Are you using Generic Cartridges? Pls See Below
I'm saying the same below!
By mclamemo on Nov 12, 2009
re: C84 I'm using generic ink, but the red doesn't work at all. I've done all the
printer cleaning programs and swabbed inside the printer with alcohol, and re-inserted the cartridge multiple times. it still doesn't
print at all.
Also now even the black every few lines
prints the top half of the line or the bottom half of the line, or its smeared, etc...
Help!
I have learned from experience, that
Epson does not like generic ink. You must use Epson Genuine Cartridges. Hopefully, you haven't screwed up the printer, like I did. I did try cleaning the heads and doing everything possible. Use 2 cartridges of ech set, for cleaning, cleaning, cleaning. ......But Nothing.
Had to go out and purchase a new printer.;
Good Luck :0(
Comments:
Nov 12, 2009- Funny. hahahahah,
Me too! I would say, about 2 dozen cartridges to be exact.
lol :0) :0) :0) :0) :0) :0)
Asker's Testimonial
" Thank you. Called Epson also and they didn't say it as directly, but advised real Epson ink too. Hope I didn't kill the printer! Generic ink for sale " - mclamemo
Replaced the three colour cartriges and now it only prints b&w. I have never used refills, only original Epson cartriges. Not a newbie, I've been dealing with printers on PCs as long as there have been printers and pc's. Now the ink monitor tells me that I have wasted 1/4 of the colour ink already in trying to clean heads etc. Very frustrating. Not good for Epson reputation.
PRINTER WORKED FINE UNTIL I PUT IN 4 NEW CARTRIDGES, NOW NOTHING. A COUPLE OF TIMES IT BARELY PRINTED ABOUT EVERY 4TH LINE.
I just replaced my cartridges (all 4) and the printer is responding to the computer and going through the motions of printing, but no ink is on the paper. Very frustrating. Tried all of the tricks with cleaning the heads, etc. Will try calling Epson and hope they can help.
Replaced the cartridges and now it goes thru the print motions but no ink on the page, it's completely blank. Ran the cleaning cycles and tried just about everything, with no luck.
same problem. The printer does not actually print ink. Goes through the motions but in the end only a blank sheet.
My C84 Stylus used to work great, then one day it stopped putting ink to paper. Replaced cartridges, drivers, ports. Cables tests OK. PC tests OK. Printer goes through the motions but rolls out blank sheets.
Standalone print test (i.e., printer-generated test page with cable disconnected) also puts out a blank page. I know nothing else worthwhile to test.
