Question about Maytag Washing Machines
Buildup/smell inside washer
I can see black colored buildup inside the washer/around the rim inside and it smells too. What is the best way to clean this? By hand with some sort of cleaner or can I run the washer with a chemical to clean it regularly?
    Sergeant:
  • 187 Answers
  • Hi,
  • Try this..
  • Check that the drain line is clear
  • Check the drain hose for kinks or blockages
  • Check pump for blockages
  • Check for build up of soap in the outer tub
  • Check for article of clothing stuck in the outer tub
Please rate my suggestion...
Posted on Apr 14, 2009
How do you get rid of mold smell in washing machine
Hello friend, thanks for your post!
I understand that you have a mold smell developing inside of your Frigidaire washer. I would normally recommend using a clean wash cycle with either one cup of bleach or one pouch of Tide Washing Machine Cleaner. If you do not have a clean wash cycle on your washer you could also use hot water and a regular cycle with a cup of bleach to clean out your washer.
You should also check over your gasket to assure there is no mold buildup, if you do locate mold inside of your gasket you can use bleach to help get rid of any residue. I hope this information is helpful. -Matt
Sep 25, 2014 | Frigidaire Washing Machines
Washer smell
If this is a front loader, clean around the rubber "boot" inside the doorway between the front of machine and the drum by pulling out a little to reveal buildup behind it. This can get a funky smell. You can also run the "sanitary" cycle if your unit has one, with bleach, which will clean the tub better.
Jan 12, 2012 | Kenmore Washing Machines
My clothes come out of the washer smelling fresh and clean. After drying in the dryer, they smell mildewy.
Check for lint buildup in the vent discharge hose/pipe and the inside of the dryer blower housing.
Heavy wet lint buildup will cause a moldy/mildewy smell that you describe.
Heavy lint build up will also increase the drying time, and it is a fire hazzard
This is a free answer, Please rate me
Oct 18, 2010 | Estate Dryers
I have a strange odor
It is normal for all models of washing machines to have a gallon or two of water left inside the bottom of the washer and in the drain pump. This is not the cause of odor. The smell is being caused by residue left on the inside of the plastic outer tub.
The best way to clean a stinky washer is to use a washer cleaner that is able to be used with clothing in the washer. The added bulk of the laundry will raise the water level to include the splash area 3-5 inches above the normal waterline. This splash area always has the worst buildup.
After the odor is gone you'll need to change washing habits to keep it away.
Oct 19, 2009 | Washing Machines
The washer smells,had the problem before the repairman took it apart, I cleaned the white plastis rim on the tub,solved the problem soap buildup we need to know how to take it apart to clean it
Dont !! Try doing a hot wash with a good dose of Washing Soda Crystals and no clothes (An empty washer not a visit to a nudist colony). Also go back to Old Fashioned Soap Powder for a while. Cold wash powders and low teperature washes do not dissolve the fats which are washed out of the clothes and they build up causing the smells. Old fashioned powders had some bleach and soda in them which kept the problem at bay
Jun 14, 2009 | Whirlpool Washing Machines
Stale smell on crockery after wash
Most commonly, this relates to sulfides or other impurities in the water itself, but may also be caused by a buildup of food soil within the washer. Smell a clean glass of water. Does it smell stale also? If no, clean the screens and wash water sump/tank within the machine.
You can also clean the inside of the machine by using a commercial grade dish machine detergent and increasing water temp if possible.
If the water smells stale, consult a local water expert for guidance in resolving
Aug 19, 2008 | Dishwashers
Whirlpool duet front loader washer
Mold and bacteria in your door seal is a symptom of problems deeper inside the unit. All washers - not just Whirlpool, have this problem. The area of worst buildup is always on the inside of the plastic outer tub just above the normal waterline where suds and soiled water splash up and don't get rinsed out. To clean this problem area add 1 or 2 caps of smelly washer cleaner to a full load of laundry. The added bulk of the laundry will raise the water level to include the "splash area". Intermittently pause to soak more extreme cases.
Aug 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Moldy smell
Turn it off, unplug it. Remove filter and check if filter and/or filter and pump housing are clogged with something "smelly". When you're at it check the drain pipe for too.
May 08, 2008 | Kenmore Elite 45986 Front Load Washer
Build up of black "gook"
I also have had issues with a bad smelling LG Tromm 2277 washer when we leave the door closed after using it. One note on the LG site mentions that soap/scum buildup on the washer drum can encourage mold growth. They suggested running an empty wash load and then pause it after the water fills and add a hot tub cleaning product (Whirl Out - I got it at Lowe's) and restart the load. This stuff should help remove the soap scum and limit the smelly mold growth. My washer does not smell as bad after using it. I also have run an empty cycle with only bleach using the very hot sanitary load setting.
Aug 20, 2007 | LG WM-2277HW Front Load Washer
Washing Machines Logo
71 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
