security Key for the wireless. You need to manually set the encryption type and key in order to connect.
When connected to the Wireless router with a cable, open up command prompt (Start->Run...->cmd [OK]), type ipconfig and note the IP address of the Gateway.
Copy paste this Gateway IP Address into IE and [Go]. you'll be prompted to logon. Try defaults if you don't know (Admin, Admin or Admin, password).
Then depends on the model of the Wireless router you need to locate settings for the wireless connection. Recommands WPA-PSK 2, AES.
Apr 16, 2009 | ASUS Eee PC 900 PC Notebook
Ethernet cable connected not detecting
make sure you donot have any static ip address in your network, or make sure you didnot disabled your network card, try to look in laptop network card if there is a linking light when you connect the cable? if not either cable or network card has problem.
try this and let me know what happen?
Best regards
Mar 02, 2009 | Toshiba Satellite A135-S2276 Notebook
Need help
my lap top does not show any wireless connection and wont let me do a restore to try to fix it
May 19, 2008 | Acer Aspire 3680 Laptop
CONNECTING WIRELESS LAPTOPS AND PSP TO NEW WIRELESS ROUTER
A SSID and security is step one. You need to hand out DHCP from something to get data to flow. Ensure you have DHCP enabled on something.
Jan 04, 2008 | Linksys WRT300N Wireless Router
Acer Aspire 5315 Notebook Logo
143 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
