Question about Dell XPS M1710 2.33GHz Core 2 DUO T7600 2GB 80GB Blu-ray DVD?±RW WLAN 17" WXGA GeForce Go 7950 GTX V... PC Notebook
Laptop battery charge indicator flashing amber and green
I have a laptop Dell XPS M1710. The battery charge light is flashing 4 times amber, 1 time green. It's only 2 years old. The battery is working normal. It started this when I ran the battery down to 3 % and the computer went into hibernate mode. I would hate to buy a new battery and not fix this nagging little flash at the corner of my screen. Your thoughts on this would be appreciated.
  • 749 Answers
If the battery is hot from being used in your computer or being in a hot environment, the battery may not charge when you connect the computer to an electrical outlet.The battery is too hot to start charging if the laptop battery charge indicator flashing amber and - batter15.jpg light flashes alternately orange and green. Disconnect the computer from the electrical outlet and allow the computer and the battery to cool to room temperature. Then connect the computer to an electrical outlet to continue charging the battery.
Regards..
Posted on Apr 14, 2009
Dell inspiron 1525 - plugged in not charging shown on battery icon. Battery power light blinks 4 times amber then once blue.
The diagnostic procedures from the Dell User Guide are as follows:
Total Power Failure When Using a Battery
If an AC adapter is not connected to your computer, the computer's power source
is a battery. If the battery indicator flashes amber or is a steady amber, the
battery needs to be charged. If the battery is flashing green and amber, the
battery may be defective. To troubleshoot this problem, use the following
procedure.
1. Turn off the computer and peripherals, and disconnect them from AC power.
2. Reseat each installed battery by removing it and then replacing it.
3. Turn on the computer. Does the green power indicator light up?
Allow one minute for the computer to initialize its components before checking
for signs of power.
Yes. Continue to step 4.
No. Use the AC adapter to connect your computer to AC power. If the computer
operates normally when using AC power, go to step 7. If the computer does not
boot when using the AC adapter, see the previous subsection, "Total Power
Failure When Using the AC Adapter."
4. Does the battery indicator flash amber or show a a steady amber light?
Yes. The battery needs to be charged. Go step 5.
No. Go to step 7.
5. Connect the computer to AC power, and fully charge the battery.
For instructions, see the topic titled "Charging the Battery" in the online
System User's Guide.
6. As the battery charges, does the green battery indicator light up?
Yes. Go to step 9.
No. Go to step 7.
7. Is the battery indicator flashing green and amber?
Yes. Your computer may be in a hot environment. Charging the battery in this
condition may affect the life span of the battery. Continue to step 8.
No. The problem is resolved.
8. Disconnect the computer from AC power. Is the the battery indicator still
flashing amber?
Yes. You may have a defective battery. Continue to step 9.
9. Remove the battery, and press its test button. Is the uppermost indicator in
the charge gauge of the battery flashing?
Yes. You have a defective battery. Continue to step 9.
10. If a spare battery is available, fully charge it, and then install it in the
computer.
11. Turn on the computer. Is the power indicator off?
Yes. Your original battery is defective. Call Dell for a replacement. (See
Chapter 5, "Getting Help," for
instructions.)
No. Call Dell for technical assistance. (See Chapter 5, "Getting Help," for
instructions.)
Feb 13, 2011 | Dell Inspiron 1525 Notebook
I have a Dell Inspirion 1525. I have a fairly new after market replacement battery which I have only had now for 4 months. I am using Vista. As soon as I unplug, computer shuts down. I go to power settings...
The adapter is working correctly. The battery is either slow to charge or in need of replacement.
It's possible your battery isn't charging at all so to test this boot into bios -> battery status and watch it run overnight.
Sep 09, 2010 | Dell Inspiron 1525 Notebook
Dell XPS M1330 battery not detected!
Normally the life time of a laptop battery is 300 cycles. that is 300 discharges and charges. Since your laptop is almost 2 years old, the battery could be at the end of its life time, and again depends on how often you use your laptop in a day. Better goto a service center or get a similar battery from any of your friends just to make sure it is not a motherboard issue. Then you can think about which part you've to replace.
Please come back and rate my solution if it turns to be helpful fro you, or also if you need more clarifications. Thnx
Apr 01, 2010 | Dell XPS M1330 Notebook
I have a Dell XPS M1710. PC will not boot, no green light only yellow. Received error code that PC did not recognize poweer source. Bought new power source. PC will not boot, no green light only yellow and...
HI there!
A amber light power button means that the
distribution of the power is not working properly,
And as you have said the battery won't charge anymore,
Usually what fixes that problem of yours is a BIOS
update but from what i see you cannot fix it with a BIOS update anymore.
And on what they said yes your gonna need to replace motherboard because it's not detecting the charger anymore if you can still access BIOS setup go to battery info you will see that the ac adapter is unknow.
So for the fix of your problem there you'll need to get a motherboard for your computer.
Hope this helps!
Mar 26, 2010 | Dell XPS M1710 Notebook
Dell 6000 power problem?
Troubleshooting a power problem is fairly simple:
1 Try a different AC adapter, see if there is any change 2 If system will not power on with a known good or new AC adapter, then the power connection on the motherboard is likely damaged and the motherboard will need to be replaced.
Mar 24, 2010 | Dell Inspiron 6000 Notebook
Dell Inspiron E1705 battery light flashes 4 amber lights, then 1 green. The battery seems to charge.
The ambar lights are warning you the battery is becoming to dead, it means in a short time, if it has not happens now, the battery won't retain the charge anymore, it is time thinking in a replacement if you use your laptop without plug in the power outlet.
Dec 29, 2009 | Dell Inspiron E1705 Notebook
Battery Light Flashes Orange and Green
I have had three different laptops, last one an XPS from DELL which did the same thing. Replacing the battery solved all three laptops. How old is the battery you have in there now?
Jun 02, 2009 | Dell Inspiron 6000 Notebook
Battery indicator?
Hi there.
Sounds like the battery could be faulty.
procedure.
for signs of power.
No. Go to step 7.
Yes. Go to step 9.
No. Go to step 7.
flashing amber?
computer.
Good luck
Jun 01, 2009 | Dell Latitude D600 Notebook
When I plug in my ac adapter into my computer to charge it the green light turns off and won't charge my computer
procedure.
for signs of power.
No. Go to step 7.
Yes. Go to step 9.
No. Go to step 7.
flashing amber?
computer.
good luck
Apr 05, 2009 | Dell Inspiron 6000 Notebook
Dell latitude D600 battery charge light flashing
I had the same problem, I removed the bettery while it was still plugged in, tested it, then plugged it back and and now all is fine.
Nov 02, 2007 | Dell Latitude D600 Notebook
Dell XPS M1710 2.33GHz Core 2 DUO T7600 2GB 80GB Blu-ray DVD?±RW WLAN 17" WXGA GeForce Go 7950 GTX V... PC Notebook Logo
869 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
