Question about Mtd 22" Yard Machine Push Mower
My 13.5 b&s started running rough in the middle mowing the yard then died it will restart but sounds like it jumped timing I checked the flywheel & the key did not sheer
    Sniper:
  • 56 Answers
Clean the carburetor.
Posted on Apr 14, 2009
  • steve guinn Apr 14, 2009
    Air cleaner is another possibility.
    gasfast
  • steve guinn May 06, 2009
    My reply was well within the scope of your problem.
    How dare you give me an inappropriate rating!
My cub cadet LT1045 46 inch cut model number 13ax11ch712 will not start its getting spark, fuel I was mowing and turned it off when I tried to restart it, it run rough then died now it will not start I...
Have you tried putting a little gas down into the carburetors throat ? If it starts then you'll know you're dealing with a fuel delivery problem. You claimed you have spark so I'm assuming that it's a good blue color, I think if it was me I would be pulling my flywheel off and checking to make sure it hasn't sheared or moved. If you were able to rule out the fuel delivery issue.
Oct 10, 2013 | Cub Cadet Garden
Craftsman 26 hp Kohler engine 54
to be honest the enigne ahas a control that the left side must fire and run before the right starts to fire it sounds to me like you have a fuel issue possibly the carb. is gummed up and dirty.
Jul 27, 2012 | Craftsman Kohler Courage 26 hp 54" Garden...
Timing chain possible jumped tooth
yea sounds like a belt or Chane but dose not jump going down the road much most of the time will do it when u start the car..
Jun 17, 2012 | 1987 Toyota Pickup
I have a 6.5 self propelled Lawnman by MTD . It will start but will not stay running.
is the handle hard to pull?or pull back at times?any way pull the flywheel off and check the key that aligns the crank and flywheel in time they shear when you hit rocks
May 08, 2012 | Mtd Yard - Man 160cc, 21" Self - Propelled...
I have a cub cadet LT1018 with 800 hrs. The engine, B&S 18.5 hp, started running rough and sputtering while mowing. Disengaged PTO to return to garage - mower died. Cleaned air filter and restarted,...
Sounds like water in your carberator. Remove the bowl and check for dirt and water, drain some gas from the tank into a bowl and check for water in the gas. Remove air filter housing and lubrcate all of the carberator linking with a product such as WD-40. Reassemble everything and start again. While you are at it check the spark plug too.
Oct 20, 2017 | Cub Cadet Garden
2002 express 1500 van, will not start
remove dog house locate test port and install guage should be 45-60 psi
Mar 03, 2010 | 2002 Chevrolet Express
Lawn mower won't start
sound like timing is off sherd a key in flywheel
take cover off where you pull the rope and then
take off nut off flywheel its going to be tight and hard to get off but can be done take a screwdriver to hold flywheel ones the nut off look around shaft see if flywheel key is sherd
or pry off flywheel be carefull dont damage anything if sherd replace key
Jul 21, 2009 | Garden
MOWER WONT START
make sure that you have oil and that the airflow is not blocked,,,take the cover and tank off and look underneath, the flywheel is designed to have fins that circulate the airflow, sounds like the piston has welded itself(from lack of oil or airflow) to the cylinder wall. good luck
Jul 03, 2009 | Mtd 22" Yard Machine Push Mower
Mtd 22" Yard Machine Push Mower Logo
222 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
