Question about Dryers
No heat have replaced thermo cutoff
I was told to replace the thermostat and thermo cutoff which i did but still have no heat.
    Genius:
  • 1,122 Answers
Have you checked the heating element with then omns meter?what make?where is the lint filter?-mike
Posted on Apr 14, 2009
Have replaced heat element, thermostat, thermal cutoff, thermal fuse and cycle thermostat on whirlpool dryer. keeps blowing thermal cutoff! Exhaust is clear inside dryer and outside! What is causing all...
I'd like you to try something easy. Set the dryer to Air Fluff and see if the dryer still puts
out Heat let it run for about 2 full minutes If you dryer is still putting out Heat get back to me
Nov 06, 2010 | Whirlpool LER4634J Electric Dryer
Dryer tumbles, no heat, thermo fuse has been changed. Can it be the cycling thermostat or the heating element?
If you have changed the thermal fuse you may have a defective thermal cutoff (located at the top of the heater housing in the back). The thermal cutoff will come with the high limit thermostat located at the bottom of the heater and you should change both parts if the thermal cutoff is bad.
You can take both of the parts (the heater and the thermal cutoff) to a parts supplier to have them checked for continuity (they should both read "closed" if they are good).
Good luck to you!
Oct 07, 2010 | Whirlpool WED5300S Electric Dryer
My thermo uses B and O terminals for damper control what programable thermo do I use to replace?
Any thermostat that says that it can be used for heat pump applications will have the B and O Terminals.
Make sure that you wire the thermostat exactly as the old one was and set the thermostat up for a heat pump so that the B and O terminals are used.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 22, 2009 | Honeywell Electronic Programmable...
Sterling model TF-45, thermostat calls for heat, gas valve opens up, thermocupler starts pilot, unit fires up only to shut down within 30 seconds or so... I had replaced the high limit a while back,...
Sounds like you broke the hot surface ignitor ?? he was on about the flame sensor a rod .so replace what you broke and clean the flame sensor ,also check the pressure switch.
May 08, 2017 | Sterling Heating & Cooling
No heat but already replaced heating elimate
Check the thermal cuttoff. It is located on the element. If it does not have continuity, replace it. Also replace the Hi-limit thermostat, also located on the element, and the operating thermostat, located on the exhaust. These two should cut off the heat before the thermal cutoff blows.
Nov 25, 2009 | Dryers
Replaced elements but does not heat in bowl
Check the thermal cutoff located on the element.  It is designed to blow if the element gets too hot.  If the thermal cutoff is blown, the hi limit thermostat (also located on the element) will also need to be replaced.  It will have two terminals on it and if it is good it will have continuity.  Trace the wires back from the element.  The first one it comes to will be the thermal cutoff, next will be the high limit thermostat.
Nov 07, 2009 | Fisher and Paykel Dryers
I changed the thermal cutoff. it dried one load and then wouldnt heat again
check the thermo again, it might be going out due to a short in the element, or obstructed venting causing too much heat, clear venting or replace therm/heating element if needed.
Jun 30, 2009 | Dryers
I have a kenmore model 68741 that won't heat. The heating element is good along with the thermo cutoff and hi-limit thermostat. I am getting proper voltage at the heating element.
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 13, 2009 | Dryers
NO HEAT
Check for 220 volts incoming at the terminal block where your cord connects.
Make certain the dryer wiring is good there also.
Check the heating element to a ground on the dryer.
Check the continuity tthrough the start switch on the motor.
for the heater wire connection.
Mar 09, 2009 | Whirlpool LER4634J Electric Dryer
Kenmore 80 Series Dryer - No Heat - Thermal Cutoff Kit 279769
that therm. will actually come off the heating element part, it is always good to change both, I use a small screwdriver to get it off
Nov 07, 2008 | Kenmore 63942 Dryer
Dryers Logo
61 people viewed this question
Top Dryers Experts
