Question about Compaq Presario 700 470024-192 Notebook
I have a compaq presario 700 laptop that is no longer charging.
I am not sure if it is the power cord or the battery. The cord may be a little bent but it still fits. However the computer will not charge.
  • mrmars123 Apr 15, 2009
    BLINKING LIGHT ON FRONT, MEANS WHAT ?
    The power supply is plugged into the laptop. Their is a blue light that comes on where the power cable connects to the laptop. Theree is also a light on the very front edge that blinks on & off.
    Once in awhile I can get the laptop to power up for a milisecond.
    This just started yesterday & I cannot use the laptop.
    Any ideas? marsredplanet@gmail.com
    Problem Solver:
  • 14 Answers
  • 184 Answers
The notebook battery may have a defect if it will not power on the notebook and if it will not hold a charge. The battery indicator light on the notebook either does not light or always blinks orange. The notebook operates correctly when connected to the AC adapter.
A battery that will not charge may be the result of an AC adapter failure, a system board failure, or a battery failure. Perform the steps below to diagnose the failure.
Troubleshoot the power supply
To verify that the AC power supply is functioning properly, follow the steps below.
1.
Plug the AC adapter directly into a functioning wall outlet, and plug connector into the computer. Do not plug into a power strip, surge protector or secondary power source.
2.
Verify the following operation and take the appropriate action:
That all power cord connections are secure.
If the AC adapter connection to the notebook is loose, the connector may be damaged and require repair. Contact HP service and support for further assistance.
That the power button or power LED is lit when the computer is on.
That an LED on the AC power supply adapter is lit when plugged into an AC wall outlet (not available on all AC power supply adapters).
That the AC power supply adapter is the correct type.
Different notebook models require different AC power supply adapters. You will need to know the Product Number of your notebook to determine the Part Number of the replacement part. Click Start > HP Help & Support to view the product name, product number, and serial number that you'll need to have to speak with HP Customer Service.
View the See Also section for information about locating HP Help & Support in your operating system.
Troubleshoot the System Board
If you've verified that the AC power functions properly, troubleshoot the PC's system board by following the steps below.
1.
Remove the battery, and keep the notebook connected to AC power.
2.
Press and release the Power button to start the computer.
If the notebook PC powers on , then the AC adapter and system board are functioning properly. Go to Troubleshoot the battery .
If the Power LED is off , then the AC power adapter needs to be replaced. Contact HP Service and Support for further assistance.
If the power LED is on , but the notebook PC does not power on, then the notebook PC needs to be repaired. Contact HP Service and Support for further assistance.
3.
Shut down Windows by selecting Shut Down from the Start Menu.
If you have verified the AC power supply and system board are functioning correctly, troubleshoot the battery by following the steps below.
1.
Insert the battery into the battery compartment on the bottom of the notebook PC.
2.
Connect the AC power supply and allow the battery to charge for 15 to 30 minutes.
NOTE: The Battery Charging light should be on while the battery is charging. If it is not on, check the AC power adapter connection to the notebook PC.
3.
Unplug the AC power adapter cord from the notebook PC.
4.
Press and release the Power button to start the computer using only the battery as the power source.
If the PC does not power on, then the battery needs to be replaced. Contact HP service and support for further assistance.
If the notebook PC does power on, the battery is functioning properly.
NOTE: If you have purchased a second battery for your notebook PC or you have access to an identical battery, you can also check the battery by inserting the second battery into the PC and performing the Troubleshoot the battery steps again.
Posted on Apr 14, 2009
Compaq presario 7pl290 will not power on
Make sure that the battery is charged or plug in the power supply.
Jan 17, 2013 | Compaq Presario 700 470024-192 Notebook
Battery won't charge
Remove main battery and get a stiff toothbrush and clean the metal contacts, re-seat the battery back in to see if it will take a charge, if there is no change battery replacement is likely.
Dec 31, 2010 | Compaq Presario 700 470024-192 Notebook
Need ac adapter/power cord
You can get a replacement power cord for this laptop from any elctronic or computer store near you like Besbuy or Radioshack, of you can order it online from this sites.
http://www.nextag.com/compaq-presario-700-power-cord/products-html
http://www.bizrate.com/laptop-accessories/compaq-presario-700/
Apr 29, 2010 | Compaq Presario 700 470024-192 Notebook
Compaq presario c700 WAS WORKING I SHUT IT DOWN AND NOW IT WILL NOT POWER ON at all
Is the power cord/brick *firmly* plugged in in all places? Sometimes, the cord from the brick comes out slightly, breaking the power connection. If your battery is old/no longer holding a charge, the machine wouldn't start again. Also, if above is ok, remove the battery, plug the power back in. Does machine start now? If it does - replace battery.
gurutim
Mar 09, 2009 | Compaq Presario 700 470024-192 Notebook
Presario 700 power problems
No the battery does not have to be in for the notebook to work. No the battery does not have to be charge for the notebook to work. It sounds like you have a AC jack issue. Check to see if the AC is loose. You need to get this repaired by a local notebook repair shop.
I hope this helps. Please rate.
Feb 18, 2009 | Compaq Presario 700 470024-192 Notebook
No power up
You have a bad battery. I had same problem before and i just replace my battery and it works fine again..
Oct 05, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq Presario needed a new battery was installed labtop will not charge up!
When you install a new battery and remove a battery always make sure the laptop is completely shut off and have the power cord removed so that you avoid any possible power surge.
Batteries generally don't last much longer than a year and I have found removing the power cord or battery when it is off to be a good practice.
Before you charge a battery make sure it is run most all the way down. Recharging a battery when it is not run down can give it a memory and you may only be able to charge it up to the point you started charging it.
Anyway, if the computer won't charge a new battery then you could have a bad motherboard. To be sure try another battery.
Sep 09, 2008 | Compaq Presario Notebook
Compaq Presario 700 470024-192 Notebook Logo
348 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
