Question about Kodak Digital Science 1500D Path-Through Scanner
Have Kodak 1500d. Import with photoshop turns off computer.
Have win xp pro running on 1.8ghz p4. Photoshop 8 recognizes scanner at File>import>kodak 1500d...
but when scanner is selected, the os bluescreens [unable to read errors] and computer shuts off.
I have library of photos with HP. How do I import them to Kodak. It just comes up with Snapfish.
Posted on Aug 07, 2009
How do I get Photoshop CC 64 bit to import scans from my Epson 4990 scanner?
you have to download 64bit driver for printer and install that. if not work you have to copy and paste manually files to plugins folder
Sep 13, 2014 | Office Equipment & Supplies
I have a Microtek 9800XL scanner. I use Photoshop to scan items into my computer. Lately if I use a custom setting and try to scan an image over 300 dpi, I get the following error message (in Photoshop)...
your scanner can not scan above 300. you can try windows scanning, but i wouldn't recommend. New scanners are still a little pricey but are worth it.
http://www.amazon.com/Canon-CanoScan-LiDE110-Scanner-4507B002/dp/B003VQR1UC/ref=sr_1_1?ie=UTF8&qid=1304968981&sr=8-1
for $55 plus shipping
May 09, 2011 | Computers & Internet
Every time I try to open the program, I'm getting this: Adobe Photoshop Elements 6.0 (Editor) has stopped working. Windows can check online for solution to the problem. Check online for a solution and...
Do Solution 1 first, then try Solution 2. Proceed to Solution 3 only if you wish to operate your device directly from within Photoshop or Photoshop Elements Editor.
Solution 1: Disable the TWAIN plug-in. Photoshop and Photoshop Elements Editor do not load plug-ins whose file name begins with a tilde (~). Rename the TWAIN plug-in to prevent Photoshop and Photoshop Elements Editor from loading it.
To disable the TWAIN plug-in:
  1. Do one of the following:
    • If you are using a 32-bit edition of Windows:
      Photoshop CS4: Navigate to C:\Program Files\Adobe\Adobe Photoshop CS4\Plug-Ins\Import-Export\
      Photoshop CS5: Navigate to C:\Program Files\Adobe\Adobe Photoshop CS5\Plug-Ins\Import-Export\
      Photoshop Elements 6.0 Editor: Navigate to C:\Program Files\Adobe\Photoshop Elements 6.0\Plug-Ins\Import-Export\
    • If you are using a 64-bit edition of Windows:
      Photoshop CS4: Navigate to C:\Program Files (x86)\Adobe\Adobe Photoshop CS4\Plug-Ins\Import-Export\
      Photoshop CS5: Navigate to C:\Program Files (x86)\Adobe\Adobe Photoshop CS5\Plug-Ins\Import-Export\
      Photoshop Elements 6.0 Editor: Navigate to C:\Program Files (x86)\Adobe\Photoshop Elements 6.0\Plug-Ins\Import-Export\
    Note: If you do not know which edition of Windows you are using, see Determine whether your computer is running a 32-bit or a 64-bit edition of Windows (kb407673).
  2. Rename Twain_32.8BA to ~Twain_32.8BA. (You may not see the filename extension .8BA.)
When the TWAIN plug-in is disabled, you cannot operate your device by choosing File > Import > [Device name] in Photoshop or Photoshop Elements.
If you do not wish to operate your device directly from within Photoshop or Photoshop Elements, then you can use other software -- such as the software that came with the device, the Windows Scanner And Camera Wizard, or Windows Photo Gallery -- to operate the device and save image files from the device. (For instructions, see the documentation for the other software.) Then you can open those files in Photoshop or Photoshop Elements.
Solution 2: Disable older scanner files in Windows. If Solution 1 does not solve the problem, open the C:/WINDOWS/Twain_32 folder and move all files in that folder except the wiatwain.ds file to another location. Older scanning files in this folder can cause problems with more recent drivers and applications.
If you would like to operate your device directly from within Photoshop or Photoshop Elements, then proceed to Solution 3.
