Cannot access motherboard on Gateway xl500
I have a Gateway xl500. I want to add more ram. I cannot open the case to get to the motherboard. Is there a simple way to open the case to get at the motherboard
  • mr Overland May 11, 2010
    take a look here is this is the correct system manaul
    500 series.pdf
  • 70 Answers
It have alock in the back push down while holding it and push lit in the back
remove screws if their is any
Posted on Aug 05, 2009
How do I open a Gateway ZX4270 to add a 4GB chip of RAM
You will likely just have to open the case of the unit (removing the back cover) and there should be a ram din in plain sight.
Sep 16, 2014 | Gateway ZX4270-UR30 19.5-Inch All-in-One...
How do I upgrade my ram on my Gateway All in one zx4250?
I too purchased a Gateway ZX4250 and a 4 GB RAM upgrade kit. It took me awhile to figure out how to open the case. Here is what I found.
1) Remove the two rubber pads at the bottom of the case (don't worry they pop right back on).
2) Open the small back cover.
3) Remove the one screw.
*****CAREFUL****
4) This part is a little difficult but just be careful not to use too much force. Take two small flat head screwdrivers and slowly separate the plastic silver front panel from the plastic black back panel. Start at the bottom where the two rubber pads were removed. Work your way around the case, you can see how the clips are connecting the two panels as you work your way around the all-in-one. It shouldn't be too hard just be careful on how much force you use.
5) Once the panels are separated you can now access the hard drive, optical drive and some other components.
6) Disconnect the Hard drive sata cable from the motherboard.
7) Disconnect the other cable right next to the sata cable on the motherboard (I'm not sure as to the purpose of this cable.
8) Remove the screws from the metal plate covering the motherboard. Take careful note that a grounding cable is connected to one screw.
9) Install your RAM.
10) Reverse the procedure to put everything back together.
This whole procedure to upgrade my RAM took about 15 minutes. I hope this helps some of you that are trying to upgrade your RAM. If you have any questions PM me.
Jan 03, 2012 | Gateway ZX493131e Notebook
Cant open the tower. i want to add ram. what is the max i can add?
One way to find out for sure how much RAM your computer can hold is to go to WWW.CRUCIAL.COM and run their SCAN MY COMPUTER feature.
This handy utility will scan your hardware configuration and tell you exactly how much RAM you currently have installed and what type it is.
It will also tell you how many RAM slots are fitted on your motherboard and what the maximum memory capacity is for that motherboard.
If your computer does have room to add more RAM, it will provide you with specific recommendations as to exactly what type and size of RAM stick to get to maximize the memory capacity and performance of your computer.
Feb 22, 2011 | Gateway Computers & Internet
I already have 512 ddr2 667 ram .So now I want to add an extra 256 ddr2 533 ram to my Intel D102ggc2 motherboard .So can I able to do this .
Open your computer's case and check for a free slot on the motherboard. If there is any, then you can add another memory module, no problem with that.
Jan 08, 2011 | Intel D102GGC2 Motherboard
Has pc100 128mb and tried to go to Pc133 and wouldn't accept, what is the max memory i can put on this board
the details of that board are sorta sketchy, it could be an intel 810 series or 815 series. theres really no way to tell except by opening it up and looking for the largest exposed ic chip with intel stamped on it, and look for an 810 or 815 designation on that chip.
if its an 810, it may not support pc133 ram, depending on the exact 810 model. if its an 810, it also will not support more than 256 total ram.
if its an 815, it will accept 512 total ram, if not more; however, you will have to go with no more than 4 ram sides- meaning, if you have 2 double-sided ram sticks, you will not be able to add anymore. if you have 2 single sided sticks, and a 3rd ram slot open, you may be able to add a double sided stick in the empty slot for 1+1+2=4 ram sides.
Sep 29, 2010 | Gateway PGA370 E139761 DIMM Motherboard...
How to add memory to my pc gm5472
You need to open the case and see how many sticks of memory are in the slots. Your machine should come with 2GB. (probably 2 1-GB sticks)
If you are running a 32-bit system, it's useless to increase the memory above 3 GB, as the system will not see it. For a 64 bit system, you can add a lot more.
Sep 25, 2009 | Gateway GM5472 PC Desktop
I want to expand the RAM in my Gateway 500SE computer
GATEWAY 500SE Computer Case Cover Removal before installing RAM
  1. Turn off the computer and then disconnect the power cord.
  2. On the rear of the computer, remove the three screws that secure the cover on the case.
  3. Slide the cover back about one-half inch, and then lift it from the case.
  4. Search for a small scale like card in motherboard similar to small scale as shown in figure in BANK A or BANK B.
  5. And place the another ram in free bank slot (RAM Slot).
  6. Make sure the locks are correctly locked to RAM at both sides.
  7. Close the cover
  8. Power On the System
  9. If any beep sound then switch of the system and reinsert the RAM module.
Hope this will be helpful
Thanks & Regards
Nandu
Mar 25, 2009 | Gateway 22929 Notebook
Want to add memory to Gateway 700x
Upgrading RAM on your Gateway 700X (DDR) Computer is easy, Gateway 700X (DDR) Computer takes the PC3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. RAM Type, and comes installed with 512 MB (removable) of RAM.
You can upgrade your Gateway 700X (DDR) Computer to up to a maximum of 2.0 GB RAM, the Computer has 4 sockets to install RAM, already with 512 MB (removable) standard RAM installed. For best Computer performance use the maximum amount of allowed RAM per slot for your system.
Dec 08, 2008 | Computers & Internet
Adding Memory to Gateway 420r
If you mean a Gateway 420GR (there's no "420R" listed on their site), then you can have up to 4GB of RAM and you can use 1GB modules. Here's a link to the specs page on their site:
http://support.gateway.com/s/PC/R/4053/4053sp3.shtml
Nov 21, 2008 | Gateway (4000779) Motherboard
Computers & Internet Logo
120 people viewed this question
David Payne
David Payne
