Question about Kenmore Dryers
When i push the start button it makes the noise it usually does but the dryer doesnt start. If you hold the start button it sounds like its putting electricity to the motor wont turn. Could it be as simple as replacing the starter switch or is it a bad motor.
  • 351 Answers
Hello, that sounds like a bad motor, you can know very quickly by unpluging the dryer, get to the back panel behind the switch. take one wire off the switch, grab your continuity checker, have someone push the switch, if it is good then its the motor. another way you can check is take the two wires for the switch and just touch them together if the dryer starts then it is the switch. Visit here for more help
Mark
Posted on Apr 14, 2009
Duet dryer is making a humming noise when cycle starts a d during
whenever i hear a humming sound in a dryer it's usually the motor or something caught in the blower wheel stopping the motor from spinning.open the door and see if you can spin the drum.if it spins by hand try this,open the door,push in the door switch with one hand,have someone push the start button while you hold in the door switch and spin the drum by hand helping it move,if it runs you have a bad motor,if it doesn't remove the bottom panel and see if the belt is broke and stuck in the motor but like i say usually it has something to do with the motor not spinning.hope this helps
Oct 21, 2013 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Maytag dryer sounds like it is going to start but wont start
could be that the belt is cut off , of the the puleys are jam .. does it make a big noise ( squeeky noise
May 12, 2017 | Maytag PYE2300AY Electric Dryer
Amana Dryer LEA30AW
usually the humming sound is coming from the motor,try this,open the door,turn the drum with one hand and hold the door switch in with your other hand and have someone else push the start button at the same time,this might help the motor turn on but if it does you need a new motor,if you can't turn the drum you could have something stuck in the blower wheel or something jammed in the motor like a broken belt but like i said a humming sound is usually the motor.
Feb 22, 2012 | Amana Dryers
I have a 70 series kenmore dryer that is new. it has been working, I took out a load and put in another pushed the start button. It ran for about 2 seconds then stopped and will not start. It has power,...
Sounds like you may have tripped the thermal limit on the motor. Although, usually you will hear a loud buzzing sound when you try to start it. Let it set for about 2 hours, and try to restart. If that doesnt work, the only other thing that could stand in your way is a door switch. The door switch is a very easy and inexpensive repair. The motor is quite a bit more. If you have not cleaned the lint out of the inside of your dryer (requires some disassembly of your dryer), that would be a good place to start and will sometimes allow a thermally overloaded motor to work again. Keep in mind, if it is the motor, they only have so many thermal resets before they are just done. There are instructions on this website if you are interested in trying to diagnose this dryer. Please, make sure before you take it apart, you have it unplugged!
Feb 05, 2011 | Kenmore Dryers
Push start button and it makes the noise like its going to start but stops when you release the button. Drum doesnt turn, smells like it might burn
my knemore want start i push the button it make a noise but it want start, if i hold the button down it goes quiet.
Nov 20, 2010 | Frigidaire Dryers
Dryer stops running shortly into cycle. When button is pushed to restart, dryer groans. Holding button may get the unit going again - but it makes noise running and stops again soon. Bad motor? Bad...
Sounds like start winding switch. I would replace whole motor assembly. Try on ebay for a used one that looks newer. Used motors will save you some serious money.
Jun 21, 2010 | Speed Queen AES28AWF Electric Dryer
My Maytag dryer buzzes when I push the start button. If you hold it in, the dryer will start but makes a noise, almost like a bad belt. After a few minutes the dryer will shut itself off and will not...
Remove the belt from the motor and push 'start'. If the motor makes loud noises, squeals, or the shaft has side play in several directions, then it probably is the motor. Replace it. If the the motor runs quietly, then check the drum by hand to see if it is making excessive noise while turning. There should be a little resistance to turning, but not real difficulty. Hope this helps.
Aug 13, 2009 | Maytag PYE2300AY Electric Dryer
When you push start button, it makes noise but won't start.
This is a A.C. hum that you are hearing. this is a warning sign. You are experiencing motor failure. the actual windings inside of the motor are losing their potential to hold an even current due to breakage. the shutdown is a safety feature built in the control panel to prevent electrical spark/fire.
Feb 14, 2009 | Kenmore 659 Electric Dryer
Kenmore gas dryer. 70 series
sound slike something fell down there and is jamming the blower from turning. if the filter is ontop of the unit, remove the 2 phillips located under where the filter pulls out from. and the n remove all the screws on back panel youll see ( down the left side of unit ) the filter houosing, its secured by 3 5/16 screws toward the bottom portion of the housing, simply unscrerw and wiggle out, then remove the debris, and reassemble.
if the lint screen is located inside behind door, eitehr remove the bottom accesss panel or pop the top(with a screw driver approx 3 inches in from ither side of main top relaes the clips) the lid tips back revealing 2 screws holding front panel to the unit, after removing you will see the filter housing, still mounted by probalby 3-4 screws, remove the housing and retrieve the debris that has fallen down there
Apr 05, 2008 | Kenmore 74602 Gas Dryer
Dryers Logo
109 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
