Question about Honda Garden
Not enough spark at spark plug to start honda mini tiller fg100 tiller seems to get fuel but will not start.
  • bragan22 Apr 16, 2009
    I changed the spark plug and fuel but the engine still will not crank.
  • bragan22 May 01, 2009
    I found the intake valve stuck and the push rod bent.After freeing the valve and getting the push rod straight the tiller works fine.Thanks for your help.
  • 1,183 Answers
If the spark plug is not getting enough spark . There could be a couple of reasons to it
1. The plug gap is not set correctly
2. The plug is bad
Try replacing the plug and check
3, The starter motor is not able to give proper current
Try draining the fuel tank, completely, clean replace the plug, fill it fresh gasoline an try to start with choke on.
For additional help the service manual of the tiller can be found below
http://www.rentrain.com/library_files/749.pdf
Thanks
Proton
Posted on Apr 14, 2009
  • Mandeep  Singh
    Mandeep Singh Apr 17, 2009
    Thanks for replying , as i have sent you the service in my previous post ,
    Go to page 23 of the same.
    1. Check the spark arrester, and adjust it to the given specifications
    2. Also remove the muffler and inspect if it is blocked
    3.Also check your air filter if its clogged of dirt. Remove and clean the same.
    Thanks
    proton
Honda FG100 tiller will not prime, filter replaced
Well if the unit has fuel than it should prime unless the primer bulb is damaged and unable to force air/gas through the line. This is definetly a fuel issue, I would remove both the line from the tank to the carb and carb to engine and clean them thoroughly.
When you press the bulb the carb should shoot gas from the unit when disconnected. If this isn't happening your clog is here. If it does eject gasoline than your clog is the clear line which sometimes collects sediment if the gas is poluted.
Mar 18, 2010 | Honda 25cc 4-cycle Mini Tiller
How do you change the oil on a honda fg100
Lay the unit face forward so it is laying on the gas tank and the engine is level. Fill through the dip stick access until oil is up to the bottom lip of the threading.
Mar 12, 2010 | Honda 25cc 4-cycle Mini Tiller
What type fuel; and mixture for honda fg 100 mini tiller
the Honda FG100 is a 4-cycle engine do NOT mix oil with the gas, - you will cause damage to the engine (head, valves, piston rings etc) not to mention if will not run well.
Mar 08, 2010 | Honda 25cc 4-cycle Mini Tiller
I need a worm wheel for a Honda minitiller FG100.
You can buy parts for this from www.petessmallengine.com
I had to replace the tine shaft w/worm wheel assy. This is usually the weak point in the transmission. The worm is made out of brass.
Jan 03, 2010 | Honda 25cc 4-cycle Mini Tiller
Honda FG100 Tiller - Tines wont move
I took the transmission apart and the gears were fine. The friction pads on the centrifugal clutch don't seem to make full contact with the drum. Does anyone know what the thickness of the friction pads are suppose to be? I used some belt dressing on the pads and got some movement on the tines. With no wear on the gears, I guess I'll be replacing the clutch.
May 02, 2009 | Honda Hmantis Mantis Garden Tiller with...
I am looking for fender for honda fg100 rototiller?
If It is a Honda FG100 like in the title the part number is 65141-V06-003
If it is a FG110 like in the description the part number will be 63411-V25-000 FENDER, RR. and 65141-V25-000 FENDER, FR.
Nov 24, 2008 | Honda Hmantis Mantis Garden Tiller with...
Garden Logo
117 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
