Question about ASUS K8N-E Motherboard
K8n-E motherboard doesnt boot anymore was working fine
Shut it down, last night and turned it one today but only fans come on.
no video, hd and cdroms dont seem to be starting, Replaced pwr supply. same problem
  • 84 Answers
Pls try to replace the memory...
Posted on Apr 24, 2009
Hp dx5150 mt shut itself down won't start
most likely power supply, those power supplies are horrible and the slightest power surge cooks them. a majority of them I get in for repair are p/s issues, a few for mobo issues.
Mar 08, 2014 | HP dx5150 Small Form Factor PC Desktop
I have an Asus K8N-E motherboard which does not seem to support booting from USB. Any suggestions?
You must configure the BIOS prior to booting up from USB. With the USB inserted, go to the BIOS setup and change the boot priority as explained on the official user's guide from ASUS (page 61):
http://dlcdnet.asus.com/pub/ASUS/mb/sock754/K8N-E/e2164_k8n-e.pdf
Jul 10, 2011 | ASUS K8N-E Motherboard
Controller MSI K8N Neo4 does not work
SHUT DOWN COMPUTER AND CLEAR CMOS BY RESETTING JUMPER ON MOTHERBOARD AND THEN RETURN JUMPER TO NORMAL POSITION OR USE RESET BUTTON. UNPLUG ALL HDD SATA CONNECTORS FROM HDD. BOOT COMPUTER TO BIOS. MAKE SURE ENABLE ALL SATA IS ENABLED, PRESS F10 AND EXIT.YOU WANT TO SHUT DOWN AGAIN. NOW REATTACH SATA HDD AND CONNECTORS AND BOOT TO BIOS AGAIN. NOW HIT F10 AND LET COMPUTER RESTART AND LOAD INTO THE OS. LOGON AND CHECK DEVICE MANAGER..SHOULD BE THERE. IF NOT CHECK MOTHER BOARD WEB SITE FOR BIOS UPDATE. IF BIOS UPDATE DOESN'T DO THE TRICK, SHUT DOWN AND DISCONNECT THE IDE DRIVE, UNLESS IT CONTAINS YOUR OS. TRY BOOTING TO BIOS AND CHANGE ORDER OF 1ST BOOT OPTIONS, HIT F10 AND EXIT AND ALLOW COMPUTER TO BOOT TO OS, THEN LOGON, GO TO DEVICE MANAGER AND REMOVE IDE AND RESTART, ONLY IF THIS HDD DOES NOT CONTAIN OS. YOU SHOULD BE FINE AFTER THIS, OR INSTALL YOUR OS ON THE SATA HDD.
Apr 09, 2010 | MSI K8N Neo4 Platinum nForce4 ultra K8...
System not booting, k8n
Have you tried resetting the bios? turn off the computer and remove the power cable connected to the power ATX power supply, look for the "clr_cmos" jumper and change the settings from 1-2 to 2-3 for approx. 10 secs, then return the jumpers to original settings and reconnnect the power cable and turn on the computer. This was the solution when i had the same problem before. Hope this helps you too.
Oct 01, 2009 | ASUS K8N-E Motherboard
Hit power button and nothing other than lights flicker once
Remove everything from the board except the front panel hookups.Make sure you remove memory, video card, hard drive and cdrom cables, hard drive and cdrom power, anything plugged into the back except the power. If it will power up this way start plugging things back in between power cycles. Start with memory then power down. Then add video then power down. Continue with Cdrom, then hard drives. When it stopps wanting to power on you know where the issue lies. If it wont power on with nothing on it then the motherboard is probably bad. Hope this helps.
Aug 08, 2009 | Intel Motherboard
Toshiba Satellite P205-S6237 won't Boot up after full shutdown
i think there is some issues with the OS because i noticed you can't shut it down properly so maybe the files needed in order to shut down had been corrupted but one more theory, the bios settings make sure that everythings configured properly there by checking the power options on the bios setup(the blue screen)so try setting it to default and change the boot priority to HDD,CDROM,FLOPPY.
Jul 14, 2009 | Toshiba Satellite P205-S6237 Notebook
I replaced the heatsink fan it booted up like three times.tryed put load xp wouldnt boot up from cd rom.Iset boot priority to cdrom.I tryed to reset jumper took out bat all night.the first time it booted...
Well, first you should check wether the fan actually starts when you turn on the pc. If it doesnt your cpu will be overheated in no-time, causing the pc to reboot. That fan then probably has the wrong voltage, or requires to much power, which your power supply may not be able to provide.
If it works, you should try to find out how powerful this fan is, meaning how much air it moves per minute. If this fan is less powerful than the previous one, your cpu will be overheated.
If neither of these solutions apply, I guess you should contact your vendor and request replacement. It may be just the fan that's broken.
Feb 20, 2009 | ASUS A8N-SLI Deluxe Motherboard
K8n neo ms-7030
change the first boot device,
go to the bios option by presing del button
ther select your first boot device like hardisk n second is cdrom the f10 for save configuration and press k and check it
Oct 18, 2008 | MSI K8N Neo-FSR Motherboard
Soyo SY-P4VDA Motherboard Problem
best thing to do is disconnect floppy, take all other board/pc card out of the computer remove cdrom, now you just have a hard drive
turn it on see where it goes. if it doesnt work try a different hard drive or just the cdrom but make sure you have boot from cdrom on in your bios.
Dec 14, 2007 | Soyo SY-P4VDA Motherboard
Computer powers off during boot
Hmmm...try resetting CMOS & checking all external peripheral connections: (KB/mouse, monitor, etc.)
Oct 26, 2007 | ASUS A8N-E Motherboard
ASUS K8N-E Motherboard Logo
157 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
