Question about Canon imageCLASS D761 Copier
Screen says "check ADF" what does that means & How can I fix the problem.
  • 66 Answers
Probably something jammed in it. lift up the spring loade ramp to see if you can find anything in it.
Posted on Apr 14, 2009
What does ADF document mean?
"Document in ADF", usually means that there is a document in the Automatic Document Feeder. Or to put it differently, there is a paper jam in the document feeder (probably of the scanner part).
The fix is to check the feeder and clear the jam. Sometimes it indicates there is a piece of paper stuck or a faulty paper detector.
Dec 26, 2014 | Office Equipment & Supplies
Error J1
Hello Sharon,
When a document jam occurs, "J" and "1" will display alternately on the function number display panel of the scanner.Please perform the following:
  1. Remove all documents from the ADF paper chute.
  2. Open the ADF while pressing down the ADF open lever. If you are using fi-6130 with the imprinter option attached, please open the imprinter and then open the ADF.
  3. Remove the jammed papers from the ADF.
  4. Close the ADF pushing the center part of the ADF carefully.
If document jams occur frequently, please check the followings:
1. Do the documents satisfy paper specification?
2. Have the documents been jogged?
• Align the edge of documents for stable paper feeding.
• Remove documents with crease or dog-ear.
• Scanning different width of documents may cause skew and result in paper jam.
3. Are Chuter Unit (ADF paper chute),Guide P ASSY (Sheet guide), Feed roller cover (plate guide) and Brake roller cover installed correctly?
4. Clean the Feed rollers, Eject rollers,Plastic rollers, glass surface and paper feeding surface, and see if the error is
resolved.
5. Replace Pick roller or Brake roller, and see if the error is resolved.Check the consumable counter from the TWAIN driver screen or from the built-in Maintenance mode. When the counter exceeds the values, replace Pick roller or Brake roller.
6. If the issue still persists, then you are recommended to contact the nearest Fujitsu service center for further assistance.
Hope the above information is helpful.
Thanks & regards,
ScanCare
May 03, 2013 | Fujitsu Office Equipment & Supplies
How do you fix error code c55
Here are the steps they recommend in the users manual for a c55 error.
5.1.11 Optional communication related service call
[C55] ADF I/F error
[F11] ADF I/F error
(1) Check if the connector CN71 on the ADF/RADF board is disconnected.
(2) Check if the relay connector between the ADF/RADF board and the PFC board is disconnected.
(3) Check if the connector CN246 on the PFC board is disconnected.
(4) Check if the connector pins are disconnected and the harnesses are open circuited.
(5) Check if the conductor patterns on the ADF/RADF board and the MAIN board are short circuited
or open circuited.
(6) Replace the ADF/RADF board.
(7) Replace the MAIN board
Jan 05, 2013 | Toshiba e-STUDIO166 Printer
Adf is not working
You might have paper stuck in the ADF. Check the ADF by doing the following: try using it for copies and see where it stops. If it stops at the very beginning it might mean bad feed rollers. Take out your feed rollers and clean them with rubbing alcohol and then dry them. If it stops deeper in the document feeder then there is either a paper clip or ripped paper blocking its path.
ADF AND COPIER PARTS AND SUPPLIES
Sep 13, 2012 | Office Equipment & Supplies
Paper jammed in the ADF and can not pull out or remove.
Required tools... T10 screw driver, cloth, tweezer, water
Remove ADF input tray, open adf door, remove connector, remove T10 screws, lift the adf mechanism, remove the paper, observe why paper got strucked, shoot the problem, clean the mechanism & sensors with cloth, fix the machanism back..Dip cloth in to water sqeeze it, clean adf pick up roller with it. fix all spares back,..Check..
Sep 14, 2011 | HP Officejet Pro L7590 All-in-One InkJet...
Cannot print screen shows ADF.what does this mean?
Hi!
ADF stands for Automatic Document Feeder and it means the device mounted on top of your pixma that allows multiple pages to be scanned/copied/faxed one at a time automatically.
Now why does it not print? The machine "believes" some document is inserted in the ADF in order to be scanned/copied/faxed, and wants that operation to be completed before it accept any print job. Please remove, if present, any paper from the ADF. Maybe its only some small piece of broken paper or even dust on the sensor in the ADF.
Aug 08, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
My conon printer mx340 says ducuments in adf error
Hi guys,
This error occurs when paper sensor in ADF = Automatic Document Feeder detects some paper inside paper path. Firs, open ADF access cover and check if some broken paper present inside paper path. If no broken paper found in paper path means paper sensor is faulty and you need got new ADF replacement. Thanks
Source:
MX340 Series Service Manual
Jun 27, 2011 | Canon MX340 AllInOne InkJet Printer
What to do window says check document open ADF?
That means: open adf cover ( auto original feeder ) and remove jamed paper.
Probably adf needs some maintenance, clean rollers.
Jul 05, 2010 | Canon imageCLASS D880 All-In-One Laser...
Black vertical line along left margin when using the adf to scan.
Check both the Fuser Unit and the Cartridge for lines . In any of the rollers are found with a line that means it needs to be replaced.
Jan 26, 2010 | Dell 1600n All-In-One Laser Printer
ADF won't draw document to be scanned into the scanner
The first thing I always do to a misbehaving ADF is take a dust blaster(canned air) and blow all of the dust and debris out of the ADF,This means lifting the ADF cover and cleaning everywhere.There is always a switch or sensor whose job it is to detect a sheet of paper placed in the ADF.Good Luck.
Mar 27, 2009 | Canon Office Equipment & Supplies
Canon imageCLASS D761 Copier Logo
old marine
old marine
