Question about Kenmore Dishwashers
Grunting sound when running
The dishwasher makes a grunting sound when filling up. I think it' getting worse with time. There is no debris or any dirt caught anywhere. I pretty much rinse the dishes clean before i load it up.
  • 423 Answers
SOURCE: LG dishwasher wont clean top rack dishes
Recommend you remove the approximately 10 screws to pull the entire filter and manually clean. Remove all debris you find and thoroughly rinse out the filter if you can separate the top from the bottom. If the sump area is greasy, use a de-greasing spray to cut through it. Resemble, checking that there are no blockages in the holes on the spray arms.
Fill a bowl or cup with white vinegar and place it on the lower rack of the empty dishwasher. Do not add detergent. Run the quick cycle. The inside of the dishwasher should now be clean and not greasy. If still greasy, use the de-greasing spray (avaiable at all stores in the cleaning section.)
For 30 days, use only Electrosol or Cascade powder. Do NOT use gel or tablets, ever. Please report back your results. Good Luck!
ianc435 , please ask your question in as a new problem and I will help you out. I understand your problem.
Posted on Mar 29, 2009
  • 423 Answers
SOURCE: My dishwasher is making a humming sound and does not rinse?
A humming sound can be a failing wash motor (that drives the water pump) or it can be as simple as a blockage in the the pump area beneath the lower spray arm, under the filter.
Remove the spray arm and the filter top (screws will need to be removed)
Use a flashlight and inspect all over the sump area for debris that is blocking/jamming the impeller area. Reasemble and test with a short cycle.
If the dishwasher continues to make the same humming, it is time to replace the wash pump.
Good Luck! Post back here if you would like more guidance.
Posted on Apr 11, 2009
  • 9 Answers
SOURCE: DISHWASHER MODEL # KUDS03FTBL2 WORKED VERY WELL
Two problems here. Clean out the filter area in the bottom of the dishwasher. Run a quick wash with a cup of bleach in the dishwasher.
The next problem sounds like the water temperature is too high. Make sure the hot water heater is set around 110 - 120 if you want. The dishes could be "etching" in too hot of water. The quality of the glasses or flat wear may not hold up to dishwasher use. Hope this helps.
Posted on May 01, 2009
dnewcombe1
  • 1564 Answers
SOURCE: I think my Bosch dishwasher might be a "lemon". I
Don't be afraid now, but , what I'n going to tell you works VERY often. Pour two cups of bleach into the washer and let it run a potscrubber cycle. They do this all the time at restaraunts, yes really! Let me know how this turns out. P.S. leave the machine empty when you run it. Thanks, Dana
Posted on Aug 22, 2009
  • 127 Answers
SOURCE: dishwasher leave debris on dishes
there is no filter except the screen in the water inlet valve to keep big pieces of grit in the water from defecting the inlet valve..
i dont know exactly why but it sounds like your unit was not installed with a recommended air gap in the drain or something similar and somehow dirty sink/drain/sewer water is making its way back into the unit and onto your dishes.
often times there is a little rubber check valve/flapper in the drain line either installed in the pump or the drain hose just after the pump to keep foreign material from entering the unit..
other than that it would just be mineral and calcium deposits if you are on well water or chunky city water..
hope this helps,
best of luck,
ttfn
Posted on Oct 27, 2009
New Roper Top Load Washer bought at Lowe's. It grunts like a pig while water is filling. Makes same grunting sound during washing cycle. Is this normal?
If it's new,it's under warranty. Don't try any repair.......call m and get it repaired for free or a refund. don-ohio
Jan 03, 2017 | Roper Washing Machines
I have changed my distributor on my rialto 2 car and at medium revs whilst driving it sounds like a bag of nails tried to turn the distributor left to wright it does queten down but still make noise
the noise is most probably detonation of uncontrolled combustion of the mixture in the cylinders
The ignition timing should be no more than 10-12 degrees BTDC
max
If you have described the noise accurately, it occurs mostly on acceleration or when the engine is under load
it is from wrong timing or lean fuel/air mixture or incorrect fuel rating used for the engine ( octane rated at 89 instead of 92 +)
big end bearings start as a knock and gets worse with idle and acceleration
Apr 02, 2016 | Cars & Trucks
My 5 speed bmw 323i makes grunting sounds just
This could be Low Fluids in trans, Or Fluid from the slave cylynder has air in it or low in the resavoir. It seems the clutch is not engaging due to lack of pressure from the slave cylynder not pushing the pressure plate hard enough and in return causing the tranny to make a grunting sound
Oct 16, 2014 | Cars & Trucks
I bought a new frigidaire fridge with the freezer on top. It's made a weird grunting, gurgling, groaning sound on and off from day one. Should have called Leon's where I bought it to complain but never...
hmmm, could be in defrost cycle when that happens, when the defrost element warms up and the frost/ice drips it then makes sounds about how oftern do you hear the noise?
Dec 18, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
I had my black ink cartridge refilled professionally, and printed several pages before receiving an "Error: Incorrect Cartridge" message. The printer is also making a loud grunting sound when I turn it on...
you have 2 different problems
1)  "Error: Incorrect Cartridge"  you get cause your cartridge had air bubbles inside and that damage the printhead
air bubbles must be removed before use ether with a vacuum refill or a refill clip as this video
http://www.youtube.com/watch?v=dhDaKSzou50
2) the loud grunting sound you get it either couse the cartridges are stuck or cause paper is stuck in the paper path and do nt let the cartridge carrier to move free
Jan 15, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Grunting noise?
If your machine is a Brother 4100 you can clear the drum message by pulling the drum out of the machine and then pressing the clear button. The display will ask if a new drum is the be installed. Press the number 1 to say yes. Reinstall drum. This resets the drum counter.
As far as the grunting sound, that may be caused by a tight or jammed toner cartridge. Try changing that out.
Hope this helps.
Aug 27, 2008 | Brother IntelliFAX 4100 Laser Fax
GE JVM1440BD Won't Heat
If it making a louder than normal humming or grunting sound when operating, than it's a sure bet it's the MAG.
Jun 09, 2008 | Microwave Ovens
Dvd recorder grunting, not recording
May be mechanical failure in the sled area. The cause may be dirt or warn parts.
Difficult to really comment properly on this one...
Jerry G.
Mar 02, 2008 | Panasonic DMR-E50 DVD Recorder
Dishwashers Logo
50 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
