Lcd tv shuts down by its self
I have a magnavox 32mf231d lcd tv that shuts down after about 10 mins. If left alone it will restart by its self after a few seconds but only run for a couple of mins and then shut down again. If I unplug it for a few mins it will run for about 5 to 10 mins then shut down again. I placed a fan in the rear of the set and it runs a little longer before shutting down again. Is there anything I can do to fix this problem?
  • Leppacyeoj7 Jan 26, 2008
    I have a sharp LC - 32D62U that is doing the same thing. but after the second time it shuts down the power light and OPC light on the front of the TV will bling in a pattern Both at same time then the power light twice, then both at same time and so on.. have no idea why
  • Anonymous Mar 20, 2014
    shuts down after 3 mins
I have a sony KLV-S32A10 LCD television it turn off in few seconds.Can anybody help me in this problem.
Posted on Jan 13, 2008
All you need to do is remove the back cover, then remove the metal cover that covered the power supply. Watch tv w/o cover, it won't shut down again. Try it and post here if it works.
Posted on Nov 26, 2007
I had the ame problem.
Un plug set and with a small clean paint brusk clen out the all the air grills at the rear of the set. Mine looked clean but i manged to get a great deal of "hard" dust out of then using this method.
Hope this helps
Posted on Dec 02, 2007
SOURCE:
Sanyo DP32640 LCD TV volume will suddenly spike to full, last 3-4 secs., shuts down, restarts at the original settings, holds 5-10 mins., repeats at 5-15 min. intervals
Set has a poltergeist in its main board where you have the setting electronics. Prices have dropped to such a point on this size set that it is simply not worth a repair.
May 05, 2017 | Sanyo Televison & Video
I have sony kdl-46hx800.When I turn on tv it work for 10 min. than cuts off by its self after that red light blinks 7 times.
7-blinks of standby light to Sony LCD TVs, indicates a fault to its power supply board. An over-voltage shut down. If you wish to get more details about this, check this link. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Oct 02, 2013 | Sony KDL46HX800 46 in. 3D LCD TV
MAGNAVOX 32MF231D TV PIXILATES, THEN GOES BLACK, ON AND OFF?
Hello Kevin,
That type of issue is usually caused by bad filter capacitors on the power supply board. As the capacitors heat up they can't filter the output power correctly so the power supply shuts off to prevent damage. Here is a link to information and parts list of the capacitors neede3d to repair the power board.
http://www.ccl-la.com/catalog/product_info.php?products_id=323
Feb 19, 2013 | Magnavox 32mf231d
I have a 32" Magnavox tv purchased in 2005, model
dear User,
pls be informed that supply capacitor are weak.
kindly change the supply capacitor
Feb 26, 2011 | Philips 32MF231D Television
My magnavox 32mf231d/37 tv will power up and the sound works, but the screen is blue... any help would be great!
Try taking it for a walk, or sing happy songs to it.
Depression is a common problem with today's LCD panels.
Most cases go untreated.
Talk to your doctor about receiving medication that may be able to help with it's symptoms. Side effects include nausea, diarrhea, genital warts, hemorrhoids, and an erection that lasts longer than 4 hours.
Do not watch your TV if yo are pregnant or using an MAOI, as these combinations have been known to cause permanent death.
Jan 27, 2010 | Philips 32MF231D Television
Magnavox 32MF231D/37
Hold a flashlight up to the tv while the tv is on. If you see a picture your CFL is burnt out.
Mar 21, 2009 | Philips Televison & Video
32 in Magnavox tv model 32MF231D/37
An earlier post of the smaller model of this with the same problem said to remove the metal cover over the power supply.
I have the 26MF231D and it worked great afterward (even though you can't mount it)
Here is how you remove the cover.
http://www.flickr.com/photos/[email protected]/sets/72157611665895426/
Jul 04, 2008 | Philips 26MF231D 26 in. LCD Television
Magnavox 32MF231D
After 20mins the tv shuts off and then come right back on continously.....
May 21, 2008 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
620 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
