Question about Panasonic SC-AK220 CD Shelf System
5 disc CD changer door jammed
I don't know what caused this to happen but my CDs are stuck in the system. The door used to open all the time without playing any of the Cds. When i kept closing the door it kinda "kick-start" it back into normal and I was able to play my CDs again and get them out. I put 3 of my most popular Cds in the and allowed them to play continuously and then they stop playing, the system was stuck again and now the door refuses to open when I tried to get my CDs out! When I press the open key it keeps saying "error" and when I press play it acts as though it's changing discs but it's not and you hear the noise of it getting stuck. I peered through the vents and found the cds till in their position but not moving at all. please help.
  • Anonymous Mar 20, 2008
  • Anonymous Apr 29, 2009
    it gave me a *******
  • 277 Answers
SOURCE: Does not play CDs
If you sure that the system supports the disc's format.. And it won't play other discs... try to clean the CD lens. If it wont help and you're NOT still under warranty you should at least open the system and look for Problems with the door opening/closing: Steps: 1. Make sure the drawer-loading belt is still tight and elastic. If not, it can be replaced with a belt obtained from an electronic-parts supplier. The replacement should be of equal or slightly greater thickness and should fit snugly but not so tightly that it strains the motor. 2. Check for broken or loose gears and have them replaced. 3. Check for obvious sources of contamination such as pet hair or foreign objects that are preventing smooth operation of moving parts. Small children have a habit of inserting items into CD players. 4. Use electronics-grade contact cleaner to clean the door-position contacts.
Posted on Jan 15, 2006
silly girl
  • 513 Answers
SOURCE: CD player
Could be the classic dirty lense syndrom... If you know how to get to it, expose the laser lense, and gently brush any accumulated dust/dirt from it. There might be multiple slots, but only 1 lense. If you have a cd cleaner available you might want to try that out first, it doesn't always do the same job, but it can save you the risk of something else happening when you open it up. Good luck
Posted on Feb 13, 2006
  • 6 Answers
SOURCE: CD Malfunction
HIwaog, two things can be causing your problem, one is your lens may be defective,or two your sp motor maybe defective, try changing them.
Posted on May 01, 2008
  • 4 Answers
SOURCE: 5 disc cd changer, model #SA PM16
Sorry, but I think it does not pay... :-/
Posted on Aug 12, 2010
SOURCE: sony chc cl 5 md - cd changer doesn't open
I had a similar problem with my sony cd changer. Took it apart it turned out to be the drive belt a 3 pound part. Got a new slightly smaller one and works well. Very easy to replace.
Posted on Feb 21, 2011
Stuck CD in JBL 4 disc CD Changer / Navigation
before you press the cd on button keep holding the eject button while you press power on, I know this works for computers etc.
Feb 13, 2016 | 2013 Toyota Highlander
Sl-eh790 compactdusc changer
Have you opened the case?
Inside the actual cd drive unit there should be a couple of small rubberband like belts. You can try replacing them.
It may help.
If that doesn't work ,it may be time for a replacement.
I have a tendancy to hang on to old audio equipment long after it should have been replaced. It's just hard to let them go!
Good luck with it!
Mar 23, 2014 | Technics Audio Players & Recorders
Hi i have technics Compact 5 Disc Cd Changer SL-EH790
Carousel-type changers such as yours are prone to eventual failure.
I have a bose wave system. I tried loading cds in the multi changer and kept showing error and never would play. The multi changer still has one of my disc and will not eject. I tried unplugging and...
Hi, The cd disc is not in his place inside the multichanger, you must open the appliance and try to take out the cd without forcing, otherwise you wil brake the mechanical system,
after this the system will work well.
Jan 30, 2011 | Bose Wave music system Multi-CD Changer...
It is a 5 disc changer. The drawer will not open and it now has 4 cd's stuck inside the changer. It also will not play any of those "stuck" cd's.
THis happens when the drawer is jammed. Turn off the unit and turn it on and then use the disc skip from the remote so that the cds inside will change and then press the Open button.
Aug 21, 2010 | RCA Audio Players & Recorders
Jammed cds in a 6 cd changer ford ranger 2002
sounds like the tray inside was misaligned when the cd went in. and it probally sent the disc into a occupied slot. you will have to remove radio and disassemble to repair. also try just unpluging radio and plug back in. sometimes it resets the radio and will start ejecting the cds
Feb 05, 2010 | OEM Systems Car Audio & Video
2003 Ford Expositi CD Player will not play or eject
Does the CD door open or is it stuck open? If it is open look to see if you have a jammed CD. This happened to me and this is what I did. A CD had gotten off track and jammed the CD changer turn table. I stuck a little key in the slot and was able to pull the CD out. This fixed my problem. Hope it helps.
Dec 21, 2009 | 2003 Ford Expedition
Bose Wave Music Sys & 3 CD Changer
I have had a few of these come to my shop. The gears jump out of timing causing the cd lift to jam or become unalligned. The unit will probably have to be disassembled to get the CD out or have it serviced.
Dec 23, 2007 | Bose Wave music system Multi-CD Changer...
CD malfunction
It sounds like you have put a disc in the tray that the system can not read, so it will just keep trying to read the disc over and over again. If you turn everything off by the plug and wait a few mins the whole system should stop. Put the plug back in and as soon as you turn your system on, try and press the disc open key before the lens gets a chance to start reading it again. If this does not work you may just have a disc jammed. So you will have to get someone to check it out for you if you do not understand what you will be doing, because you may do more harm than good to your system. Good luck.
Aug 29, 2006 | Sharp CDES600 5 CD, 240W, Silver, Mini...
Cds Stuck in cd changer. stuck at no. 6.
i have a infiniti i-35 2002 and my cd player won't play or eject i was switching cd's on no. 4 and when it went in it got stuck inside it won't play no. 1thru6 are there any suggestions
Jun 16, 2006 | Bose Wave music system Multi-CD Changer...
Panasonic SC-AK220 CD Shelf System Logo
65 people viewed this question
Top Panasonic Audio Players & Recorders Experts
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