Solution 3: Troubleshoot installed drivers and re-enable the TWAIN plug-in. If you use a scanner, all-in-one printer, or another TWAIN-compatible device on your system, then the device's driver may be out-of-date. Download the latest version of the driver for your device from the manufacturer's website. Follow the manufacturer's instructions to install the driver. (If you have more than one TWAIN-compatible device, then download and install the latest driver for each device.)
After you have installed the latest driver for each device, re-enable the TWAIN plug-in and restart Photoshop or Photoshop Elements.
To re-enable the TWAIN plug-in:
  2. Rename ~Twain_32.8BA to Twain_32.8BA. (You may not see the file name extension .8BA.)
If Photoshop or Photoshop Elements successfully starts with the TWAIN plug-in enabled, then you can operate your device by choosing File > Import > [Device name].
If Photoshop or Photoshop Elements fails to start, then the driver for one or more TWAIN-compatible devices that you no longer have or no longer use may be causing the problem. (A driver will remain on the computer even after you disconnect a device.) Identify each device that you do not use, and then follow the manufacturer's instructions to completely remove each device's driver.
After you remove the driver for each device that you do not use, restart Photoshop.
If Photoshop or Photoshop Elements still fails to start, then the driver for one or more of the devices that you currently use is incompatible with the TWAIN plug-in. In that case, disable the TWAIN plug-in (see Solution 1: Disable the TWAIN plug-in) and leave it disabled. (You may also wish to periodically check the device manufacturer's website for driver updates. If an updated driver becomes available, then repeat this solution.)
Jul 31, 2010 | Adobe Photoshop 6.0 for PC
Using adobe photoshop 8 the editor will import from my Epson Perfection 1260, but the organiser will not get from it displaying "Epson perfection 1260 software for this device could not be launched the...
I don't think it's any of those things. I think it's a Twain Data Source problem. When you install the software for your scanner, make sure you also install the twain data source files. This is the scanning protocol used by all scanners and if not present, the scanner won't import images into Photoshop under the command "File" -> "Acquire."
Mar 25, 2010 | Epson Perfection 1250 Flatbed Scanner
Photoshop cs4 pen pressure not working. Windows xp. Have the latest photoshop update and Wacom tablet update. running Cintiq. Have tried reinstalling tablet and photoshop...did not fix issue. ...
In photoshop, press F5 to bring up your brush control window. Under shape dynamics and other dynamics and any other brush attributes you wish to control with your pen, make sure that control is set to "pen pressure" in the drop down menu. Hope that fixes it for ya.
Dec 16, 2009 | Genius G-PEN F350 Ultra slim tablet....
Fi-5750C Fujitsu scanner can't change grayscale default setting
Photoshop is not an "advanced" scanning program. To get some "production" and value out of this expensive scanner you need a professional scanning program which also may control the settings of the scanner. Use PixEdit which utilizes the built-in jpeg compression in the scanner. Did a test scanning 10 pages A4 duplex fullcolor. Adobe Acrobat Pro used 4 minutes. PixEdit used 20 seconds. Guess Photoshop (in your version) would also scan uncompressed and not use this good scanner optimal.
Jun 26, 2009 | Fujitsu fi-5750C Flatbed Scanner
Customizing an Invoice in QuickBooks Pro 2007 for Mac
From Photoshop, save it as a Photoshop PDF and import it that way. You can customize it as much as you want.
Apr 27, 2009 | Intuit QuickBooks® Pro 2007 Full Version...
Our Epson Scanners do not work from Photoshop CS4
Try using a separate scanner utility to do yr scans - not ideal but sorted my problem. I use the EPSOM scan utility with a Perfection 2400 scanner.
Apr 17, 2009 | Epson Expression 1640XL Pro Flatbed...
Computer does not recognize my scanner
The current software is 1.0.3. It does work with this scanner and XP.
You should install the drivers after removing the existing driver and software. Do not hook up the scanner until the drivers have been installed.
It might not show up under the Cameras and Scanners section in Control Panel but it will still work.
When you open Elements make sure your scanner is on with the door closed. Go down to where you import and look for the scanner to be listed. It will take a minute or two to go through its calibration routine and then you should be able to scan with it.
Jan 18, 2008 | Minolta Dimage Scan Dual II Film Scanner
Kodak Digital Science 1500D Path-Through Scanner Logo
123 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
