Question about Whirlpool LGB6000KQ Gas Dryer
Dosent dry Dryer fires, lights but does not stay hot long.
  • 234 Answers
Hello, you need to replace the gas coils. Over time, they tend to get weak and stop energizing to allow the gas to flow thru the valve. There are 2 coils and one is the booster.
Best of luck :)
Posted on Aug 19, 2009
  • 55 Answers
SOURCE: hotpoint condenser tumble dryer aquarius cdt00- wont dry
I am not familiar with this particular unit, but I have a condensing dryer (Malber) which pumps out the water by itself. I am guessing that your unit requires you to empty a bin manually. Even if the bin is empty, I think the unit thinks it needs to be emptied and that is why the dryer will not work to give you hot air. If you do have such a bin, it might have a weight switch which the unit uses to detect if the bin needs emptying. See if the weight switch is working. The same weight switch idea is used on dehumidifiers.
Posted on Mar 10, 2008
SOURCE: dryer coming on but not drying
I had this issue with mine, my plug for the 220 voltage was loose therfore I was only getting half the current causing the dryer to spin but not heat. check your plug and make sure it is tightly in.
Posted on Jan 18, 2009
  • 64 Answers
SOURCE: dryer wont dry clothes
Vents can fool you sometimes they seem to be ok but still cause problems. Try running with vent unhooked from machine one time and see if it works ok.
Check for leaks air leaks around the door or anywhere else.
Posted on Jun 10, 2009
  • 46 Answers
SOURCE: Kenmore Elite Oasis dryer 110.6708 that gets too hot
did u clean machine filters? in the back of your machine there is a big silver pipe itmay need to be clean too
Posted on Jan 21, 2010
kel1guy2002
  • 3740 Answers
SOURCE: mdg5500aww lp gas dryer heating problem it fires
When a gas dryer starts and the burner does not stay lit more than one minute the flame sensor is not detecting the flame to as a by design safety feature the burner is automatically shut off. It is not sensing flame so it is shut off.
This is the most likely suspect. http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg5500aww-%3d%3di2681&PartID=2681
BEFORE you change this part make sure that the outside vent flapper and the ducting form the back of the dryer is free of lint. Disconnect the dryer vent and try it with nothing connected to the dryer. Also check around the lint filter area for lint especially in the bottom. If there is not a lint or ducting problem then by all means change the flame sensor.
Thanks for using FixYa!
Kelly
Posted on Mar 06, 2010
Dryer gets hot on the outside of machine
Clean the lint out of the pipe that goes out side, also the grate on the outside, If that dosent do it take the back off and see where the lint comes out, take that apart and clean the lint out. I have had this problem before and just recently. The dryer has a saftey fuse, when the dryer gets too hot to shut off, thats why your clothes are not drying. 1st try the pipe that goes outside including the end(outside).
Aug 15, 2012 | Kenmore 400 6942 Dryer
Mdg5500aww lp gas dryer heating problem it fires once but dosent burn long clothes dont dry help
Kelly
Mar 05, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer wont dry clothes
Jun 10, 2009 | Whirlpool LER4634J Electric Dryer
Dryer is running but dosent get hot.
if the fire is cimming on when you 1st start it the and as it runs it does not come back on. the problem is the coils, if the fire never comes on the problem can be the ignitor or the flame sensor in most cases.
Apr 07, 2009 | Whirlpool LGV4634JQ Gas Dryer
Dryer gets hot and spins won't dry cloths
clean exhaust vent ASAP it could start a fire if the heat has nowhere to go out the moisture stays inside and your heat element will cycle on and off on a high temp limit swich
Apr 01, 2009 | Kenmore 73952 Gas Dryer
Won't stay lit
You ignitor is working and sensor is working because it will fire up. so those pesky coils are intermittant because they get hot and quit cool off and work some more . replace them
cc8e664.jpgHere is a little ditty I wrote some time ago about this subject
INTERMITTANT COILS
Mar 07, 2009 | Maytag MDG6000 Dryer
Not staying hot-Kemore 80 Series gas
suspect coils bad on burner valve after heating up first time will sometimes fail on following fire ups
Nov 19, 2008 | Kenmore 63942 Dryer
Whrilpool gas dryer
DISCONNECT THE EXHAUST FROM THE BACK OF THE DRYER AND TRY DRYING ONE LOAD OF LAUNDRY. IF THE DRYER WORKS O.K. WITH THE EXHAUST DISCONNECTED, YOU HAVE A RESTRICTION IN THE EXHAUST DUCT SOMEWHERE.
Apr 22, 2008 | Dryers
Hotpoint condenser tumble dryer aquarius cdt00- wont dry
Mar 09, 2008 | Dryers
Dryers Logo
59 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
