Question about Dell Axim X30 Pocket PC
Dell axim x 30 backup battery wont work
My back up battery in my dell axim x30 went completly dead and i bought another one and it still says yhe battery is low .when itack it of the charger it does not work and when i put it back on it blinks from green to orange but my new battery says it is at 100% .what do i do.
  • 326 Answers
--This is a suggestion. I can not be certain given I have not worked on this device. --
Sounds like the backup battery is dead and needs to be replaced.
Researched The battery, and it is a standard flat-cell available at Radio Shack.
Taking the device apart will void the warranty.
The device is assembled in a standard click-tab and possibly some small hidden screws.
A plastic screw-driver or non-marring wedge tool is best.
Simple work your way around its edges until a gap forms and gently feel towards a portion that will not separate. Get a tool in there and gently pry away from the device to disengage the clips, rinse and repeat.
Upon removing all the tabs, remove the back panel slowly to assure that there are no wires connected to the panel itself, you should see the battery.
Posted on Apr 14, 2009
Where is the backup battery
On the motherboard, at the bottom near the charging port. You will have to remove the motherboard completely to access it. Here is a good tutorial with pictures and all the information you need.
Dec 07, 2011 | Dell Axim X30 Pocket PC
MY DELL AXIM X30 WILL NOT TURN ON
My Axim X30 would not turn on using battery power but would turn on when connected through charger adapter.
Solution:
1. Connect AC adapter directly to the charger adapter and then to the Axim X30 and to the electrical outlet.
2. Charge battery until power button is solid green.
3. Press the power button to power on.
4. Remove cable from cable connector leaving the cable connector connected to the Axim X30. The Axim X30 will remain powered on.
5. Turn the Axim X30 off.
6. Turned the Axim X30 on using battery power.
7. Remove cable connector from Axim X30.
Apr 07, 2009 | Dell Axim X30 Pocket PC
When charging my axim X30 on the cradle, the on-off light is blinking from green light to amber consistantly... when I remove the device from cradle the device does not turn on at all.. I have replaced the...
It sounds to me that your "original" battery, the one that causes the blinking when charging is completly drained dead, causing it to show an error by blinking the light.
I have one of these PDA's and have never had that problem, I also have a larger battery as well, and it works great. I suggest recycling the other battery, and possibly purchasing another larger one for back up,
Mar 27, 2009 | Dell Axim X30 Pocket PC
Delll axim x30 screen remains dimmed even though fully charged
ok , you have checked the brightness settings, check battery power settings as well. you may have to do a hard reset so back up your info. If doing a hard reset, pull the battery and charge it on its own if you have a cradle. Hope this works for you
Feb 28, 2009 | Dell Axim X30 Pocket PC
Backup battery
its in the back of device a slight curved flap is given just lift that flap and its there.
Sep 18, 2008 | Dell Axim X30 Pocket PC
Fixing backup battery for axim 30
http://www.gethightech.com/Merchant2/merchant.mv?Screen=CTGY&Store_Code=GHT&Category_Code=_x3_takeapart
step 10 is actually the lead to the backup battery. Follow the wires to find the battery.
Hope it helps.
Jun 03, 2008 | Dell Axim X30 Pocket PC
Screen frozen with vertical lines
same problem
if anyone has any suggestions, it would be appreciated.
Nov 18, 2007 | Dell Axim X30 Pocket PC
Backup battery problem
Try this web site:http://www.pdasmart.com/aximpartscenterx3.htm?tp=CONTINUE+SHOPPING
Sep 04, 2007 | Dell Axim X30 Pocket PC
Dell Axim X30 Pocket PC Logo
356 people viewed this question
Alun Cox
